Dash EL Inverter Locations
09-22-2006, 03:01
Don,
I only see what looks like globs of silicone on the panel back, with the wire going through the silicone. What am I missing? Is there a plug under the silicone? Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. dspithaler@... wrote: >Curt > Mine had a loose wire on the right upper side that when I plugged it in >every thing worked fine except the small middle section. > Don > 89 SP 36' > Butler, PA > >Don, >Good question. I don't recall if the altimeter would light up. Once I >had the upper dash working, it soon failed which could be caused by me >doing a lot of work up in there. I have not gotten back to testing that. >Will do so soon, maybe. It is on my to-do-list. > >Curt Sprenger 1987 PT38 > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
09-22-2006, 03:51
Curt STOP:
There is no plug , the wires are attached to a foil, do not disconnect, These wires can not be reconnected. Go the other way follow the wires, to the inverter. 12 volts IN AC volts OUT , the Hz are way more than 60 Hz. maybe 200/ 300 Hz The voltage may be 110 or probably much higher RMS voltage 250 Volts depending on your meter and reostat setting. You can hear a faint Hum, and any voltage reading is probably a good sign, I suggest you replace the inverters with the new from Stephen. Makes the Gingerbread much brighter Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Don, > > I only see what looks like globs of silicone on the panel back, with the > wire going through the silicone. What am I missing? Is there a plug > under the silicone? > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > dspithaler@... wrote: > > >Curt > > Mine had a loose wire on the right upper side that when I plugged it in > >every thing worked fine except the small middle section. > > Don > > 89 SP 36' > > Butler, PA > > > >Don, > >Good question. I don't recall if the altimeter would light up. Once I > >had the upper dash working, it soon failed which could be caused by me > >doing a lot of work up in there. I have not gotten back to testing that. > >Will do so soon, maybe. It is on my to-do-list. > > > >Curt Sprenger 1987 PT38 > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > |
09-22-2006, 03:57
No, the altimeter does not light.
Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 22, 2006 9:54 PM Subject: Re: [WanderlodgeForum] Dash EL Inverter Locations Don, Good question. I don't recall if the altimeter would light up. Once I had the upper dash working, it soon failed which could be caused by me doing a lot of work up in there. I have not gotten back to testing that. Will do so soon, maybe. It is on my to-do-list. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. dspithaler@... >Curt > Does your Altimeter panel light up. If it is suppose to mine doesn't. >Only the panels on each side. >Don >89 SP 36' >Butler, PA > > > >One upper dash inverter. Multiple panels...a left panel, a right panel, >and the Altimeter between the two. > >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed] |
09-22-2006, 04:39
Bill,
I replaced the original inverters, got them from Stephen. The upper EL panels came alive after R&R the inverters. Now they don't come alive. The trouble is most likely me working in the upper dash, and I caused the problem. Do you recall if the inverters 12VDC feed is fused? Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. pattypape wrote: >Curt STOP: > >There is no plug , the wires are attached to a foil, >do not disconnect, These wires can not be reconnected. >Go the other way follow the wires, to >the inverter. 12 volts IN AC volts OUT , the Hz are way >more than 60 Hz. maybe 200/ 300 Hz The voltage may be 110 >or probably much higher RMS voltage 250 Volts >depending on your meter and reostat setting. >You can hear a faint Hum, and any voltage reading >is probably a good sign, I suggest you replace the inverters >with the new from Stephen. Makes the Gingerbread much brighter > >Bill 88 FC > >--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > >>Don, >> >>I only see what looks like globs of silicone on the panel back, >> >> >with the > > >>wire going through the silicone. What am I missing? Is there a >> >> >plug > > >>under the silicone? >> >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. >> >> >> >>dspithaler@... wrote: >> >> >> >>>Curt >>> Mine had a loose wire on the right upper side that when I >>> >>> >plugged it in > > >>>every thing worked fine except the small middle section. >>>Don >>>89 SP 36' >>>Butler, PA >>> >>>Don, >>>Good question. I don't recall if the altimeter would light up. >>> >>> >Once I > > >>>had the upper dash working, it soon failed which could be caused >>> >>> >by me > > >>>doing a lot of work up in there. I have not gotten back to >>> >>> >testing that. > > >>>Will do so soon, maybe. It is on my to-do-list. >>> >>>Curt Sprenger 1987 PT38 >>> >>> >>> >>> >>>[Non-text portions of this message have been removed] >>> >>> >>> >>> >>>Yahoo! Groups Links >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
09-22-2006, 06:14
Leroy, The late Sid Clark had a Royal conversion. No goat rails, and very
nice inside. A member of the forum purchased that coach. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-22-2006, 08:29
Sorry Curt,
I did not trace the circuit, nor did I need to find a fuse or circuit breaker. Start by looking at the master electrical drawing for your 87 8v. The EL, AC wireing on our 88 is color coded solid black and solid green. These wires are heavier than expected and really stiff. You may have a loose connection, BB also used those push-on connectors and splice connectors that sometimes become loose. I hard wired to the new inverters to eliminate some of these troublesome contact connections. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Bill, > I replaced the original inverters, got them from Stephen. The upper EL > panels came alive after R&R the inverters. Now they don't come alive. > The trouble is most likely me working in the upper dash, and I caused > the problem. > > Do you recall if the inverters 12VDC feed is fused? > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > pattypape wrote: > > >Curt STOP: > > > >There is no plug , the wires are attached to a foil, > >do not disconnect, These wires can not be reconnected. > >Go the other way follow the wires, to > >the inverter. 12 volts IN AC volts OUT , the Hz are way > >more than 60 Hz. maybe 200/ 300 Hz The voltage may be 110 > >or probably much higher RMS voltage 250 Volts > >depending on your meter and reostat setting. > >You can hear a faint Hum, and any voltage reading > >is probably a good sign, I suggest you replace the inverters > >with the new from Stephen. Makes the Gingerbread much brighter > > > >Bill 88 FC > > > >--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > >>Don, > >> > >>I only see what looks like globs of silicone on the panel back, > >> > >> > >with the > > > > > >>wire going through the silicone. What am I missing? Is there a > >> > >> > >plug > > > > > >>under the silicone? > >> > >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > >> > >> > >> > >>dspithaler@ wrote: > >> > >> > >> > >>>Curt > >>> Mine had a loose wire on the right upper side that when I > >>> > >>> > >plugged it in > > > > > >>>every thing worked fine except the small middle section. > >>>Don > >>>89 SP 36' > >>>Butler, PA > >>> > >>>Don, > >>>Good question. I don't recall if the altimeter would light up. > >>> > >>> > >Once I > > > > > >>>had the upper dash working, it soon failed which could be caused > >>> > >>> > >by me > > > > > >>>doing a lot of work up in there. I have not gotten back to > >>> > >>> > >testing that. > > > > > >>>Will do so soon, maybe. It is on my to-do-list. > >>> > >>>Curt Sprenger 1987 PT38 > >>> > >>> > >>> > >>> > >>>[Non-text portions of this message have been removed] > >>> > >>> > >>> > >>> > >>>Yahoo! Groups Links > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > |
09-22-2006, 10:54
Thanks Ernie: I will follow up with BB next week
Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 22, 2006 5:14 PM Subject: Re: [WanderlodgeForum] Dash EL Inverter Locations Leroy, The late Sid Clark had a Royal conversion. No goat rails, and very nice inside. A member of the forum purchased that coach. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-22-2006, 11:13
and the Altimeter between the two. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: >Curt: Thanks, this winter I am going to look again for the inverters that power my overhead panel. I have a Royal conversion and cannot remove the panel, encased with wood. It is the only one that does not work so I think the problem is in the inverters. Cannot find them. I don't know how I going to do it but will try again. There are many stereo, TV and other cables in the overhead cabs. Looks like good Italian spaghetti. > So there was only on inverter cube that powered your complete overhead panel? Is there only one panel? I think I have three. > >Leroy Eckert >1990 WB-40 >Niceville, FL > > > > |
09-22-2006, 11:15
Curt
I just went out & opened up my right side top dash & looked at it. Yours might not be like mine but I have two wires coming from the left side. One is green & the other is black. They have a male & a female plug on each wire & are connected & from there they go to a silicone glob in the dash. The glob is right below the Batt Charge & Coach Load Gage. It was the black wire that was disconnected in mine. To make sure I unplugged it & I didn't have any lights on the right side. I think they do it like this because they don't light the altimeter gage area. My guess??? Hope this helps. Don 89 SP 36' Butler, PA Don, I only see what looks like globs of silicone on the panel back, with the wire going through the silicone. What am I missing? Is there a plug under the silicone? Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. _dspithaler@..._ (mailto:dspithaler@...) wrote: >Curt [Non-text portions of this message have been removed] |
09-22-2006, 16:54
Don,
Good question. I don't recall if the altimeter would light up. Once I had the upper dash working, it soon failed which could be caused by me doing a lot of work up in there. I have not gotten back to testing that. Will do so soon, maybe. It is on my to-do-list. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. dspithaler@... wrote: >Curt > Does your Altimeter panel light up. If it is suppose to mine doesn't. >Only the panels on each side. >Don >89 SP 36' >Butler, PA > > > >One upper dash inverter. Multiple panels...a left panel, a right panel, >and the Altimeter between the two. > >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
