Front running light mod
11-15-2006, 05:20
Hello everyone:
Some time back there was a thread on someone making or having made a
stainless cover for the front running lights that is located between the
headlights on the 90's Coaches.
I searched but did locate the thread. Where was it made? are they
available? Any help is appreciated.
Safe travels,
11-15-2006, 06:41
Hi Ralph,
These guys can definitely make it. They may even have
something is stock:
http://www.summit-products.com/contact.htm
David Brady
'02 LXi, Smokey
Va no more
Ralph L. Fullenwider wrote:
> Hello everyone:
> Safe travels,
11-15-2006, 07:44
Ralph,
Greg O'Connor made a SS cover that goes between the head lights on his '94.
Curt Sprenger
Anaheim Hills, Calif.
>Hello everyone:
>Safe travels,
11-15-2006, 08:05
Ralph:
I fabricated flat stainless for my coach including a plate that surrounds the
headlight and turn signal. I used 20 guage #8 polished stainless. Got the metal
from Phoenix Metals.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Niceville, FL
Sent: Wednesday, November 15, 2006 11:20 AM
Subject: [WanderlodgeForum] Front running light mod
Hello everyone:
Safe travels,
11-15-2006, 09:10
Thanks to all for the info, very much appreciated. With your help, I have
found the solution.
Ralph
At 01:41 PM 11/15/2006 -0500, you wrote:
>Hi Ralph,
>something is stock:
>David Brady
>'02 LXi, Smokey
>Va no more
> > Hello everyone:
> > Safe travels,
>Yahoo! Groups Links
Safe travels,
11-15-2006, 17:18
Ralph, I made several out of rem stock I think 6 units cost less than
20.00 to make. Its easy if you have access to a brake. from
headlight to headlight there is a slight radius that can be
duplicated by leaving both fold tabs with material to trim ( aprox 2
inches)drag a plasma torch quick for the first 4-5 and last 4-5
inches but lift the torch during the center cut to heat the dross and
distort the SS with a radius. If you want it closer to chrome
use "everbright" SS I went with the DeLorean look using brushed SS.
I made one of each for a guy we are meeting up with in Quartsite.
GregoryO'Connor
94ptRomolandCa
I have
> found the solution.
> Ralph
> >Hi Ralph,
> >something is stock:
> >David Brady
> >'02 LXi, Smokey
> >Va no more
> > > Hello everyone:
made a
between the
they
> > > Safe travels,
> >Yahoo! Groups Links
> Safe travels,
