Hot water and boondocking
12-12-2006, 06:48
It sure was a relatively easy build when the factory did all our plumbing.
After they installed the bed, cabinets, closets- then it became a chore to work
on. I'll probably replace the street side plumbing with pex when I get back
to Montana next year. At least I have a few months to either think about that
project- or just forget about it.
83PT40
Weatherford, tx
12-12-2006, 07:21
I'm used to the household system which has a return line to the
cold/supply side of the water heater, with a check valve, and
convection keeps the hot water circulating throughout the system. A
manual valve in the return is also employed to restrict flow. Works
great in a household water heater, whether it would also work in the
relatively short RV-size tank I don't know.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> We took a 4 day trip and had only power available. I left with a
> full water tank and mostly empty grey and black tanks. By the last
> day I had about 1/4 tank of water left. I began to think about
ways
> to conserve water to streach the time we could stay. One thought
was
> the waste of water waiting for the sink or shower hot water to
come
> up to temperature. It was cold outside so it took a while, wasted
> water and holding tank capacity.
> In hotels/motels/large buildings they use a circulating system
> that keeps the hot water supply hot so you don't wait for hot
water
> at the tub or tap. It would seem that this could be done in an RV
by
> adding a return line from the far end of the hot water system, a
one-
> way valve and a pump. Then all you would need to do is activate
> pump for a minute or so to charge the system, and then start the
> shower. It would conserve the water supply as well as the grey
tank
> space.
> Has anyone seen this kind of system in use?
> Gardner
> 78FC33
12-12-2006, 09:21
An interesting thought for water conservation but, since the copper
hot water pipes are bundled next to the copper cold water pipes, then
wrapped in heat tape, you'll have to find a way to keep your cold
water cold once you start keeping your hot water hot...
With every yin, there's a yang...
Gary Miller
83 FC 33
Milwaukee area
> day I had about 1/4 tank of water left. I began to think about ways
was
> the waste of water waiting for the sink or shower hot water to come
> that keeps the hot water supply hot so you don't wait for hot water
by
one-
> way valve and a pump. Then all you would need to do is activate the
> shower. It would conserve the water supply as well as the grey tank
> space.
> Gardner
> 78FC33
12-23-2006, 11:15
Hi all:
Back onto this topic. I was doing some browsing of the net, and
Lucas Willemese (did I spell that right?) had a gizmo in his coach.
Well I am not sure if this was the item or not, but it is called
a "chillipepper". Just the thing that we should have on our coaches.
Look it up and let me know what you think.
http://www.chilipepperapp.com/hwcs.htm
Bill
84FC35SB
Terrace, B.C.
> ways
> was
> come
> water
> by
> one-
> the
> tank
> > space.
> > Gardner
> > 78FC33
12-23-2006, 13:39
Bill,
I don't know if my previous post made it, I got a bad message, so
here I go again.
Nice find on the Chilipepper. I may even install one in my house.
I need to install a bypass for the hot water heater in the Bird for
winterization, so it might be a good time to install one of these as
well.
I had to replace the ice maker module in the U-line, and the
microwave krumped, so I don't think the Chilipepper will be on the
imediate horizon.
I was thinking I might paint the Bird Visa blue with Red ink trim.
What do you think?
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "Bill"
> Hi all:
coach.
coaches.
> Bill
> 84FC35SB
> Terrace, B.C.
> > ways
thought
> > was
> > come
wasted
> > water
RV
> > by
a
> > one-
activate
> > the
> > tank
> > > space.
> > > Gardner
> > > 78FC33
12-23-2006, 15:01
Hey, a 'bird is better than a boat. Boats sink. (Well, a 'bird would,
too, but they're usually not _intentionally_ put into water.)
Pete Masterson
aeonix1@...
El Sobrante, CA
On Dec 23, 2006, at 5:39 PM, Gardner Yeaw wrote:
> <snip>
> What do you think?
12-23-2006, 18:39
Bill, Lucas and Linda have all the cool stuff. The little green toad
was the best.
Years back California had a water shortage and one method we used to
save the resource and get the hotwater to the shower was to simply
brush your teeth with the cold water that comes out of the hot tap at
the sink prior to hitting the shower (won't work if you clean them in
a cup). Chillipepper is cool and I can see where it is a must have on
a Yacht like the Willemese have.
GregoryO'Connor
94ptRomolandCa
> Hi all:
coach.
coaches.
> Bill
> 84FC35SB
> Terrace, B.C.
> > ways
thought
> > was
> > come
wasted
> > water
RV
> > by
a
> > one-
> > the
> > tank
> > > space.
> > > Gardner
> > > 78FC33
12-24-2006, 05:39
Greg:
You right, they had all sorts of cool stuff, and that little green toad was
awesome. For a little car, it was quite roomy in the back seat LOL.
And you right about the cup thing too - hehe.
Terrace, B.C. Canada
----- Original Message ----
Sent: Saturday, December 23, 2006 10:39:16 PM
Subject: [WanderlodgeForum] Re: Hot water and boondocking
was the best.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@ yahoogroups. com, "Bill"
> Hi all:
coach.
> a "chillipepper" . Just the thing that we should have on our
coaches.
> http://www.chilipep perapp.com/ hwcs.htm
> Bill
> 84FC35SB
> Terrace, B.C.
> > ways
thought
> > was
> > come
wasted
> > > In hotels/motels/ large buildings they use a circulating system
> > water
RV
> > by
a
> > one-
> > the
> > tank
> > > space.
> > > Gardner
> > > 78FC33
Do You Yahoo!?
http://mail.yahoo.com
12-24-2006, 06:12
Gardner:
Have you tried putting your bus pic into a pic gallery and painting it there
before you actually paint it?
I liked the color of one of the FC's, it was white, blue and red, and my wife
hated it, hmmm it is all in the eye of the beholder LOL
Sent: Saturday, December 23, 2006 5:39:37 PM
Bill,
here I go again.
well.
imediate horizon.
What do you think?
Gardner
78FC33
> Hi all:
coach.
coaches.
> Bill
> 84FC35SB
> Terrace, B.C.
> > ways
thought
> > was
> > come
wasted
> > water
RV
> > by
a
> > one-
activate
> > the
> > tank
> > > space.
> > > Gardner
> > > 78FC33
Do You Yahoo!?
12-24-2006, 09:55
Bill,
My wife is a photographer and well versed in Photoshop. When I
get ready to actually paint, that is where we will start. But for
now, I have lots of things to do before I start to get ready for the
painting stage.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> Gardner:
painting it there before you actually paint it?
and my wife hated it, hmmm it is all in the eye of the beholder LOL
> From: Gardner Yeaw
> Bill,
> here I go again.
for
as
> well.
> imediate horizon.
> What do you think?
> Gardner
> 78FC33
> > Hi all:
> coach.
> coaches.
> > Bill
> > 84FC35SB
> > Terrace, B.C.
> > > ways
> thought
> > > was
to
> > > come
> wasted
system
hot
> > > water
an
> RV
> > > by
system,
> a
> > > one-
> activate
> > > the
> the
grey
> > > tank
> > > > space.
> > > > Gardner
> > > > 78FC33
> Do You Yahoo!?
