Shower Water Mixer Repair?
01-05-2007, 02:57
Scott the grease is a good tip, and I will make sure I include this
in the parts list.
Thanks!
Kevin
--- In WanderlodgeForum@yahoogroups.com, "Scott"
> Bill, took the words right out of my "keyboard" :>) I did alll the
> valves in RUBY last fall, and they work great...
> Kevin, I would suggest you also get some "plumbers grease" to lube
> the o'rings inside. A tiny tube of "high temp, water proof" grease
> will work. I used Q tips to apply. Also on our 86FC I needed
> the "special wrench" (small plastice piece) came with the rebuild
> from HD to remove the existing core. Really easy job..
> Good Luck
> Scott B
> 86FC35 RUBY
> Murrells Inlet SC "leaving for OKC in the am"
> --- In WanderlodgeForum@yahoogroups.com, "pattypape"
> > IF it is a Moen any HomeDepot,Lowe's or hardware store had the
> > replacement about $20.00. If you can wait Moen will sent it
free,
> just
> > call the 800 number.
> > Bill 88 FC
> > --- In WanderlodgeForum@yahoogroups.com, "Kevin Ford"
> > > Hello:
> > > My shower water mixer will no longer shut off on my 1982 PT40,
> and my
> > > questions is can this be repaired or do I have to replace it (I
> > assume
> > > it is orginal)? I'm hoping it can be repaired since it will
> be "very"
> > > difficult to remove without damaging the shower stall.
> > > As always your help is greatly appreciated!
> > > Kevin Ford
> > > 1982 PT-40, Richmond TX
01-05-2007, 07:19
It sure does.
David Hollis 84FC35 Springfield,IL
> Kevin, when I had my 35 for sale and we were headed to RIV to
deliver the
> coach, same thing happened. Due to non use, it would not operate
and we sprayed
> wd-40 in it. Finally had to take it apart and clean it. Guess it
works, fine,
> now.
> Ernie Ekberg
> 83PT40
> Weatherford, tx
01-05-2007, 08:31
In the event you have the new control in and you have cold on the hot
side and hot on the cold, pull it out and turn it 180 de and put
it back in.
David T
89 fc
Northern Wi
User(s) browsing this thread: 13 Guest(s)
