Dump Valve Rebuild?
02-27-2007, 15:22
Post: #21
Dump Valve Rebuild?
make sure you turn on the block heater- less smoke- same noise~
83PT40
Livingston,Montana
Sent: Tuesday, February 27, 2007 7:31 PM
Subject: Re: [WanderlodgeForum] Dump Valve Rebuild?
Will do Ernie. I bought a Senco dual tank model for the Bird. Nice &
small, 120 volt.
Kellie won't let me start the Detroit until I go outside & warn anyone
within 50 yards or so. This should solve that problem.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
ernieekberg@... wrote:
> Terry- let me know how you plumb in your aux air compressor. It takes
> me forever to build air and I would like to be able to leave sooner
> then before- especially if this river rises too fast on spring thaw.
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Terry Neal
> Sent: Tuesday, February 27, 2007 6:15 PM
> I don't have air valves Pete. I just mentioned them so Keith could
> consider them as an option. I know there are electric valves out there
> too. Believe they are 12 volt.
> I don't see why you can't power your waste valves from your aux air
> system if your aux compressor is plumbed into your coach air system?
> Should be an easy modification for your coach I think.
> That's what most people are doing with an aux compressor anyway so you
> don't have to fire up that big diesel to have air to leave a campground
> or to dump your holding tanks.
> I have an aux compressor that I will plumb into my coach air system so I
> won't kill any neighbors on a cold Detroit start up.
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> Pete Masterson wrote:
> > Now that there is a discussion of dump valves ... and you mention the
> > &^%^&% air valves ...
> > I really hate having to 'air up' the coach just to dump, especially
> > when I'm in an RV park for a week or so. It seems so silly to run a
> > 500 hp engine just to get the air pressure to dump the sewage.
> > So, does anybody know if
> > 1. is it practical to re-route the air valve source to the auxiliary
> > compressor (used to provide air to the Microphor toilet) -- and will
> > that compressor be able to provide enough air to efficiently operate
> > the air valves without stressing the compressor, or
> > 2. what are some of the alternatives (and costs + ease of
> > installation). Are electric valves a good idea? I certainly don't
> > really want to hassle with manual valves... the switches are close
> > enough to the sewage as it is...
> > When in an RV park, I usually go 3 days between dumps or I dump on
> > the day we leave... It's not like I do it all the time, but I have
> > noticed a few strange looks from neighbors after I've 'aired up' to
> > do a dump.
> > Pete Masterson
> > aeonix1@...
> > '95 Blue Bird Wanderlodge WBDA 42'
> > El Sobrante, CA
> > On Feb 27, 2007, at 1:34 PM, Terry Neal wrote:
> > > Keith, you should contact Jeff Miller at Dupree Products
> > > (616.355.9811). He owns Dupree now & has the valves in stock as
> > > well as
> > > all the rebuild parts. Also,. you can upgrade to air valves if that
> > > interests you? The bodies are glued into the tank adapter. If you
> > > get
> > > lucky, the adapter that screws into the tank will turn out easily. If
> > > not, you have the cut the fitting out of the tank & glue a new one in.
> > > Terry Neal
> > > Bozeman, MT
> > > 82PT40 6V92TA
> > > 74FC34 6V53T
> > > Keith Strehle wrote:
> > >> The next item on the list is the dump valves. They are the twist lock
> > >> type and appear to be original equipment. The look just like the
> > >> Dupree
> > >> valves? Are there knockoffs out there? Are the valve bodies glued in?
> > >> If they are Dupree valves, should I rebuild or replace the gate
> > >> assembly?
> > >> Thanks, Keith
> > [Non-text portions of this message have been removed]
02-27-2007, 15:35
Post: #22
Dump Valve Rebuild?
No MORE "twist and turn"....NO MORE "pump up the air"...just
install...DRAINMASTER DOT COM 12 VOLT ELECTRIC DUMP VALVES...I PUT
THEM ON BOTH my birds..80FC31 & 90SP36...love em!..ask for JIM at
drainmaster.com
Regards,
Hank Hannigan
90SP36..LOL
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Terry Neal
Nice &
> small, 120 volt.
anyone
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
It takes
sooner
thaw.
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Terry Neal
could
out there
aux air
system?
anyway so you
campground
system so I
> > Terry Neal
> > Bozeman, MT
> > 82PT40 6V92TA
> > 74FC34 6V53T
mention the
especially
to run a
sewage.
auxiliary
and will
operate
don't
close
dump on
I have
up' to
> > > do a dump.
> > > Pete Masterson
> > > aeonix1@... 40mac.com>
> > > El Sobrante, CA
stock as
> > > > well as
valves if that
If you
> > > > get
easily. If
new one in.
> > > > Terry Neal
> > > > Bozeman, MT
> > > > 82PT40 6V92TA
> > > > 74FC34 6V53T
the twist lock
like the
> > > >> Dupree
bodies glued in?
the gate
> > > >> assembly?
> > > >> Thanks, Keith
02-27-2007, 16:46
Post: #23
Dump Valve Rebuild?
Pete can you use the Microphor pump to open the dump valves????
GregoryO'Connor
94ptRomolandCa
> Sounds like you have an electric-only Microphor (as I do) instead
of one of the ones with air assist?
> On 2/28/2007 at 2:00 AM Gregory OConnor wrote:
> >Mike, My 94 doesnt have an aux air compressor or air to the toilet
> >what ever that is all about????.
> Don Bradner
> 90 PT40 "Blue Thunder"
> Eureka, CA
02-27-2007, 17:42
Post: #24
Dump Valve Rebuild?
Pete,
I have two compressors; one dedicated to the Michrophor toilet that
runs off the house batteries and an auxiliary compressor the runs off
110 volt shore power or generator. The auxiliary generator, with a
switch on the right side of the steering wheel, second row from the
top, will inflate brakes, air bags and Dupree valves without running
the Series 60. Sometimes after a long time at rest, it is faster to
run the Series 60 to air up instead of waiting 30 - 45 minutes. I
know I have some air leaks that I will be addressing at the next
service visit.
Tom McCarthy
same coach, same layout, same year
> GregoryO'Connor
> 94ptRomolandCa
toilet
> > Don Bradner
> > Eureka, CA
02-28-2007, 01:49
Post: #25
Dump Valve Rebuild?
I have the electric Microphor toliet on my 93, (They use the
electric model if the holding tank is directly under the stool) I
have the onboard aux. compressor which is used for opening the waste
valves (usually along with the help of the DUPREE VALVE TOOL , this
is something you can't be without. Also something to keep in mind is
that the drier valve on the clothes drier needs air to open. The red
light being on when it's in the open position is indicating only the
POSITION OF THE SWITCH. If you notice your clothes taking forever to
dry, visually check the position of the drier valve and see if it's
in the OPEN position with the red light on...This is how it work's on
my 93pt-40, your's might be different! Bob 93pt40
> GregoryO'Connor
> 94ptRomolandCa
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > OK, I'll bite. You don't have an aux air compressor that pre-
loads
> > your chassis air tanks, which is then used to power the dump
> valves?
> > That's the way my 91 works. I thought all the late 80s and up
had
> that??
> > Mike Bulriss
> > 1991 WB40 "Texas Minivan"
> > San Antonio, TX
> > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson
mention
> the
> especially
run
> a
> auxiliary
> will
> operate
> don't
> close
> on
> have
up'
> to
> > > do a dump.
> > > Pete Masterson
> > > aeonix1@
> > > El Sobrante, CA
> as
> > > > well as
if
> that
If
> you
> > > > get
> easily. If
new
> one in.
> > > > Terry Neal
> > > > Bozeman, MT
> > > > 82PT40 6V92TA
> > > > 74FC34 6V53T
> twist lock
> the
> > > >> Dupree
> glued in?
gate
> > > >> assembly?
> > > >> Thanks, Keith
02-28-2007, 04:02
Post: #26
Dump Valve Rebuild?
You just need to add an auxiliary compressor. My 92 coach came with
one and it is convenient. In an older BB I added a pancake compressor
that I purchased from Sears and it worked just fine. Just make sure
you go in before your spitter valve and filter.
> do a dump.
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > well as
> > get
> > Terry Neal
> > Bozeman, MT
> > 82PT40 6V92TA
> > 74FC34 6V53T
> >> Dupree
> >> assembly?
> >> Thanks, Keith
02-28-2007, 04:25
Post: #27
Dump Valve Rebuild?
Bob , Thanks. My floorplan also allow you to position the stool just
above the holding tank. The dryer vent info is good to know. I gave
up trying to dry in the washer/dryer now I know the problem.
Thanks
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`"
waste
is
red
to
on
toilet
> > GregoryO'Connor
> > 94ptRomolandCa
> loads
> > valves?
> had
> > that??
> > > Mike Bulriss
> > > San Antonio, TX
> mention
> > the
> > especially
> run
> > a
> > auxiliary
> > will
> > operate
> > don't
> > close
dump
> > on
> > have
> up'
> > to
> > > > do a dump.
> > > > Pete Masterson
> > > > aeonix1@
> > > > El Sobrante, CA
stock
> > as
> > > > > well as
valves
> if
> > that
adapter.
> If
> > you
> > > > > get
> > easily. If
> new
> > one in.
> > > > > Terry Neal
> > > > > Bozeman, MT
> > > > > 82PT40 6V92TA
> > > > > 74FC34 6V53T
> > twist lock
like
> > the
> > > > >> Dupree
bodies
> > glued in?
> gate
> > > > >> assembly?
> > > > >> Thanks, Keith
02-28-2007, 06:44
Post: #28
Dump Valve Rebuild?
_That's_ my question... can I? Is the Microphor compressor up to the
task?
Pete Masterson
aeonix1@...
El Sobrante, CA
> GregoryO'Connor
> 94ptRomolandCa
>> Don Bradner
>> Eureka, CA
> Yahoo! Groups Links
02-28-2007, 06:57
Post: #29
Dump Valve Rebuild?
Don,
Your electric Microphor has a nifty pushbutton rather than a handle,
right? I built the toilet surround cabinets and didn't have room for
the original handle.
FYI: Microphor makes both air and electric toilets for a reason; the
electric dumps straight down into the tank where the air assist is
designed to allow more freedom in the installation. It dumps into
a "hopper" then the valve closes and air pressure pushes the waste
from the hopper toward the tank through a 1 1/2" drain pipe. The air
model can be mounted several feet from the black tank. I've had both
and both have have always worked flawlessly. The electric has fewer
parts; I like that!
Rich D. '99LXi43' CT
> Don Bradner
> Eureka, CA
02-28-2007, 06:59
Post: #30
Dump Valve Rebuild?
Tom,
I think you have the 'deluxe' model. I only have the one Microphor
compressor.
I do have an "air compressor master" switch -- which is (and has
been) set "on" but it doesn't seem to do anything. (I don't know if
it's wired to the Microphor compressor or not as that would have
taken some time to check.)
Pete Masterson
aeonix1@...
El Sobrante, CA
On Feb 27, 2007, at 9:42 PM, Tom McCarthy wrote:
> Pete,
> service visit.
> Tom McCarthy
