Water pump problem
03-07-2007, 09:58
Water pump problem
The water pump in my coach stops suddenly and starts again within a
minute or less. Any ideas what may be causing it? Thanks Keith |
03-07-2007, 10:12
Water pump problem
Keith- you have a small water leak. I can't remember what coach you have, so if
you could sign your posts with that info, it will make it easier to narrow a problem down. Thanks Ernie Ekberg 83PT40 Livingston,Montana "POO-DOO-EXPRESS" ----- Original Message ----- From: Keith Strehle To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, March 07, 2007 2:58 PM Subject: [WanderlodgeForum] Water pump problem The water pump in my coach stops suddenly and starts again within a minute or less. Any ideas what may be causing it? Thanks Keith [Non-text portions of this message have been removed] |
03-07-2007, 10:20
Water pump problem
Keith,
If you are talking about this happening when you have a faucet open and water running then it is tripping the circuit breaker for some reason. The breakers do an auto reset. If it is when the pump is on but all faucets are off then there is a leak. This is usually in the fill valve or the water heater drain valve. Either one will let water from the pressure side flow back to the fresh water tank. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Keith Strehle Sent: Wednesday, March 07, 2007 3:58 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Water pump problem The water pump in my coach stops suddenly and starts again within a minute or less. Any ideas what may be causing it? Thanks Keith [Non-text portions of this message have been removed] |
03-07-2007, 10:22
Water pump problem
Sorry about that Ernie, I had the coach info set up to do it in
auto? Anyway, 84FCSB. It just stops, waits, and starts again? Keith 84FCSB --- In WanderlodgeForum@yahoogroups.com, > > Keith- you have a small water leak. I can't remember what coach you have, so if you could sign your posts with that info, it will make it easier to narrow a problem down. Thanks > Ernie Ekberg > 83PT40 > Livingston,Montana > "POO-DOO-EXPRESS" > ----- Original Message ----- > From: Keith Strehle > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, March 07, 2007 2:58 PM > Subject: [WanderlodgeForum] Water pump problem > > > The water pump in my coach stops suddenly and starts again within a > minute or less. Any ideas what may be causing it? > > Thanks Keith > > > > > > [Non-text portions of this message have been removed] > |
03-07-2007, 10:26
Water pump problem
It is when the faucet is open. It stops, then restarts. 12 volt
circuit breakers? Where would that be located? And what does it look like? Keith 84FCSB --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Keith, > > If you are talking about this happening when you have a faucet open and > water running then it is tripping the circuit breaker for some reason. The > breakers do an auto reset. If it is when the pump is on but all faucets are > off then there is a leak. This is usually in the fill valve or the water > heater drain valve. Either one will let water from the pressure side flow > back to the fresh water tank. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Keith Strehle > Sent: Wednesday, March 07, 2007 3:58 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Water pump problem > > > > The water pump in my coach stops suddenly and starts again within a > minute or less. Any ideas what may be causing it? > > Thanks Keith > > > > > > [Non-text portions of this message have been removed] > |
03-07-2007, 10:46
Water pump problem
The expansion tank may have lost its 'charge' of air. There's a tire-
valve nipple on the top that you can use to 'pump up' the pressure. Or the expansion tank may have had the diaphragm fail -- replacing the tank is the only solution then. Or, you might want to try the variable speed pump option -- replace your pump(s) and expansion tank with the Shurflow variable speed pump. Caution - this option will raise your coach water pressure to 65lbs when you're on the pump. Be sure your plumbing can handle it. There may be other reasons for the pump to act up as well.. possible overheating? Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 7, 2007, at 1:58 PM, Keith Strehle wrote: > The water pump in my coach stops suddenly and starts again within a > minute or less. Any ideas what may be causing it? > > Thanks Keith > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Something is new at Yahoo! Groups. Check out the enhanced email > design. > http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM > -------------------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
03-07-2007, 10:55
Water pump problem
Thanks Pete, I was wondering what the tank was for. That makes
perfect sense. How much pressure should I put in it? I also thought of overheating but the coach is very lightly used? Doesn't seem like the pump is worn out? Thanks, Keith 84FCSB --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > The expansion tank may have lost its 'charge' of air. There's a tire- > valve nipple on the top that you can use to 'pump up' the pressure. > Or the expansion tank may have had the diaphragm fail -- replacing > the tank is the only solution then. Or, you might want to try the > variable speed pump option -- replace your pump(s) and expansion tank > with the Shurflow variable speed pump. Caution - this option will > raise your coach water pressure to 65lbs when you're on the pump. Be > sure your plumbing can handle it. > > There may be other reasons for the pump to act up as well.. possible > overheating? > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Mar 7, 2007, at 1:58 PM, Keith Strehle wrote: > > > The water pump in my coach stops suddenly and starts again within a > > minute or less. Any ideas what may be causing it? > > > > Thanks Keith > > > > > > > > ------------------------ Yahoo! Groups Sponsor ------------------- - > > ~--> > > Something is new at Yahoo! Groups. Check out the enhanced email > > design. > > http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM > > ------------------------------------------------------------------ -- > > ~-> > > > > > > Yahoo! Groups Links > > > > > > > > > > [Non-text portions of this message have been removed] > |
03-07-2007, 11:04
Water pump problem
Keith- i wonder if your accumulator tank is working as it was designed. My pump
runs all the time- accumulator tank- shot. Ernie Ekberg 83PT40 Livingston,Montana "POO-DOO-EXPRESS" ----- Original Message ----- From: Keith Strehle To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, March 07, 2007 3:26 PM Subject: [WanderlodgeForum] Re: Water pump problem It is when the faucet is open. It stops, then restarts. 12 volt circuit breakers? Where would that be located? And what does it look like? Keith 84FCSB --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Keith, > > If you are talking about this happening when you have a faucet open and > water running then it is tripping the circuit breaker for some reason. The > breakers do an auto reset. If it is when the pump is on but all faucets are > off then there is a leak. This is usually in the fill valve or the water > heater drain valve. Either one will let water from the pressure side flow > back to the fresh water tank. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Keith Strehle > Sent: Wednesday, March 07, 2007 3:58 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Water pump problem > > > > The water pump in my coach stops suddenly and starts again within a > minute or less. Any ideas what may be causing it? > > Thanks Keith > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-07-2007, 11:43
Water pump problem
Ernie, is that the same as the expansion tank Pete mentioned. I do
remember fooling around with the schrader valve when I first got the bus. I don't remember if I had the problem before that or not? I'm going to pump some air ito it and see what happens. Keith San Diego 84FC --- In WanderlodgeForum@yahoogroups.com, > > Keith- i wonder if your accumulator tank is working as it was designed. My pump runs all the time- accumulator tank- shot. > Ernie Ekberg > 83PT40 > Livingston,Montana > "POO-DOO-EXPRESS" > ----- Original Message ----- > From: Keith Strehle > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, March 07, 2007 3:26 PM > Subject: [WanderlodgeForum] Re: Water pump problem > > > It is when the faucet is open. It stops, then restarts. 12 volt > circuit breakers? Where would that be located? And what does it > look like? > > Keith > 84FCSB > > --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > > > > Keith, > > > > If you are talking about this happening when you have a faucet open > and > > water running then it is tripping the circuit breaker for some > reason. The > > breakers do an auto reset. If it is when the pump is on but all > faucets are > > off then there is a leak. This is usually in the fill valve or the > water > > heater drain valve. Either one will let water from the pressure > side flow > > back to the fresh water tank. > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > _____ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Keith Strehle > > Sent: Wednesday, March 07, 2007 3:58 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Water pump problem > > > > > > > > The water pump in my coach stops suddenly and starts again within a > > minute or less. Any ideas what may be causing it? > > > > Thanks Keith > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
03-07-2007, 11:46
Water pump problem
The pump is pretty durable, but it may be partially clogged and/or
need a rebuild causing it to overheat. That might cause a circuit breaker to trip then reset. (Don't know where they are on your year.) I'd guess that the expansion tank would need about 40# as that's what the operating pressure is ... but it may be lower. The pressure in the tank allows the pump to run at a constant speed until the pressure in the system is "right". Then the tank provides the pressure until it drops to the point where the pump kicks on again. If the water pressure at a faucet isn't significantly changing as the pump cycles on-off-on, then the problem may not be the expansion tank at all. If the pump needs a rebuild, kits are available for a modest cost $20~30 or so. Most often, the pump will 'seep' at the joint in the case between the motor and the pump section if it needs a rebuild -- but perhaps not. If you find the circuit breakers, swap the one for the pump circuit for another one with a similar rating. It could be a faulty breaker instead of the pump, but that's not as likely. Even if it is the breaker tripping, you'll need to determine why the breaker trips. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 7, 2007, at 2:55 PM, Keith Strehle wrote: > Thanks Pete, I was wondering what the tank was for. That makes > perfect sense. How much pressure should I put in it? I also thought > of overheating but the coach is very lightly used? Doesn't seem like > the pump is worn out? > > Thanks, Keith > 84FCSB > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: >> >> The expansion tank may have lost its 'charge' of air. There's a > tire- >> valve nipple on the top that you can use to 'pump up' the > pressure. >> Or the expansion tank may have had the diaphragm fail -- replacing >> the tank is the only solution then. Or, you might want to try the >> variable speed pump option -- replace your pump(s) and expansion > tank >> with the Shurflow variable speed pump. Caution - this option will >> raise your coach water pressure to 65lbs when you're on the pump. > Be >> sure your plumbing can handle it. >> >> There may be other reasons for the pump to act up as well.. > possible >> overheating? >> >> Pete Masterson >> aeonix1@... >> '95 Blue Bird Wanderlodge WBDA 42' >> El Sobrante, CA >> >> >> >> >> On Mar 7, 2007, at 1:58 PM, Keith Strehle wrote: >> >>> The water pump in my coach stops suddenly and starts again within > a >>> minute or less. Any ideas what may be causing it? >>> >>> Thanks Keith >>> >>> >>> >>> ------------------------ Yahoo! Groups Sponsor ------------------- > - >>> ~--> >>> Something is new at Yahoo! Groups. Check out the enhanced email >>> design. >>> http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM >>> ------------------------------------------------------------------ > -- >>> ~-> >>> >>> >>> Yahoo! Groups Links >>> >>> >>> >> >> >> >> [Non-text portions of this message have been removed] >> > > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Something is new at Yahoo! Groups. Check out the enhanced email > design. > http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM > -------------------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
