Water pump problem
03-08-2007, 11:32
Post: #21
Water pump problem
It does seem a little excessive. I think I'll bleed it down and pump
it up in 5 psi increments to see where it behaves best. Keith San Diego 84FC --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > If my memory serves me correctly, I think that tank is supposed to be > pressurized to something like 10-15lb only. I don't have mine anymore, but there > is supposed to be a tag or label around the schraeder valve that gives the max > pressure it's supposed to have. I think 50 PSI is way high... > > Kevn McKeown > Yorba Linda, CA > 1986 38' PT > ************************************** AOL now offers free > email to everyone. Find out more about what's free from AOL at > http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
03-08-2007, 11:54
Post: #22
Water pump problem
One thing I can tell you from experience is that the auto-reset
breakers make a sound similar to a relay. If you hear that sound when the pump stops the breaker is likley tripping. It is possable that a previous owner added some additional equipment to the same breaker and both the pump and the new equipment are too much of a load. It seems odd that the pump would keep tripping a good breaker but continue to provide proper preasure when running. In the long run it is in your best interest to learn about the electrical systems in your bird. Little things like this can spoil an otherwise great trip. The more you know the easier it will be to diagnose and fix this kind of problem. Of course, the forum members are always ready to help out. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > If my memory serves me correctly, I think that tank is supposed to be > pressurized to something like 10-15lb only. I don't have mine anymore, but there > is supposed to be a tag or label around the schraeder valve that gives the max > pressure it's supposed to have. I think 50 PSI is way high... > > Kevn McKeown > Yorba Linda, CA > 1986 38' PT > ************************************** AOL now offers free > email to everyone. Find out more about what's free from AOL at > http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
03-08-2007, 13:24
Post: #23
Water pump problem
Keith,
The object is to inflate the bladder in the tank to 10 or 15lbs when there is no water preasure compressing it. Then when you build water preasure it will compress the bladder and thus compress the air raising the pressure in the bladder. Now when you open the fawcett the presure in the bladder will force the water out and give you a reserve before the pump needs to energize. If the bladder is pre-preasurized to 50lbs, you would need to build the water presure to 50lbs before the bladder began to compress. I hope this makes sense! Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > It does seem a little excessive. I think I'll bleed it down and pump > it up in 5 psi increments to see where it behaves best. > > Keith > San Diego > 84FC > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > If my memory serves me correctly, I think that tank is supposed to > be > > pressurized to something like 10-15lb only. I don't have mine > anymore, but there > > is supposed to be a tag or label around the schraeder valve that > gives the max > > pressure it's supposed to have. I think 50 PSI is way high... > > > > Kevn McKeown > > Yorba Linda, CA > > 1986 38' PT > > ************************************** AOL now > offers free > > email to everyone. Find out more about what's free from AOL at > > http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > |
03-08-2007, 16:50
Post: #24
Water pump problem
20 PSI works.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Keith Strehle wrote: > It does seem a little excessive. I think I'll bleed it down and pump > it up in 5 psi increments to see where it behaves best. > > Keith > San Diego > 84FC > > --- In WanderlodgeForum@yahoogroups.com > > > > > If my memory serves me correctly, I think that tank is supposed to > be > > pressurized to something like 10-15lb only. I don't have mine > anymore, but there > > is supposed to be a tag or label around the schraeder valve that > gives the max > > pressure it's supposed to have. I think 50 PSI is way high... > > > > Kevn McKeown > > Yorba Linda, CA > > 1986 38' PT > > ************************************** AOL now > offers free > > email to everyone. Find out more about what's free from AOL at > > http://www.aol.com. <http://www.aol.com.> > > > > > > [Non-text portions of this message have been removed] > > > > |
03-09-2007, 03:49
Post: #25
Water pump problem
Thanks Gardner, that makes perfect sense when you think of the
bladder acting as a diaphragm valve. I noticed that the power light stayed lit when the pump/water stopped this last time. I'm not sure that means there was still power to the pump. But it does lead me to believe it is more related to the expansion tank. Thanks to all of you for your help. Keith 84FC --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Keith, > The object is to inflate the bladder in the tank to 10 or 15lbs > when there is no water preasure compressing it. Then when you build > water preasure it will compress the bladder and thus compress the > air raising the pressure in the bladder. Now when you open the > fawcett the presure in the bladder will force the water out and give > you a reserve before the pump needs to energize. If the bladder is > pre-preasurized to 50lbs, you would need to build the water presure > to 50lbs before the bladder began to compress. > > I hope this makes sense! > > Gardner > 78FC33 > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > It does seem a little excessive. I think I'll bleed it down and > pump > > it up in 5 psi increments to see where it behaves best. > > > > Keith > > San Diego > > 84FC > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > If my memory serves me correctly, I think that tank is supposed > to > > be > > > pressurized to something like 10-15lb only. I don't have mine > > anymore, but there > > > is supposed to be a tag or label around the schraeder valve that > > gives the max > > > pressure it's supposed to have. I think 50 PSI is way high... > > > > > > Kevn McKeown > > > Yorba Linda, CA > > > 1986 38' PT > > > ************************************** AOL now > > offers free > > > email to everyone. Find out more about what's free from AOL at > > > http://www.aol.com. > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
