Towing Question
03-13-2007, 02:56
Towing Question
Hi All,
I'm A class C owner and I'm getting close to a purchase on a beautiful
87 PT38. Just one quick question for the group, are there any
GVWR/GCWR data on these coaches available? I'm sure they can pull a
bunch with a 8V92TA but I'd like to know the numbers if possible.
Thanks In Advance,
Jeff Hampton
03-13-2007, 05:12
Towing Question
Jeff,
I pull a 20', 7000# car hauler with no trouble. Sure, I can tell the difference
with and without the trailer but it pulls just fine.
Good luck.
Sent: Tuesday, March 13, 2007 6:56 AM
Subject: [WanderlodgeForum] Towing Question
Hi All,
Thanks In Advance,
Jeff Hampton
03-13-2007, 09:53
Towing Question
There should be a tag on the coach you are looking at that gives you that info.
My tag is under the overhead above the driver. You really have to crank the ole
neck around to read it.
I also pull a 7000# 20 ft trailer without any problems.
Leroy Eckert
1990WB-40"Smoke N Mirrors"
Niceville, FL
8v92 TAC 475hp DDEC II
Allison HT-755 5 speed
Sent: Tuesday, March 13, 2007 11:12 AM
Subject: Re: [WanderlodgeForum] Towing Question
Jeff,
difference with and without the trailer but it pulls just fine.
Good luck.
Hi All,
Thanks In Advance,
Jeff Hampton
03-13-2007, 20:11
Towing Question
My neck won't turn in that fashion so I just take a picture of those plates and
add them to the Blue Box.
Sent: Tuesday, March 13, 2007 1:53 PM
info. My tag is under the overhead above the driver. You really have to crank
the ole neck around to read it.
Leroy Eckert
Niceville, FL
To:
Jeff,
Good luck.
To:
WanderlodgeForum@yahoogroups.com to:WanderlodgeForum@yahoogroups.com>
Hi All,
Thanks In Advance,
Jeff Hampton
