Problem with propane
03-19-2007, 14:33
Hi Everyone, need a little help with my propane system. The last time
we used the Bird, everything worked great (stove and heater). Now we
are out on the road and no go (yes, lesson learned...check ALL systems
before you leave...even the "simple ones"). I checked to make sure the
tank is full. All valves are opened, nothing at the stove and heater
fan will run, but does not get hot.
Question: Is there anything electrical required to get the propane to
work? I found a couple of blown fuses, not sure what they are for
actually...any chance of them being related to this problem? I thought
the propane system was all mechanical.
Thanks for your help.
v/r
Wayne and Kimberlynn Curles
1984 PT-40
03-19-2007, 15:14
Here's a non-intuitive suggestion -- for the heat, make sure that the
AC master switches (by the driver) are turned ON.
Also, check the LP gas leak detector. If it senses LP gas it will
shut it off. Might also do that if it has no power or is defective. I
believe it is electrical -- so a blown fuse might affect it.
Pete Masterson
aeonix1@...
El Sobrante, CA
> the
> thought
> v/r
> 1984 PT-40
03-19-2007, 15:35
As well as the other suggestions, my electronic master switch shuts off, all
the propane ops as well as certain other systems.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Monday, March 19, 2007 7:33 PM
Subject: [WanderlodgeForum] Problem with propane
v/r
1984 PT-40
03-19-2007, 15:40
To add to Petes list, the 3 way refridg has an ignition key delay
hooked up to keep the amonia system pilot from sparking when the bus
is pitstopped for fuel. My 94pt has a 110 style light switch that
control a inline valve called "lp master" located below the sink.
this valve fails closed.
GregoryO'Connor
94ptRomolandCa
I
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
time
Now we
systems
sure
> > the
heater
propane to
> > thought
> > v/r
> > 1984 PT-40
03-19-2007, 15:51
Thanks guys, got it. It was the LP detector...such a newbie
mistake. At least I can have a warm dinner now. Thanks again.
v/r
Wayne C.
bus
> GregoryO'Connor
> 94ptRomolandCa
> the
will
defective.
> I
> > Pete Masterson
> > aeonix1@
> > El Sobrante, CA
last
> time
> Now we
> systems
> sure
> > > the
> heater
> propane to
for
I
> > > thought
> > > v/r
> > > 1984 PT-40
