Tachometer, AC outlets
04-22-2007, 04:58
My tach moves all over the scale when running at highway speeds.
What drives the tach on a 6V92.
Another problem was most of my AC outlets went dead while using my
drill motor I had the generator running. I have to assume the gen. was
putting out because the AC recepticle where the microwave is plugged
in was still hot. I checked breakers in the AC box that is located in
one of the wardrobe closets
In all the manuals I got, there is no diagram of the AC circuitry -
several diagrams of the DC.
Concerning my fresh water tank - on futher investigation I have no
leak. Water must have been spilled when filling at the vent.
Art Weatherly
Riverside Ca.
'85 PT 36
04-22-2007, 05:51
The built in vacs, I believe, were an option.
83PT40
Livingston, Mt
--central vac in mine
04-22-2007, 06:40
When your generator is running and working properly you should have 120v on leg
one and leg two gauges as you would if plugged into shore power. The associated
amp gauges tell you the usage on each leg. Is that the case?
There also are breakers on the box behind the gen set, at least there are on
mine.
Spend some time understanding what all the gauges in the coach tell you. When
you get that down it makes it easier to know where to start looking<<<<.>>>>
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Sunday, April 22, 2007 11:58 AM
Subject: [WanderlodgeForum] Tachometer, AC outlets
Art Weatherly
Riverside Ca.
'85 PT 36
04-22-2007, 06:56
One other thing I failed to mention. See if you have a GFI in the coach.
Reset it and see what happens. On my coach the bay outlets work on the gen set
and shore power, not the inverter. Sounds like you were using interior outlets?
Leroy Eckert
Niceville, FL
Are there any orange groves left in Riverside? I spent 25 years of my life
there.
Art Weatherly
Riverside Ca.
'85 PT 36
04-22-2007, 08:59
Reset both main breakers and that fixed it. They didn't look tripped.
Now if I could figure out where the built-in vacume cleaner is.
Art Weatherly
Riverside Ca.
'85 PT 36
Very few orange groves left in the inland area. There are now miles of groves
east of Bakersfield along HYW 46
Sent: Sunday, April 22, 2007 11:56 AM
Subject: [SPAM] Re: [WanderlodgeForum] Tachometer, AC outlets
One other thing I failed to mention. See if you have a GFI in the coach. Reset
it and see what happens. On my coach the bay outlets work on the gen set and
Leroy Eckert
Niceville, FL
there.
Art Weatherly
Riverside Ca.
'85 PT 36
04-22-2007, 09:12
Sent: Sunday, April 22, 2007 3:59 PM
Subject: Re: [SPAM] Re: [WanderlodgeForum] Tachometer, AC outlets
If yours is like mine it did not have one.
Bob Loomas 1985 PT 36
Art Weatherly
Riverside Ca.
'85 PT 36
Leroy Eckert
Niceville, FL
there.
Art Weatherly
Riverside Ca.
'85 PT 36
04-22-2007, 09:12
Wonder why it tripped with a drillmotor? Tripped circuits like blown
fuses are usualy a result and not a cause. If you rewire anything
remember the ground is not bonded to the common like is done at a
household panel
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Art Weatherly"
tripped.
> Art Weatherly
> Riverside Ca.
> '85 PT 36
of groves east of Bakersfield along HYW 46
> From: Leroy Eckert
coach. Reset it and see what happens. On my coach the bay outlets
work on the gen set and shore power, not the inverter. Sounds like
> Leroy Eckert
> Niceville, FL
of my life there.
> From: amweath
gen. was
plugged
located in
circuitry -
no
> Art Weatherly
> Riverside Ca.
> '85 PT 36
