PT cruise control
04-20-2007, 10:55
PT cruise control
I have made a deal to purchase a PT38, so if everything goes well, I
will have many questions as I move my learning curve from FC to PT.
First question: seller says cruise control is not operational, he does
not know why. Are there any common cruise problems that I should try
to troubleshoot once I get the coach?
Thanks
Scott Forman
82 FC35RB-for sale
Should have an 86 PT38 soon
04-20-2007, 11:03
PT cruise control
Check the Bosh relay that is located just under the Bendix control box.
This is located behind the grill on the curb side. The connectors there
will have a tendency to corrode and I have had that relay go bad in the
past. Also check the related wiring in the same area.
Safe travels,
84FC35
>Thanks
>Scott Forman
>82 FC35RB-for sale
06-03-2007, 14:07
PT cruise control
Ralph..."behind the grill on the curb side"...do you mean behind the
curb-side front exterior swing-out panel, the area in front of the co-
pilot seat? If so, I looked in there, did not see anything
electronic in there except the brain for The Horn. Help????
Scott
box.
there
> Safe travels,
> 84FC35
I
does
try
> >Thanks
> >Scott Forman
> >82 FC35RB-for sale
06-03-2007, 15:17
PT cruise control
Scott:
We are talking about the PT right? Then on the curb side rear, there is a
grill that lifts up for access to the side of the engine, batteries and so
forth. Open that grill and on a plate above the batteries there will be the
bendix control, a couple of valves, a cylinder with a cable housing.
It also may be behind a steel cover toward the fire wall but in the same
compartment. There should be a bosh relay in that same group of items.
Safe travels,
84FC35
Duncan, Oklahoma
>Scott
>box.
>there
>the
> > Safe travels,
> > 84FC35
>I
>does
>try
> > >Thanks
> > >Scott Forman
> > >82 FC35RB-for sale
06-03-2007, 23:57
PT cruise control
Gotcha...you can see my front-engine mentality, someone says "grill"
and I instinctively think of the front of the coach.
Thanks for the help
Scott
> Scott:
there is a
and so
will be the
same
items.
> Safe travels,
> 84FC35
> Duncan, Oklahoma
co-
> >Scott
control
> >box.
connectors
> >there
bad in
> >the
> > > Safe travels,
> > > 84FC35
well,
> >I
to PT.
he
> >does
should
> >try
> > > >Thanks
> > > >Scott Forman
> > > >82 FC35RB-for sale
06-23-2007, 11:10
PT cruise control
Scott- in the rear of the coach by the racor, is where my cruise control is
located. I had an air leak in one of the valves that was leaking. i took
that apart and cleaned it. After 4 years, she works great.
83PT40
Livingston, Mt
06-23-2007, 13:51
PT cruise control
OK...I replaces the relay and checked all the wiring, which all looks
fine, and still no dice. Any other suggestions?
Scott
box.
there
> Safe travels,
> 84FC35
I
does
try
> >Thanks
> >Scott Forman
> >82 FC35RB-for sale
06-24-2007, 12:34
PT cruise control
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
<sforman@...> wrote:
>Scott an air cylnder pulls the throttle. look at the fuel lever and
you will find a cable connected to it , it could be the cylinder is
froze or airis not geeting to the cylinder. This is how it is on
my '84 pt 40
re
> Scott
control
> box.
connectors
> there
in
> the
> > Safe travels,
> > 84FC35
well,
> I
PT.
he
> does
should
> try
> > >Thanks
> > >Scott Forman
> > >82 FC35RB-for sale
