Brake Adjusters
06-08-2007, 14:18
Brake Adjusters
Well I went a little to far with one of my brake tension adjusters on
my coach and have not been able to determine how to get it to back
off. When I try to turn the wrench the other way, it will not
budge.
How do you get the adjuster to back off?
Michael Brundridge
1992 WB40
Georgetown, TX
06-09-2007, 02:32
Brake Adjusters
Michael:
If I can remember correctly, push the wrench hard on the bolt, there is a
locking spring there, it should allow you to turn it.
Terrace, B.C. Canada
----- Original Message ----
Sent: Friday, June 8, 2007 7:18:37 PM
Subject: [WanderlodgeForum] Brake Adjusters
budge.
Michael Brundridge
1992 WB40
Georgetown, TX
Do You Yahoo!?
http://mail.yahoo.com
06-09-2007, 02:48
Brake Adjusters
Sent: Friday, June 08, 2007 9:18 PM
Michael Your coach is not equip with self slack adjusters?
Bob Loomas 1985 PT 36
budge.
Michael Brundridge
1992 WB40
Georgetown, TX
06-09-2007, 08:33
Brake Adjusters
Since it was built after 1990 it has Auto-Slack adjusters. Since I
had the wheels off I went ahead and adjusted them as if I had just
done a brake job. Tighten them down till they contact the drum and
then back them off 1/3 turn. They where adjusted fairly close, but
figured I would do it anyway.
Finially found the release pin, it was hidden on the back side where
I could not see it. Once I reached around back I found the release
pin and pulled it and was able to back it off 1/3 turn.
Michael Brundridge
1992 WB40
Georgetown, TX
--- In WanderlodgeForum@yahoogroups.com, "bloomas"
> From: mbrund
adjusters on
back
> budge.
> Michael Brundridge
> 1992 WB40
> Georgetown, TX
