Added external propane quick connector
06-10-2007, 08:11
What about a catalytic heater? Are those safe, as an alternative in our
coach? I'm sure that anything that has combustion emits CO2.
83PT40
Livingston, Mt
-with one heater turned off cause the fumes are bad
06-10-2007, 11:10
Added a quick connect fitting to the propane tank today so I can hook up outside
campstove.
Took the elbow going into the regulator and replaced it with a T, put a second
regulator
above the existing one with a quick connect hose fitting. Took about an hour
and about $20
in parts. I can also plug in a small propane heater, running the hose in thru a
window so
when dry camping I can get propane heat without the need for electricity if
necessary.
Kerry
82 Fc 35
Denver
06-10-2007, 11:26
Sent: Sunday, June 10, 2007 6:10 PM
Subject: [WanderlodgeForum] Added external propane quick connector
Yes and you can also kill you and your family from carbodioxide if the bird is
not properly ventilated.It is
your bird do with it you want.
Bob Loomas 1985 PT 36
outside campstove.
regulator
and about $20
a window so
necessary.
Kerry
82 Fc 35
Denver
06-10-2007, 11:45
Kerry,
A "small propane heater" inside your coach is a good way to make sure
you and your family never wake up from a winter's nap. Might want to
reconsider that idea....
Scott Forman
86 PT38
hook up outside campstove.
put a second regulator
about an hour and about $20
hose in thru a window so
electricity if necessary.
> Kerry
> 82 Fc 35
> Denver
06-10-2007, 12:18
Catalytic heater works. Leave a window cracked. We've used them for years.
Anaheim Hills, Calif.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
> http://www.aol.com. <http://www.aol.com.>
06-10-2007, 12:30
Aware of those issues. I have owned a motorhome with a non-forced air propane
heater
in the past and have been quite happy with it. The heater I have has an oxygen
depletion
sensor that automatically shuts it off if the oxygen level drops below a certain
point.
Kerry
82 FC 35
Denver
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote:
> Kerry,
> Scott Forman
> 86 PT38
> > Kerry
> > 82 Fc 35
> > Denver
06-10-2007, 12:31
Will do.
Kerry
82 FC 35
Denver
06-10-2007, 12:52
Kerry, I am not familiar with what type of heater you are talking
about. Is there an external exhaust? What happens if the oxygen
level sensor would fail? Please expand. I have used propane camp
style heaters in garage or tent type situations. I don't think I
would take a chance in a BB. I am also extremely sensitve to any
fumes at all. The only heater I use in my trailers and RV have been
the small electric heaters. Even these I would not leave unattended
do to potential fire risks. JEH
air propane heater
has an oxygen depletion
below a certain point.
> Kerry
> 82 FC 35
> Denver
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
> > Kerry,
sure
want to
> > Scott Forman
> > 86 PT38
can
T,
> > > Kerry
> > > 82 Fc 35
> > > Denver
06-10-2007, 14:08
--- In WanderlodgeForum@yahoogroups.com, "bloomas"
wrote:That would be Carbon monoxide.
Jim
> From: davidkerryedwards
if the bird is not properly ventilated.It is
> Kerry
> 82 Fc 35
> Denver
06-10-2007, 15:08
It was in a motorhome I owned in Europe. Never seen one in the US. No external
exhaust
that I was aware of. Can't remember the brand name. I keep a carbon monoxide
detector
in the motorhome so if the oxygen depletion sensor fails, the carbon monoxide
detector
would go off. I also open a window.
There is less combustion taking place in the propane heater than there is with
the stove
top burners or the oven.
Kerry
82 FC 35
Denver
