Generator not starting
06-19-2007, 00:05
For those of you who might be curious about my generator that would not
start I was able to find a solution at least temporarily. After checking and determining that 12 volt was coming to the electric pump during starter cranking but no fuel coming from the filter housing it was thought that a new pump was in order. After conferring with Power Tech they said any locally available pump that provided 4 to 11 PSI would work. Being a tightwad I decided to try tapping on the side of the pump with a metal object while my wife cranked the engine and to my surprise it started right up and has worked flawlessly since. Thanks to all who offered suggestions. Alvie Miller Arthur IL 1993 WLWB 15KW PowerTech Generator |
06-19-2007, 14:54
Yup,
My old hot rod tool kit seems to have fixed your problem. We used to keep a hammer and prophylactic in the tool kit. The premise being 'if you can't fix it, F%$#@ it' Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "whynotam" wrote: > > For those of you who might be curious about my generator that would not > start I was able to find a solution at least temporarily. After > checking and determining that 12 volt was coming to the electric pump > during starter cranking but no fuel coming from the filter housing it > was thought that a new pump was in order. After conferring with Power > Tech they said any locally available pump that provided 4 to 11 PSI > would work. Being a tightwad I decided to try tapping on the side of > the pump with a metal object while my wife cranked the engine and to my > surprise it started right up and has worked flawlessly since. Thanks to > all who offered suggestions. > > Alvie Miller > Arthur IL > 1993 WLWB > 15KW PowerTech Generator > |
06-19-2007, 16:06
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
wrote: > > Yup, > My old hot rod tool kit seems to have fixed your problem. We used > to keep a hammer and prophylactic in the tool kit. The premise > being 'if you can't fix it, F%$#@ it' > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, "whynotam" > wrote: > > > > For those of you who might be curious about my generator that > would not > > start I was able to find a solution at least temporarily. After > > checking and determining that 12 volt was coming to the electric > pump > > during starter cranking but no fuel coming from the filter housing > it > > was thought that a new pump was in order. After conferring with > Power > > Tech they said any locally available pump that provided 4 to 11 > PSI > > would work. Being a tightwad I decided to try tapping on the side > of > > the pump with a metal object while my wife cranked the engine and > to my > > surprise it started right up and has worked flawlessly since. > Thanks to > > all who offered suggestions. > > > > Alvie Miller > > Arthur IL > > 1993 WLWB > > 15KW PowerTech Generator One of heater stop working and with a little swift kick it started right up! Now that's how to fix something!!!!!!!!!!!!!!! > > > |
