Troubleshooting icemaker
07-03-2007, 09:02
My icemaker is getting cold and there's water in the line to the unit but no
water is flowing in
to the icemaker. Any troublshooting hints. I'm guessing it's the valve that
controls the flow
of the water. Anything else I should be looking at?
Kerry
82 FC 35
Denver
07-03-2007, 09:15
Kerry,
You say "getting cold"...let it run a while longer, to freezing, and
maybe the water valve will open.
Curt Sprenger
Anaheim Hills, Calif.
> but no water is flowing in
> that controls the flow
> Kerry
> 82 FC 35
> Denver
07-03-2007, 09:26
Is the water pump on? More than once I have made this mistake.
Scott Forman
86 PT38
Memphis
valve that controls the flow
> Kerry
> 82 FC 35
> Denver
07-03-2007, 09:35
Water pump is on. It hadn't occurred to me that the unit would only let water
in once a
freezing temperature was reached. I'll leave it on for a while. I took the
water valve apart
and it seems functional.
Kerry
82 FC 35
Denver
> Scott Forman
> 86 PT38
> Memphis
07-03-2007, 09:38
Kerry, the water inlet valve is controlled by a timer/solenoid. If you
don't have ice in a while (you can hear it hit the container) check to
make sure you have power to the solenoid. Mine sometimes has to set for
a while before it starts up again. Has to do with the eject step I
believe so that it completes a full cycle.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
> Scott Forman
> 86 PT38
> Memphis
> > Kerry
> > 82 FC 35
> > Denver
07-03-2007, 10:45
Kerry,
I am sure you looked, but I will ask anyway. Are you sure the pump
is on and has not turned itself off?
Al Johnson
'96 BMC B100
Mandeville, Louisiana
unit but no water is flowing in
> Kerry
> 82 FC 35
> Denver
07-03-2007, 12:50
Well I don't know if it was because I disassembled and reassembled the solenoid
valve or
because I let it run longer, but now it seems to be working.
Kerry
82 FC 35
Denver--at 100 degrees and glad to have ice.
--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote:
> Kerry,
> Curt Sprenger
07-03-2007, 13:08
That is dry heat, huh? Wanna trade locations? I can leave tomorrow. lol
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Today 90, Humidity 95% with T/S, no breeze except in T/S
Sent: Tuesday, July 03, 2007 7:50 PM
Subject: [WanderlodgeForum] Re: Troubleshooting icemaker
solenoid valve or
Kerry
82 FC 35
> Kerry,
> Curt Sprenger
