Air slow to pressure up
07-07-2007, 07:36
Drove my bus today for the first time in a couple weeks. I took a LONG
time for it to build initial air pressure...like maybe 20 minutes or more just to get to 90psi. Once on the road, everything was fine, it just took a long time initially. Hi idle didn't seem to help. Any idea what could cause this? Scott Forman 86 PT38 Memphis |
07-07-2007, 08:27
Check your air dryer and make sure the purge valve isn't leaking. You will
need to let the air completely down to check. The air pressure will tend to close it once it has built up. Run the pressure up to about 60 pounds then shut it off and check for leaks. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Saturday, July 07, 2007 2:37 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Air slow to pressure up Drove my bus today for the first time in a couple weeks. I took a LONG time for it to build initial air pressure...like maybe 20 minutes or more just to get to 90psi. Once on the road, everything was fine, it just took a long time initially. Hi idle didn't seem to help. Any idea what could cause this? Scott Forman 86 PT38 Memphis [Non-text portions of this message have been removed] |
