Sticky bedroom window
07-07-2007, 00:52
Thanks. The daynights are kinda tricky to remove. The regular window shades
come out easily. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: mohavewolfpup@...: Fri, 6 Jul 2007 11:13:43 -0700Subject: RE: [WanderlodgeForum] Sticky bedroom window Maybe take it out, and use the old "open a envelope you don't want yourparents to see?" trick? I'm not sure what they exactly look like/how theycome out not being a coach owner sadly, but I'm kinda guessing it looks likeit is rolled up and would rip if you tried to lower it? Pop them out, andhold over a decent steam source for a while to see if maybe that loosens theadhesive/soda/whatever and allows it to be spread out and cleaned perhaps?Dane_____ From: WanderlodgeForum@yahoogroups.com[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of brad bartonSent: Friday, July 06, 2007 11:06To: wanderlodgeforum@...: RE: [WanderlodgeForum] Sticky bedroom windowOn our LXi, I found out the night shades had hardly been used at all..verysticky..almost to the point of tearing. I'm not sure what to do other thanuse them. Any way to clean them without damage? Brad Barton 00LXiDFWbbartonwx@hotmail. portions of this message have been removed] _________________________________________________________________ Local listings, incredible imagery, and driving directions - all in one place! Find it! http://maps.live.com/?wip=69&FORM=MGAC01 [Non-text portions of this message have been removed] |
07-07-2007, 06:23
The passenger seat is on a rotating base -- we simply rotate it "in"
and my double duty "dining" and "office" chair is comfortable for sitting/reading. We don't use the forward TV and plan to remove it entirely at some point. We also don't do a lot of socializing -- inside the coach anyway -- so the lack of a "living room" is not a problem to us. Admittedly, others might not like this arrangement -- but it suits our lifestyle. One comment on the filing cabinets. We selected the top-of-the-line model that's very solidly made. While underway, they don't contribute (much) to the rattling, but it's important to lock the drawers so they don't open up on turns. They are bolted to a wooden platform (attached to the floor) that raises them about 6". This allows the AquaHot heat radiator to remain near its original location just behind the driver's area. (It had to be moved closer to the wall, but it was easy to move.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at On Jul 6, 2007, at 7:28 PM, Leroy Eckert wrote: > Very nice looking coach Pete. White makes it look larger than it > actually is. I can see why you would off the bedroom window > treatment. It might keep you awake at night. > Just wondering, with metal cabinets on the road side and a desk on > the other where are you folks going to sit? <snip> [Non-text portions of this message have been removed] |
07-08-2007, 10:24
On 7/6/07, Pete Masterson
> > The original bedroom window covering can be seen in photo > "95lxi4281", which is the 5th before the end of the thumbnails. Pete, I can't believe you got rid of this. If you put a couple of pink flamingos out in front of the bus wherever you parked, it would fit right in. Surely that would be a cheaper and easier solution... -Ryan '86 PT-40 8V92 Tri-Cities, WA |
07-09-2007, 08:58
Ryan,
You have no idea. A neighbor down the street and around a corner had an old pick-up truck that was long-term parked in front that was "decorated" with a couple of pink flamingos. Some fool complained about the "eyesore". While the truck was removed (various parking laws 'help' when complaints are made), the neighbor's response was to "decorate" their front yard with several dozen plastic pink flamingos -- and a "fence" of old brass bed head boards was put up. Frankly, the decorated truck was more attractive... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 8, 2007, at 3:24 PM, Ryan Wright wrote: > On 7/6/07, Pete Masterson >> >> The original bedroom window covering can be seen in photo >> "95lxi4281", which is the 5th before the end of the thumbnails. > > Pete, I can't believe you got rid of this. If you put a couple of pink > flamingos out in front of the bus wherever you parked, it would fit > right in. Surely that would be a cheaper and easier solution... > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA [Non-text portions of this message have been removed] |
07-09-2007, 10:21
LOL! Well, we all have different tastes, I suppose. It's usually best
not to push people with odd tastes, they often react unpredictably. I painted my house a deep blue and it doesn't exactly fit with one of my neighbor's vision of what a house should look like. I figure it's my house, there aren't any covenants and I like the color. So, to his mild whining, my answer was, "Keep it up and I'll have to paint the fence to match." He let it go. "Flamingo-ing" houses has become a popular thing in some areas. I've seen it several times around here. It seems to be a replacement for the toilet-papering of houses we used to do as kids: You go out and buy several dozen pink flamingos, then cover someone's yard in them under cover of darkness. It's quite a sight. -Ryan On 7/9/07, Pete Masterson > > Ryan, > > You have no idea. A neighbor down the street and around a corner had > an old pick-up truck that was long-term parked in front that was > "decorated" with a couple of pink flamingos. Some fool complained > about the "eyesore". While the truck was removed (various parking > laws 'help' when complaints are made), the neighbor's response was to > "decorate" their front yard with several dozen plastic pink flamingos > -- and a "fence" of old brass bed head boards was put up. Frankly, > the decorated truck was more attractive... > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... |
07-09-2007, 23:42
On Mon, 9 Jul 2007 15:21:24 -0700, you wrote:
>"Flamingo-ing" houses has become a popular thing in some areas. I've >seen it several times around here. It seems to be a replacement for >the toilet-papering of houses we used to do as kids: You go out and >buy several dozen pink flamingos, then cover someone's yard in them >under cover of darkness. It's quite a sight. > >-Ryan > Rainbow Girls in our area often use activity this as a fund raiser. 1) You can buy a "Contract" on someone to have their home "Flamingo-ed". 2) You can buy "Insurance" to prevent it from happening. About $10 either way. -- Fraternal Regards, Peter T. Arnold Worthy Patron, Temple Chapter #53 {3rd Time} Hartford Evergreen Lodge #88 Past Master Meets on 1st and 3rd Mondays Washington Lodge #70, Past Master 1997 2nd and 4th Monday Yahoo 6th District B.L.C. Newsgroup Co-Moderator Past A.G.M., Masonic District 6B Grand Lodge of Connecticut A.F. & A.M. As you can see, I'm busy on Mondays! |
