Temp Readings
05-05-2005, 15:41
Temp Readings
I was exercising the bird and my water temp was running 190-200 which didn't
concern me but the oil temp was running 290-300 and that concerns me. Altho I
haven't checked or changed the oil sending unit yet and I know the guages aren't
necessarily accurate as they haven't been calibrated to my knowledge. I had also
stopped and cracked & opened the radatior cap without a problem while it was
warm so I know the water was OK. I also plan on testing the antifreeze for
cooling and ph properties. Any other thoughts b4 I start digging into things?
Mark, 80FC35 in PA for awhile
Do you Yahoo!?
Yahoo! Sports - Sign up for Fantasy Baseball.
05-06-2005, 02:26
Temp Readings
Seems to me I remember something about oil coolers going bad on
3208s, can't remember for sure though (long time ago).
I suppose if you were to replace the hoses on the oil cooler anyway,
you could check water flow through it.
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, Mark Garber
which didn't concern me but the oil temp was running 290-300 and that
concerns me. Altho I haven't checked or changed the oil sending unit
yet and I know the guages aren't necessarily accurate as they haven't
been calibrated to my knowledge. I had also stopped and cracked &
opened the radatior cap without a problem while it was warm so I know
the water was OK. I also plan on testing the antifreeze for cooling
> Do you Yahoo!?
05-06-2005, 04:08
Temp Readings
Ty for your reply and your contributions to the continuing sucess of many
peoples Bird ownership.
Mark
- Jeff Miller
Yahoo! Mail Mobile
Take Yahoo! Mail with you! Check email on your mobile phone.
