Red Light Switch?
08-15-2007, 09:36
Red Light Switch?
Hey all, there is a red light switch behind the drivers seat on my
84FC35. What does it control? Thanks, Keith 84FC35 |
08-15-2007, 10:02
Red Light Switch?
Electric battery heaters.
Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > Hey all, there is a red light switch behind the drivers seat on my > 84FC35. What does it control? > > Thanks, Keith > 84FC35 > |
08-15-2007, 10:08
Red Light Switch?
Block Heater(s).
- Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Keith Strehle Sent: Wednesday, August 15, 2007 4:36 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Red Light Switch? Hey all, there is a red light switch behind the drivers seat on my 84FC35. What does it control? Thanks, Keith 84FC35 [Non-text portions of this message have been removed] |
08-15-2007, 10:19
Red Light Switch?
Yep, I believe you're right. Not that I'll ever use them here in San
Diego. But you never know when I might end up in the cold country. Thanks for the info. Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Electric battery heaters. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Hey all, there is a red light switch behind the drivers seat on my > > 84FC35. What does it control? > > > > Thanks, Keith > > 84FC35 > > > |
08-15-2007, 11:42
Red Light Switch?
Keith, Should be for the battery heaters, if they are still connected and or
functional. Keith Strehle Hey all, there is a red light switch behind the drivers seat on my 84FC35. What does it control? Thanks, Keith 84FC35 Doug Engel, Gunnison, CO. Bird Usta Be, now 1990 Thomas Skoolie, "Hormone Derange" --------------------------------- Shape Yahoo! in your own image. Join our Network Research Panel today! [Non-text portions of this message have been removed] |
08-15-2007, 12:04
Red Light Switch?
Might be the engine heater -- used to help with cold weather starts.
Run it 24 to 36 hours before the planned start. I also have a red switch under the kitchen sink that operates the "Konstant hot" water heater. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 15, 2007, at 2:36 PM, Keith Strehle wrote: > Hey all, there is a red light switch behind the drivers seat on my > 84FC35. What does it control? > > Thanks, Keith > 84FC35 [Non-text portions of this message have been removed] |
08-15-2007, 13:21
Red Light Switch?
Block heater switch on FC is at passenger's toes.
Scott --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Might be the engine heater -- used to help with cold weather starts. > Run it 24 to 36 hours before the planned start. I also have a red > switch under the kitchen sink that operates the "Konstant hot" water > heater. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Aug 15, 2007, at 2:36 PM, Keith Strehle wrote: > > > Hey all, there is a red light switch behind the drivers seat on my > > 84FC35. What does it control? > > > > Thanks, Keith > > 84FC35 > > > > [Non-text portions of this message have been removed] > |
08-15-2007, 15:43
Red Light Switch?
This is probably like every thing else and varies from bird to bird. The
switch behind the driver's seat on our bird is a double pole switch, on two separate circuits, that powers two freeze plug block heaters on either side of the 3208. The switch by the passenger's feet controls a tank type block heater. Maybe that is why our FC31 came with a 12.5kw generator! - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Wednesday, August 15, 2007 8:22 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Red Light Switch? Block heater switch on FC is at passenger's toes. Scott --- In WanderlodgeForum@ yahoogroups.com, Pete Masterson wrote: > > Might be the engine heater -- used to help with cold weather starts. > Run it 24 to 36 hours before the planned start. I also have a red > switch under the kitchen sink that operates the "Konstant hot" water > heater. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Aug 15, 2007, at 2:36 PM, Keith Strehle wrote: > > > Hey all, there is a red light switch behind the drivers seat on my > > 84FC35. What does it control? > > > > Thanks, Keith > > 84FC35 > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
