Toilet emergency...Help!
08-31-2007, 09:49
Hi Juergen Mine has a shut off in the vanity for the toilet. There
is a sprayer under the vanity that has a door that drops down on the street
side that has a shut off in the copper line that goes to the toilet.It is hard
to see because it is behind some other plumbing. Does yours have that sprayer
& the drop down door in the vanity?
Don
89 SP 36'
Butler, PA
Howard hit the nail on the head. I had the same problem with my toilet
years ago. Several times actually. Each time it was a piece of built
up calcium in the water shut off solenoid. I installed a water
shut-off valve right behind the toilet and a electric shut-off switch
next to it. Also put an inline filter screen between the shut-off and
toilet inlet. Havn't had a problem since. BB dropped the ball indeed,
by not having an accessable shut-off. My original one is under the
kitchen sink behind some panels that have to unscrewed, its hard to
find, you need a flashlight, and if you forgot to shut off the pump,
or hooked to external water supply, you just might drown in your own
coach. Thanks,BB,..coach
Juergen in PA
1991 WLSP36
_Messages in this topic _
(http://groups.yahoo.com/group/Wanderlodg...ajRlN\
zkxBF9TAzk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSW
QDMTcwNTEyNjE4NQRtc2dJZAMyNzM2OQRzZWMDZnRyBHNsawN2dHBjBHN0aW1lAzExODg2MDkxNDIE
dHBjSWQDMjczNjA-) (0) _Reply (via web post) _
(http://groups.yahoo.com/group/Wanderlodg...F9TAz\
BGdycHNwSWQDMTcwNTEyNjE4NQRtc2dJZAMyNzM2OQRzZWMDZnRyBHNsawNycGx5BHN0aW1lAzExOD
g2MDkxNDI-?act=reply&messageNum=27369) | _Start a new topic _
k3MzU5NzE0BGd
ycElkAzE0ODE1NTE4BGdycHNwSWQDMTcwNTEyNjE4NQRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzExO
Dg2MDkxNDI-)
_Messages_
(http://groups.yahoo.com/group/Wanderlodg...WJiBF\
9TAzk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSWQDMTcwNTEyNjE4NQRzZWM
DZnRyBHNsawNtc2dzBHN0aW1lAzExODg2MDkxNDI-) | _Files_
(http://groups.yahoo.com/group/Wanderlodg...BF9TA\
E0ODE1NTE4BGdycHNwSWQDMTcwNTEyNjE4NQRzZWMDZnRyBHNsawNmaWxlcwRzdGltZQMxMTg4NjA5
MTQy) | _Photos_
(http://groups.yahoo.com/group/Wanderlodg...1BF9T\
QRzZWMDZnRyBHNsawNwaG90BHN0aW1lAzExODg2MDkxNDI-)
08-31-2007, 11:16
I am at a Football tailgate, and my toilet will not quit filling. I
have the original toilet, and don't even know how to take it apart to
look at anything. Any suggestions? I am having to keep my water pump
off now, and it is quite inconvenient & will create a challenge for
taking showers tomorrow morning.
Help!
Scott Forman
86 PT38
Memphis
08-31-2007, 11:22
Not familiar with your original toilet, but if you trace back the water line,
there should be a
toilet shut off valve somewhere.
Kerry
82 FC 35
Denver
> Help!
> Scott Forman
> 86 PT38
> Memphis
08-31-2007, 11:29
Scott,
I emailed you a couple manual. I'm assuming you have the air toilet, same as
our 1987 PT38.
> Help!
> Scott Forman
> 86 PT38
> Memphis
Curt Sprenger
Anaheim Hills, CA
08-31-2007, 11:31
Scott,
I got a "out of the office" message back. Do you want the manuals sent to
another email address?
On 8/31/07, Curt Sprenger wrote:
> Scott,
> as our 1987 PT38.
> > Help!
> > Scott Forman
> > 86 PT38
> > Memphis
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
08-31-2007, 11:32
Thanks, that very obvious solution I didn't think of has solved the
problem for now. However, I will still need instructions of how to
fix, if anyone has insight..
Scott
water line, there should be a
> Kerry
> 82 FC 35
> Denver
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
filling. I
apart to
pump
for
> > Help!
> > Scott Forman
> > 86 PT38
> > Memphis
08-31-2007, 11:39
As with most things, we can only talk about our own coaches and hope yours might
be the same. I have an electric Microphor, and the shutoff is in the wall behind
it. I've only had occasion to use it when removing the toilet to remove the
black tank, but I THINK I could possibly get at it without removing the toilet.
When the top is off the back of the toilet, there is a fairly good-sized opening
in the back of the toilet where wiring and water come in. The valve is visible
back there.
The troubleshooting in the microphor manual at
http://www.microphor.com/pdf/LF-220_Manual.pdf says "Water continues to
run. Obstruction in water Solenoid Valve. Remove and inspect Solenoid Valve -
see Solenoid Valve Cleaning" The latter section says:
1 Disconnect the power by removing the two blue wires from the solenoid.
2 Disconnect the water supply line at china end.
3 Remove two screws securing the solenoid to the mounting bracket.
4 Pull solenoid away from the Vacuum Breaker.
5 Remove water supply tube.
6 Remove four (4) screws from Solenoid Valve Body and remove spring and
diaphragm.
7 Clean holes in the diaphragm if clogged. Inspect solenoid for debris and
clean. Reassemble in reverse order.
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
>Help!
>Scott Forman
>86 PT38
>Memphis
08-31-2007, 12:09
Scott,
I had mine start leaking at RIV last year. I replaced the old OE toilet with a
new china one and put in a cut off valve while doing the change. You might want
to add a cut off valve tomorrow to get you through the weekend. I was
dumbfounded that BB did not have a cut off on the toilet. When you consider all
the other redundant items on the coach someone dropped the ball.
Howard T., Sowega, 86 PT40
Sent: Friday, August 31, 2007 7:16 PM
Subject: [WanderlodgeForum] Toilet emergency...Help!
Help!
Scott Forman
86 PT38
Memphis
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007
4:29 PM
08-31-2007, 13:12
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Scott,
coach. Thanks,BB,.......
Juergen in PA
1991 WLSP36
09-01-2007, 13:00
Curt,
I'll just get it Tuesday, but I don't have an air toilet anyway, it's
a normal Thetford
Scott
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Scott,
sent to
> > Scott,
toilet, same
> > as our 1987 PT38.
filling. I
apart to
pump
for
> > > Help!
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> > Curt Sprenger
> > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
