Safe Combo
05-06-2005, 02:25
Safe Combo
Thanks for all the help guys! I was informed last night by a member that the
numbers I found were probably mt coach #'s, not a safe combo. Since I'm on
the road now, I don't think I'll remove it or have it drilled so it will
have to sit there and just look cool for now. Thanks for all the advice!
Al
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Kurt Achenbach
Sent: Friday, May 06, 2005 7:15 AM
Subject: [WanderlodgeForum] Re: Safe Combo
Hello Al,
Just had my Safe serviced and reset.
The Combination is (usualy)
Left 4 turns to # ?
Right 3 turns to # ?
left 2 turns to # ?
Right 1 turn to STOP
Kurt
83FC35SB in NH
--- In WanderlodgeForum@yahoogroups.com, "Al here" wrote:
> I tried the message archieve but it wouldn't work for me, so I
thought I
> would try you guys.
> My safe combo has been changed from the original factory setting as
per 2
> different locksmiths. They would have drilled it but since I assume
it's
> empty and there are no replacement parts, I didn't see the point in
ruining
> a great safe. I was going to hid a new one somewhere until I found
these
> #'s under the couch seats covering the safe (shhhh, don't tell
anyone).
> 50 452
> Not really having used dial safes in the past I don't know the
proper order
> of spins and what direction to start turning. Anyone have any
advice?
> Al S.
> 1981 31' FC
> _____
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3
> Sent: Thursday, May 05, 2005 5:37 PM
> Subject: [WanderlodgeForum] Re: Headlight switch
> Hi Sid,
> I just replaced mine with one from Blue Bird. Was around $100 or
> so... like everything else. Brand was "ohmite". Was pretty easy to
> get to. New one works beautifully. Could not find a match at any
> auto parts stores, but did not try a "good" NAPA (the one here in
> Hershey is pretty sad) I can walk you throught the removal and
> installation if needed.
> Shane Fedeli
> 85PT40
> Hershey, PA
> --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese"
> <ssbreese@a...> wrote:
> > Well, I think my switch has bit the dust. Some time ago I wrote
> that
> > the switch did not work in the parking position, but the headlight
> > came on, but the tail lights didn't. Someone suggested WD40 and
> that
> > worked for a while. Doesn't work this time. I have headlights,
> but
> > no marker or tailights. Does anyone know the brand or model of
> > switch. I went to a couple of parts stores and the said I needed
> to
> > bring the old one in and they would match it. Everything is
> working
> > fine and I am not thinking of night driving, so I hate to take the
> > dash apart to get at the switch. Hoping someone has a model
> number.
> > thanks.
> > Sid Breese
> > 85PT40
> > St. Joseph, MO
> _____
> Yahoo! Groups Links
> http://groups.yahoo.com/group/WanderlodgeForum/
> subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo!
> <http://docs.yahoo.com/info/terms/> Terms of Service.
_____
Yahoo! Groups Links
05-06-2005, 02:33
Safe Combo
my first thought would be to try it as 50 4 52, then maybe 50 45 2, or 50 45
20
good luck
Mark 80FC35 PA for awhile
pattypape wrote:
Hi AL,
My Safe needs six numbers in the combination to open.
You may be missing a digit.
Example is; 25 35 45
Bill 88 FC
thought I
> would try you guys.
per 2
it's
ruining
these
anyone).
> 50 452
proper order
advice?
> Al S.
> 1981 31' FC
> _____
> Hi Sid,
> Shane Fedeli
> 85PT40
> Hershey, PA
> that
> that
> but
> to
> working
> number.
> > thanks.
> > Sid Breese
> > 85PT40
> > St. Joseph, MO
> _____
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Mail
Stay connected, organized, and protected. Take the tour
05-06-2005, 10:05
Safe Combo
Opps! Sorry Hank, that you received a copy of my response.
I was responding to the subject: Safe Combo.
See attached postings, I think Al got the message.
Bill 88FC Michigan
--- In WanderlodgeForum@yahoogroups.com, hank robb
> I'M NOT AL. CHECK YOUR SEND ADDRESS. HATE TO SEE AL
> MISS A MESSAAGE.
> SINCERELY,
> HANK HANNIGAN
> 90SP36
> SYDNEY AUSTRALIA FOR NOW
> --- pattypape wrote:
> > Hi AL,
> > open.
> > Bill 88 FC
> > for me, so I
> > thought I
> > > would try you guys.
> > factory setting as
> > per 2
> > but since I assume
> > it's
> > see the point in
> > ruining
> > these
> > (shhhh, don't tell
> > anyone).
> > > 50 452
> > don't know the
> > proper order
> > Anyone have any
> > advice?
> > > Al S.
> > > 1981 31' FC
> > > _____
> > Behalf Of sfedeli3
> > > Hi Sid,
> > Was around $100 or
> > Was pretty easy to
> > a match at any
> > (the one here in
> > removal and
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
> > Breese"
> > time ago I wrote
> > > that
> > but the headlight
> > suggested WD40 and
> > > that
> > have headlights,
> > > but
> > brand or model of
> > the
> > the said I needed
> > > to
> > Everything is
> > > working
> > I hate to take the
> > has a model
> > > number.
> > > > thanks.
> > > > Sid Breese
> > > > 85PT40
> > > > St. Joseph, MO
> > > _____
> > > Yahoo! Groups Links
> > to:
> > Yahoo!
> > Service.
> > removed]
> __________________________________
> Do you Yahoo!?
> Read only the mail you want - Yahoo! Mail SpamGuard.
> http://promotions.yahoo.com/new_mail
05-07-2005, 10:09
Safe Combo
why didn't you have the locksmith come to the BB????????
05-07-2005, 15:18
Safe Combo
I did, two of them. The combo has been changed and there are no replacement
parts. So when they drilled the safe, it would have been destroyed. I think
it was Jeff that pointed out they could drill it from the side so it can
still be used. Didn't know that when they came by.
Al S.
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of dwalks@...
Sent: Saturday, May 07, 2005 7:09 PM
Subject: Re: [WanderlodgeForum] Re: Safe Combo
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
<http://docs.yahoo.com/info/terms/> of Service.
