Problems with air dumping
10-17-2007, 04:54
Just an update here in Yakima, Washington.
I have had problems dumping the tag and main suspension dump valves.
Others on this site have had this problem and nobody has a solution yet.
Emailed Ralph and he had me look behind the front frame rail straight
up. There is a manifold there with lines going to the various air bags
and, I'm assuming, the suspension dump buzzer switch.
My problem is, no air is getting up to the switches to tell the bags to
dump.
At present I am here in Yakima at a place (5th Wheel Truck) that has
worked on other birds. They tried to get an air schmatic faxed from
Bluebird to give them some direction...people don't get back to them.
Pat here is very knowledgeable on this stuff and I hope the problem
gets resolved quickly as we have to get back to Lakewood for the wife's
last week of working for the state before we take off fulltiming next
week.
Bob Lawrence
84 PT36
Taco ma, Wa. (where the illegals roam)
10-17-2007, 07:28
Bob,
Just sent you a very large PDF with drawings from my 1993 to see if it will
help. Let me know if they don't make it.
Steve Quandt
Iron Mountain, MI
1993 PT-40
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Bob Lawrence
Sent: Wednesday, October 17, 2007 11:54 AM
Subject: [WanderlodgeForum] Problems with air dumping
dump.
week.
Bob Lawrence
84 PT36
10-17-2007, 11:57
First want to thank Steve and Ralph who send me files of the various
air systems....thanks again, guys..will print them off for others we
meet on our travels that might have similar problems.
I found the solution to my problem.
Turns out the air switches are/were the problem. Pulled them out and
found that these valves have many mini o rings. Seems they fall apart
with age and the small pieces jam the air holes.
Replaced them with new and bigger air switches...problem solved.
Bus now dumps quicker and fills quicker as went to 1/4 in size
openings.
Thanks again to Steve and Ralph.
I know several have mentioned they have this occasional problem and I
think this is the reason.
Bob Lawrence
84 PT36
Tacoma, Wa.
yet.
straight
bags
bags to dump.
has
them.
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
10-19-2007, 04:12
Bob,
Can you provide the part number of the valve(s) you used to replace
the orginal equipment? I also have a randomly sticking dump valve.
Thanks,
Glenn Allen
1986 PT-40
Marietta, GA
various
we
apart
> openings.
I
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
valves.
solution
> yet.
> straight
> bags
> bags to dump.
> has
from
> them.
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
10-19-2007, 06:39
Glenn,
Check with Stephen Birtles he now produces the Dupree line of dump valves.
Stephen said he would have a booth at the RIV and RATS rallies and would have
parts for repairs. I found that using mine regularly has helped with it
sticking.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Friday, October 19, 2007 12:12 PM
Subject: [WanderlodgeForum] Re: Problems with air dumping
Bob,
Thanks,
Glenn Allen
1986 PT-40
Marietta, GA
various
we
apart
> openings.
I
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
valves.
solution
> yet.
> straight
> bags
> bags to dump.
> has
from
> them.
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.15.1/1079 - Release Date: 10/19/2007
5:10 AM
10-19-2007, 15:37
Hi Glenn,
Sorry, on the bill, no part no. was put, but if you call Pat at 5th
Wheel Truck Repair 509-248-3070 I'm sure he can tell you.
He just said this was a regular air dump switch used on all current
trucks.
Bob Lawrence
84 PT36
Tacoma, Wa.
> Bob,
> Thanks,
> Glenn Allen
> 1986 PT-40
> Marietta, GA
> various
> we
> and
> apart
> > openings.
> I
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
> valves.
> solution
> > yet.
> > straight
air
> > bags
> > bags to dump.
that
> > has
> from
> > them.
> > > Bob Lawrence
> > > 84 PT36
> > > Tacoma, Wa.
10-19-2007, 17:05
Howard,
I must be out of sync. I thought Bob was talking about the
I recently replaced by Holding Tanks Dump valves with new ones from
Steve and they work great.
Thanks,
Glenn
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Glenn,
valves. Stephen said he would have a booth at the RIV and RATS
rallies and would have parts for repairs. I found that using mine
regularly has helped with it sticking.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: ragster_ga
> Bob,
replace
> Thanks,
> Glenn Allen
> 1986 PT-40
> Marietta, GA
> various
others
> we
out
> and
> apart
> > openings.
> I
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
10-20-2007, 02:12
Glenn,
I think you could be right. When I read dump valves I automaticly thought of
holding tanks. Don't suppose Stephen has air dump valves also?
Howard T.
Sent: Saturday, October 20, 2007 1:05 AM
Howard,
Thanks,
Glenn
> Glenn,
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: ragster_ga
> Bob,
replace
> Thanks,
> Glenn Allen
> 1986 PT-40
> Marietta, GA
> various
others
> we
out
> and
> apart
> > openings.
> I
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
5:10 AM
10-20-2007, 02:24
I believe Stephen has all the parts for the dump valves both air and manual.
That would include everything from replacement valve paddles to handles,
valve bodies as well as air cylinders.
On 20/10/2007, Howard O. Truitt wrote:
> Glenn,
> of holding tanks. Don't suppose Stephen has air dump valves also?
> Howard T.
> From: ragster_ga
> Howard,
> Thanks,
> Glenn
> "Howard O. Truitt"
> > Glenn,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> > From: ragster_ga
> > Bob,
> replace
> > Thanks,
> > Glenn Allen
> > 1986 PT-40
> > Marietta, GA
> "Bob Lawrence"
> > various
> others
> > we
> out
> > and
> > apart
> > > openings.
> and
> > I
> > > Bob Lawrence
> > > 84 PT36
> > > Tacoma, Wa.
> 10/19/2007 5:10 AM
Rob, Sue & Merlin Robinson
94 WLWB
10-20-2007, 05:15
Rob, Dupree dump valves are good for crap'.
they are talking about dump valves for air bags and I believe it is
a sticking 'regulator isolation valve' that limits auxillary air use
during low system pressure that is the problem.
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
and manual.
handles,
> > Glenn,
thought
> > Howard T.
> > From: ragster_ga
> > To: WanderlodgeForum@yahoogroups.com 40yahoogroups.com>
> > Howard,
from
> > Thanks,
> > Glenn
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Howard O. Truitt"
> > wrote:
> > > Glenn,
dump
> > > Howard Truitt
> > > Camilla, Ga.
> > > 86 PT40
> > > From: ragster_ga
> > > Bob,
> > replace
valve.
> > > Thanks,
> > > Glenn Allen
> > > 1986 PT-40
> > > Marietta, GA
> > "Bob Lawrence"
> > > various
> > others
> > > we
> > out
> > > and
fall
> > > apart
solved.
> > > > openings.
problem
> > and
> > > I
> > > > Bob Lawrence
> > > > 84 PT36
> > > > Tacoma, Wa.
> > 10/19/2007 5:10 AM
> 94 WLWB
