Driving lights -operation?
10-21-2007, 11:18
Tom, I have the same configuration, although without the fog in Texas. I look
forward to learning what you come up with. Tom McCarthy Lights." From this information, the two apparently are mutually exclusive. I rarely need high beams but often get nighttime fog in CA. I asked HMH if they could switch the operation to FOG and low beams, just like my fleet of autos. Tommy 2S McCarthy Poway CA --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" wrote: > > Tommy my lights are fog lights and they only come on if I have my main > lights on and set to low beam. My manual says that if I had driving lights > in place of the fog lights the driving lights would only come on with the > main lights on and high beam setting. > > On 21/10/2007, Tom McCarthy wrote: > > > > Coincidently, I was checking all the lights the other night. I tried > > the Fog/Driving light switch. Nothing. At Holland Motor Homes, I > > asked them to chek the bulbs and/or power. They said the Fog/driving > > lights came on with HIGH beams! Why would anyone want these lights > > meant for fog on when high beams do not work well in fog? > > > > Just to see what cars do, I checked all I had. All makes, years and > > models worked only on low beams and never on high. Those include '07 > > BMW X3, '01 BMW, '06 Mini Cooper, '07 Astin Martin. > > > > Now I read you guys saying yours only come on with high beams, too. > > Why? I thought somebody reversed mine at some point. What is the > > logic, or lack thereof, in this setup? > > > > Tommy 2 Shoes McCarthy > > 95 PT42 > > Poway CA > > > > --- In WanderlodgeForum@yahoogroups.com40yahoogroups.com>, > > "Curt Sprenger" > > wrote: > > > > > > Tom, > > > > > > Here are some notes that I saved some time ago. Hope this helps. > > Please keep > > > us posting on your project. > > > > > > First note: > > > Alan there is a switch that the light has to touch to turn the > > light on. The > > > > > > light can be adjusted to hit it. If the cylinder is bad it is a > > Clippard. > > > Mine is an SDR-20-3 & I got two new ones for sixty dollars for > > both. That > > > made > > > mine work fine after I adjusted them to come the whole way down. I > > don't > > > think you can repair them. > > > Don > > > 89 SP 36' > > > Butler, PA > > > > > > Second note: > > > These lights to operate. > > > Dash Switch ON > > > Headlights Must be on > > > High beam must be on > > > Coach must be at ride hieght. > > > > > > If The lights won't lower check micro switches mouted on light > > > brackests. > > > Air control valves are under the front electricial panel. > > > And of course last of all the air cylinders. > > > The bulbs are replaceable, as for as the lens???? > > > Good Luck > > > Allen Powell > > > 88 WLWB PT40 > > > > > > > > > On 10/14/07, thomas_sorrentino wrote: > > > > > > > > I'm in the process of trying to get my driving lights working. > > So far > > > > I've figured out: > > > > 1.) the high beams have to be on > > > > 2.) the suspension has to be up > > > > 3.) one lens is clear the other is amber (is this normal)? > > > > They won't swing down all the way without a little manual help. > > > > On the air valve, there is a fitting that looks somewhat like a > > brake > > > > bleeder fitting. What is the purpose of that? And is it > > adjustable? > > > > When the switch is in position to put the lights down, air > > escapes from > > > > it. When I cover the escaping air with my hand, the lights swing > > up. > > > > And where do I buy a new one since I broke the old one? > > > > > > > > Tom Sorrentino > > > > 1987 PT38 > > > > Bedford Hills, NY > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
10-21-2007, 11:20
Tommy 2 shoes,
I am in the process of getting mine working and everyhing that Curt S. has said is the way mine work also. I don't know of any logic behind it working off the high beams. Mine has 1 clear and 1 amber light. The amber light, the lens is broke. I've gotten as far as e- mailing photo's to hella to get a replacement clear lens (then I'll have two clear ones). Does anyone happen to have a part number? Once I get the new air cyclinder and new lense I think mine should work as designed. I may have to make some adjustments on the clevis pin on the air cylinder, the micro switch and some lubrication, though. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Tom McCarthy" > > Coincidently, I was checking all the lights the other night. I tried > the Fog/Driving light switch. Nothing. At Holland Motor Homes, I > asked them to chek the bulbs and/or power. They said the Fog/driving > lights came on with HIGH beams! Why would anyone want these lights > meant for fog on when high beams do not work well in fog? > > Just to see what cars do, I checked all I had. All makes, years and > models worked only on low beams and never on high. Those include '07 > BMW X3, '01 BMW, '06 Mini Cooper, '07 Astin Martin. > > Now I read you guys saying yours only come on with high beams, too. > Why? I thought somebody reversed mine at some point. What is the > logic, or lack thereof, in this setup? > > Tommy 2 Shoes McCarthy > 95 PT42 > Poway CA > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > Tom, > > > > Here are some notes that I saved some time ago. Hope this helps. > Please keep > > us posting on your project. > > > > First note: > > Alan there is a switch that the light has to touch to turn the > light on. The > > > > light can be adjusted to hit it. If the cylinder is bad it is a > Clippard. > > Mine is an SDR-20-3 & I got two new ones for sixty dollars for > both. That > > made > > mine work fine after I adjusted them to come the whole way down. I > don't > > think you can repair them. > > Don > > 89 SP 36' > > Butler, PA > > > > Second note: > > These lights to operate. > > Dash Switch ON > > Headlights Must be on > > High beam must be on > > Coach must be at ride hieght. > > > > If The lights won't lower check micro switches mouted on light > > brackests. > > Air control valves are under the front electricial panel. > > And of course last of all the air cylinders. > > The bulbs are replaceable, as for as the lens???? > > Good Luck > > Allen Powell > > 88 WLWB PT40 > > > > > > On 10/14/07, thomas_sorrentino > > > > > > I'm in the process of trying to get my driving lights working. > So far > > > I've figured out: > > > 1.) the high beams have to be on > > > 2.) the suspension has to be up > > > 3.) one lens is clear the other is amber (is this normal)? > > > They won't swing down all the way without a little manual help. > > > On the air valve, there is a fitting that looks somewhat like a > brake > > > bleeder fitting. What is the purpose of that? And is it > adjustable? > > > When the switch is in position to put the lights down, air > escapes from > > > it. When I cover the escaping air with my hand, the lights swing > up. > > > And where do I buy a new one since I broke the old one? > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > |
10-21-2007, 11:21
Tommy I only have fog lights and a switch labelled Fog. I do have the spot
for Driving Lights but it is fitted with a blank instead of a switch. Like I said my Fog lights only work if I have the lights on and set to low beam /10/2007, Tom McCarthy > Rob, the switch reads "Fog/Driving Lights." From this information, > the two apparently are mutually exclusive. I rarely need high beams > but often get nighttime fog in CA. I asked HMH if they could switch > the operation to FOG and low beams, just like my fleet of autos. > > Tommy 2S McCarthy > Poway CA > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Tommy my lights are fog lights and they only come on if I have my > main > > lights on and set to low beam. My manual says that if I had driving > lights > > in place of the fog lights the driving lights would only come on > with the > > main lights on and high beam setting. > > > > On 21/10/2007, Tom McCarthy > > > > > > Coincidently, I was checking all the lights the other night. I > tried > > > the Fog/Driving light switch. Nothing. At Holland Motor Homes, I > > > asked them to chek the bulbs and/or power. They said the > Fog/driving > > > lights came on with HIGH beams! Why would anyone want these lights > > > meant for fog on when high beams do not work well in fog? > > > > > > Just to see what cars do, I checked all I had. All makes, years > and > > > models worked only on low beams and never on high. Those > include '07 > > > BMW X3, '01 BMW, '06 Mini Cooper, '07 Astin Martin. > > > > > > Now I read you guys saying yours only come on with high beams, > too. > > > Why? I thought somebody reversed mine at some point. What is the > > > logic, or lack thereof, in this setup? > > > > > > Tommy 2 Shoes McCarthy > > > 95 PT42 > > > Poway CA > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > "Curt Sprenger" > > > > > > > > > > > Tom, > > > > > > > > Here are some notes that I saved some time ago. Hope this helps. > > > Please keep > > > > us posting on your project. > > > > > > > > First note: > > > > Alan there is a switch that the light has to touch to turn the > > > light on. The > > > > > > > > light can be adjusted to hit it. If the cylinder is bad it is a > > > Clippard. > > > > Mine is an SDR-20-3 & I got two new ones for sixty dollars for > > > both. That > > > > made > > > > mine work fine after I adjusted them to come the whole way > down. I > > > don't > > > > think you can repair them. > > > > Don > > > > 89 SP 36' > > > > Butler, PA > > > > > > > > Second note: > > > > These lights to operate. > > > > Dash Switch ON > > > > Headlights Must be on > > > > High beam must be on > > > > Coach must be at ride hieght. > > > > > > > > If The lights won't lower check micro switches mouted on light > > > > brackests. > > > > Air control valves are under the front electricial panel. > > > > And of course last of all the air cylinders. > > > > The bulbs are replaceable, as for as the lens???? > > > > Good Luck > > > > Allen Powell > > > > 88 WLWB PT40 > > > > > > > > > > > > On 10/14/07, thomas_sorrentino > > > > > > > > > > I'm in the process of trying to get my driving lights working. > > > So far > > > > > I've figured out: > > > > > 1.) the high beams have to be on > > > > > 2.) the suspension has to be up > > > > > 3.) one lens is clear the other is amber (is this normal)? > > > > > They won't swing down all the way without a little manual > help. > > > > > On the air valve, there is a fitting that looks somewhat like > a > > > brake > > > > > bleeder fitting. What is the purpose of that? And is it > > > adjustable? > > > > > When the switch is in position to put the lights down, air > > > escapes from > > > > > it. When I cover the escaping air with my hand, the lights > swing > > > up. > > > > > And where do I buy a new one since I broke the old one? > > > > > > > > > > Tom Sorrentino > > > > > 1987 PT38 > > > > > Bedford Hills, NY > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-21-2007, 11:48
Tom, My Pinto and Vega fog lights only work on low beam but the
Maverick doesnt even have fog lights. When driving requires fog lights, I use the coffee maker and wait. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Tom McCarthy" > > Coincidently, I was checking all the lights the other night. I tried > the Fog/Driving light switch. Nothing. At Holland Motor Homes, I > asked them to chek the bulbs and/or power. They said the Fog/driving > lights came on with HIGH beams! Why would anyone want these lights > meant for fog on when high beams do not work well in fog? > > Just to see what cars do, I checked all I had. All makes, years and > models worked only on low beams and never on high. Those include '07 > BMW X3, '01 BMW, '06 Mini Cooper, '07 Astin Martin. > > Now I read you guys saying yours only come on with high beams, too. > Why? I thought somebody reversed mine at some point. What is the > logic, or lack thereof, in this setup? > > Tommy 2 Shoes McCarthy > 95 PT42 > Poway CA > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > Tom, > > > > Here are some notes that I saved some time ago. Hope this helps. > Please keep > > us posting on your project. > > > > First note: > > Alan there is a switch that the light has to touch to turn the > light on. The > > > > light can be adjusted to hit it. If the cylinder is bad it is a > Clippard. > > Mine is an SDR-20-3 & I got two new ones for sixty dollars for > both. That > > made > > mine work fine after I adjusted them to come the whole way down. I > don't > > think you can repair them. > > Don > > 89 SP 36' > > Butler, PA > > > > Second note: > > These lights to operate. > > Dash Switch ON > > Headlights Must be on > > High beam must be on > > Coach must be at ride hieght. > > > > If The lights won't lower check micro switches mouted on light > > brackests. > > Air control valves are under the front electricial panel. > > And of course last of all the air cylinders. > > The bulbs are replaceable, as for as the lens???? > > Good Luck > > Allen Powell > > 88 WLWB PT40 > > > > > > On 10/14/07, thomas_sorrentino > > > > > > I'm in the process of trying to get my driving lights working. > So far > > > I've figured out: > > > 1.) the high beams have to be on > > > 2.) the suspension has to be up > > > 3.) one lens is clear the other is amber (is this normal)? > > > They won't swing down all the way without a little manual help. > > > On the air valve, there is a fitting that looks somewhat like a > brake > > > bleeder fitting. What is the purpose of that? And is it > adjustable? > > > When the switch is in position to put the lights down, air > escapes from > > > it. When I cover the escaping air with my hand, the lights swing > up. > > > And where do I buy a new one since I broke the old one? > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > |
10-21-2007, 11:50
It should be a simple change -- moving one wire to the correct relay.
However, what seems simple on a 'bird rarely is. The real trick is finding the "right" wire! You may want to take your 'bird out to a lonely, dark stretch of road and determine if the lights are, in fact, fog or driving lights. If they're driving lights, they will simply increase the glare in fog. Fog lights should have a broad, low-aimed beam while the driving lights would have a narrow, long beam. You may need to change the lenses to have proper fog lights. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Oct 21, 2007, at 5:14 PM, Tom McCarthy wrote: > Rob, the switch reads "Fog/Driving Lights." From this information, > the two apparently are mutually exclusive. I rarely need high beams > but often get nighttime fog in CA. I asked HMH if they could switch > the operation to FOG and low beams, just like my fleet of autos. > > Tommy 2S McCarthy > Poway CA > |
10-30-2007, 12:57
Hi Tom,
I have not followed this thread, But I have driving lights mounted in the bumper, (Not air activated). I was unhappy with the high / low beam set-up. So I rewired, and now turn on the driving lights with the on/off switch only, not the high beam switch. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > I'm in the process of trying to get my driving lights working. So far > I've figured out: > 1.) the high beams have to be on > 2.) the suspension has to be up > 3.) one lens is clear the other is amber (is this normal)? > They won't swing down all the way without a little manual help. > On the air valve, there is a fitting that looks somewhat like a brake > bleeder fitting. What is the purpose of that? And is it adjustable? > When the switch is in position to put the lights down, air escapes from > it. When I cover the escaping air with my hand, the lights swing up. > And where do I buy a new one since I broke the old one? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > |
10-30-2007, 15:06
Bill,
You always do it right. I was talking with Marty Haberman a few days ago. He is rewiring his headlights. Marty and I agreed that the driving lights should be on their own switch/control. On 10/30/07, pattypape > > > Hi Tom, > > I have not followed this thread, > But I have driving lights mounted in the bumper, (Not air > activated). I was unhappy with the high / low beam set-up. So I > rewired, and now turn on the driving lights with the on/off switch > only, not the high beam switch. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > "thomas_sorrentino" > > > > > I'm in the process of trying to get my driving lights working. So > far > > I've figured out: > > 1.) the high beams have to be on > > 2.) the suspension has to be up > > 3.) one lens is clear the other is amber (is this normal)? > > They won't swing down all the way without a little manual help. > > On the air valve, there is a fitting that looks somewhat like a > brake > > bleeder fitting. What is the purpose of that? And is it adjustable? > > When the switch is in position to put the lights down, air escapes > from > > it. When I cover the escaping air with my hand, the lights swing > up. > > And where do I buy a new one since I broke the old one? > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
10-30-2007, 15:23
I went to Napa and purchased a set of halogen lights. I installed them using a
relay and a seperate switch. I use them for day recognition lights. That way none of the other electrical lighting system is on. When I need light at night as I recently did in a dark campground in the GA mountains I have Ten lights shining. I hope no one wants to sleep. lol 6 halogen headlights, 2 driving lights and 2 spot lights. Turn on the landing lights and the world lights up. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Curt Sprenger Bill, You always do it right. I was talking with Marty Haberman a few days ago. He is rewiring his headlights. Marty and I agreed that the driving lights should be on their own switch/control. On 10/30/07, pattypape > > > Hi Tom, > > I have not followed this thread, > But I have driving lights mounted in the bumper, (Not air > activated). I was unhappy with the high / low beam set-up. So I > rewired, and now turn on the driving lights with the on/off switch > only, not the high beam switch. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > "thomas_sorrentino" > > > > > I'm in the process of trying to get my driving lights working. So > far > > I've figured out: > > 1.) the high beams have to be on > > 2.) the suspension has to be up > > 3.) one lens is clear the other is amber (is this normal)? > > They won't swing down all the way without a little manual help. > > On the air valve, there is a fitting that looks somewhat like a > brake > > bleeder fitting. What is the purpose of that? And is it adjustable? > > When the switch is in position to put the lights down, air escapes > from > > it. When I cover the escaping air with my hand, the lights swing > up. > > And where do I buy a new one since I broke the old one? > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
10-30-2007, 15:56
Leroy,
I like that kind of talk. Let there be light! Does anybody have any idea why my fog lights only work when the high beams are on? Turn on the dash switch for the fog lights, nothing! They only work with the driving lights on high beam. Recently, I took the headlight switch apart to firm up the contacts, the running lights were going in and out. I didn't check to see if the fog lights were connected to the main switch, but there are four wires connected to it. Any help would be great. Kurt Horvath '95 PT-42 WLWB 10ACEeeee ----- Original Message ---- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, October 30, 2007 9:23:58 PM Subject: Re: [WanderlodgeForum] Re: Driving lights -operation? I went to Napa and purchased a set of halogen lights. I installed them using a relay and a seperate switch. I use them for day recognition lights. That way none of the other electrical lighting system is on. When I need light at night as I recently did in a dark campground in the GA mountains I have Ten lights shining. I hope no one wants to sleep. lol 6 halogen headlights, 2 driving lights and 2 spot lights. Turn on the landing lights and the world lights up. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Curt Sprenger You always do it right. I was talking with Marty Haberman a few days ago. He is rewiring his headlights. Marty and I agreed that the driving lights should be on their own switch/control. On 10/30/07, pattypape > > > Hi Tom, > > I have not followed this thread, > But I have driving lights mounted in the bumper, (Not air > activated). I was unhappy with the high / low beam set-up. So I > rewired, and now turn on the driving lights with the on/off switch > only, not the high beam switch. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@ yahoogroups. com > "thomas_sorrentino" > > > > > I'm in the process of trying to get my driving lights working. So > far > > I've figured out: > > 1.) the high beams have to be on > > 2.) the suspension has to be up > > 3.) one lens is clear the other is amber (is this normal)? > > They won't swing down all the way without a little manual help. > > On the air valve, there is a fitting that looks somewhat like a > brake > > bleeder fitting. What is the purpose of that? And is it adjustable? > > When the switch is in position to put the lights down, air escapes > from > > it. When I cover the escaping air with my hand, the lights swing > up. > > And where do I buy a new one since I broke the old one? > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] ____________ _________ _________ _________ _________ __ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail. yahoo.com [Non-text portions of this message have been removed] __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
10-30-2007, 17:18
Kurt,
Apparently, fog lights and driving lights are two different concept. While my dash switch reads, "Driving/Fog Lights," I found that they only worked with HIGH beams on. This configuration is considered "Driving" lights. I always used "Fog" lights with low beams. My Driving/Fog lights do not work with Low beams. In fog, therefore, they are useless. Since I rarely travel with High beams, I am having them switched to work as normal "Fog" lights with low beams. To each his own. Tommy Two Shoes McCarthy Driving fast and easy in Poway Ca for John Finn's sake 95 PT42 --- In WanderlodgeForum@yahoogroups.com, Kurt Horvath > > Leroy, > > I like that kind of talk. Let there be light! Does anybody have any idea why my fog lights only work when the high beams are on? Turn on the dash switch for the fog lights, nothing! They only work with the driving lights on high beam. Recently, I took the headlight switch apart to firm up the contacts, the running lights were going in and out. I didn't check to see if the fog lights were connected to the main switch, but there are four wires connected to it. Any help would be great. > > Kurt Horvath > '95 PT-42 WLWB > 10ACEeeee > > > ----- Original Message ---- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, October 30, 2007 9:23:58 PM > Subject: Re: [WanderlodgeForum] Re: Driving lights -operation? > > I went to Napa and purchased a set of halogen lights. I installed them using a relay and a seperate switch. I use them for day recognition lights. That way none of the other electrical lighting system is on. When I need light at night as I recently did in a dark campground in the GA mountains I have Ten lights shining. I hope no one wants to sleep. lol 6 halogen headlights, 2 driving lights and 2 spot lights. Turn on the landing lights and the world lights up. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > Curt Sprenger > You always do it right. I was talking with Marty Haberman a few days ago. He > is rewiring his headlights. Marty and I agreed that the driving lights > should be on their own switch/control. > > On 10/30/07, pattypape > > > > > > Hi Tom, > > > > I have not followed this thread, > > But I have driving lights mounted in the bumper, (Not air > > activated). I was unhappy with the high / low beam set-up. So I > > rewired, and now turn on the driving lights with the on/off switch > > only, not the high beam switch. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@ yahoogroups. com > > "thomas_sorrentino" > > > > > > > > I'm in the process of trying to get my driving lights working. So > > far > > > I've figured out: > > > 1.) the high beams have to be on > > > 2.) the suspension has to be up > > > 3.) one lens is clear the other is amber (is this normal)? > > > They won't swing down all the way without a little manual help. > > > On the air valve, there is a fitting that looks somewhat like a > > brake > > > bleeder fitting. What is the purpose of that? And is it adjustable? > > > When the switch is in position to put the lights down, air escapes > > from > > > it. When I cover the escaping air with my hand, the lights swing > > up. > > > And where do I buy a new one since I broke the old one? > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > [Non-text portions of this message have been removed] > > > > > > ____________ _________ _________ _________ _________ __ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail. yahoo.com > > [Non-text portions of this message have been removed] > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
