Power steering pump disaster
11-25-2007, 08:12
WOW!!!What pleasant a surprise when the power steering quits on a
narrow winding country road.
I was bringing the coach home to install tank heaters for a trip
north next weekend. I felt a little unfamiliar twitch in the steering
followed shortly by another as I was entering a bend in the road. I
suddenly felt the wheel fighting me and pushing back. It felt like
the front end was locking up or falling apart. I hit the brakes and
pulled wheel with all my might to keep it on the road.
After stopping I couldn't see what was wrong so I assumed the power
steering pump just quit. I managed to disconnect the toad and make a
very difficult three point turn, reconnect the toad and return to the
storage facility very slowly. After I opened up the front end and
swung out the radiator I could see the belt was off the pulley. I
reached in to see if the pump was frozen and the pulley fell off in
my hand. The hub had disintegrated and only the three spokes were
left. Fluid was dripping from the front pump bearing and the shaft
was scraped up. The bolt was still tight in the front of the shaft.
So I am perusing the forum data to locate pump suppliers. I assume
the pump will be easier than the pulley. Does anyone know where I
might find the pulley before I start calling the likley candidates?
So much for this weekend's trip.
Gardner
78FC33
11-25-2007, 08:53
Good thing you weren't on yer way to Alaska.
Now might be the time to install the 87 and up 6.5"
dia. pump pulley, greatly reduces the incidence of pump cavitation. Cavitation
is what kills most FC pumps due to the lousy sump configuration. A larger sump
down by the pump with a small fill/check chamber under the engine cover is a
great upgrade. One of the better things I've done to mine I'll tell you.
Power Steering Specialist
614 882 2422
These guys have supplied me successfully with the things I need for some
projects requiring very obscure parts.
MH
Sent: Sunday, November 25, 2007 2:12 PM
Subject: [WanderlodgeForum] Power steering pump disaster
Gardner
78FC33
11-25-2007, 09:31
http://www.levysteering.com
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> Gardner
> 78FC33
11-25-2007, 11:31
Mike,
Do you have a part number for the larger pulley? I think for now
I just want to get back on the road. The weather is turning cold and
working outdoors will be bad enough just getting it back together,
let alone trying fanacy upgrades. The pulley would be simple, but
relocating the sump is a later project.
Gardner
78FC33
cavitation. Cavitation is what kills most FC pumps due to the lousy
sump configuration. A larger sump down by the pump with a small
fill/check chamber under the engine cover is a great upgrade. One
> 614 882 2422
for some projects requiring very obscure parts.
> MH
> From: Gardner Yeaw
a
steering
road. I
like
power
make a
to the
I
in
were
shaft
shaft.
assume
I
candidates?
> Gardner
> 78FC33
11-25-2007, 11:47
Stephen,
Thanks. I am having trouble crossreferencing, but I assume a
phone call will work tomorrow.
Gardner
78FC33
> Stephen 77fc35
a
trip
steering
road. I
like
power
make a
to the
I
in
were
shaft
shaft.
assume
I
candidates?
> > Gardner
> > 78FC33
11-26-2007, 03:38
Gardner:
While you're working on the pump over the cold months,
you might want to consider some upgrades to the whole
system. I have some pictures here of what I did to
mine. FC power steering systems run too hot. (put an
infrared thermometer on the reservoir after driving),
partly because the low pressure lines run close to
the exhaust manifold. I replaced all my lines with
high temperature lines, insulated them with firesleeve
where they pass by the manifold, doubled the size of
the reservoir and added a cooler. Reduced running
temperatures by about 100 degrees.
Kerry
82 FC 35
Denver
____
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now.
http://mobile.yahoo.com/sports;_ylt=At9_...QtBI7ntAcJ
