88 pt 40 how many alternators?
12-10-2007, 09:37
Post: #21
Thanks Rob, will do. I will check them out.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Rob Robinson wrote: Leroy I
assume you are aware of the compressor coolant lines issue and the
need to check them for aging. Some of them have literally fallen apart when
subjected to relatively gentle tugs. Do a search on both Wanderlodge sites
for previous posts and fixes.
On 10/12/2007, Leroy Eckert wrote:
> If that was for me I haven't messed with my air compressor. If it is in
> the rear area of the engine then I presume so. The access hole allows me to
> access the generator, exhaust pipe, belts and other things on the top rear
> of the engine.
> Is there something I should be doing to the air compressor. I haven't had
> any problems, yet...???
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> ciao70@... wrote: Larry..I haven't looked yet but
> does the, under the bed access door for the
> alternator, also give you access to the air compressor? Jim Barone
> 1991WLWB
> **************************************Check out AOL's list of 2007's
> hottest
> products.
> (http://money.aol.com/special/hot-product...0000000001)
> Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Rob, Sue & Merlin Robinson
94 WLWB
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
12-10-2007, 09:44
Post: #22
In my coach you can't get to the alternator thru the bedroom. There is room to
climb in from the curbside however. Also in my coach the is no switch for alt 1
and 2.
Jim
Leroy Eckert
Dahlonega, GA
Rob Robinson wrote: Leroy I assume you are aware of the
> of the engine.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> 1991WLWB
> hottest
> products.
94 WLWB
