8v92 temperature
12-10-2007, 00:05
8v92 temperature
Correction on my post. I should have said cut out instead of cut in point when
road surface temps are hot. Cut in is at the high temperature, cut out (turns
the fan off) is at the lower temperature of the Alarmstat range.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Scott Forman <sforman@...> wrote: 8v92
owners...what temp does your engine run when cruising?
Mine hovers around 190. When it creeps a bit past the 190 line on the
gauge, I assume the fan kicks in, and it cools to just below 190 on the
gauge. Then it heats back up and the process is repeated.
Is this similar to other owners' experiences?
Scott Forman
86 PT38
Memphis
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
12-10-2007, 14:56
8v92 temperature
Curt: Do you know what temperature thermostats you are running in
your coach? Also what temperature is your alarmstat set to cycle the fan?
I am about to have my cooling system cleaned and back-flushed. After
that I will put in new alarmstat and thermostats.
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Our '87 PT38 performed about the same...after new thermostats and
radiator
> cleaning the temp. runs about 180 and rarely climbs to 190 on the steep
> grades. Oil temperature is running cooler as well.
> On Dec 9, 2007 5:49 PM, Scott Forman <sforman@...> wrote:
> > 8v92 owners...what temp does your engine run when cruising?
on the
> > Scott Forman
> > 86 PT38
> > Memphis
> Curt Sprenger
> 1987 PT38 8V92 "MacAttack Racing"
> Anaheim Hills, CA
12-10-2007, 18:12
8v92 temperature
Ron,
I'm running new 180 degree thermostats. Didn't touch the alarmastat.
> "Curt Sprenger"
> radiator
> on the
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> > Curt Sprenger
> > Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
12-11-2007, 07:56
8v92 temperature
Thanks Curt. Did you get your thermostats from Detroit? Those
puppies are expensive if you did. Anybody else furnish them that you
know of?
> Ron,
the fan?
> > --- In
> > "Curt Sprenger"
> > radiator
the steep
on the
> > on the
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
> > > Curt Sprenger
> > > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
12-11-2007, 10:25
8v92 temperature
Ron,
All purchased from Detroit, thermostats $44.28 each, seals $14.20 each,
gaskets $1.55 each. I'm not aware of anybody else that carries them. I think
a big truck store would have them or can get them.
> know of?
> "Curt Sprenger"
> > Ron,
> the fan?
> > > --- In
> > > "Curt Sprenger"
> > > radiator
> the steep
> on the
> > > on the
> > > > > Scott Forman
> > > > > 86 PT38
> > > > > Memphis
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
> > Curt Sprenger
> > Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
12-11-2007, 11:42
8v92 temperature
Curt: Do you have a part number? For my S/N engine, they said I
needed #8924847 at a price of $117.57 per each.
> Ron,
I think
> > know of?
> > --- In
> > "Curt Sprenger"
> > wrote:
> > > Ron,
> > the fan?
After
> > > > --- In
> > > > "Curt Sprenger"
thermostats and
> > > > radiator
> > the steep
> > on the
below 190
> > > > on the
> > > > > > Scott Forman
> > > > > > 86 PT38
> > > > > > Memphis
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
> > > Curt Sprenger
> > > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
12-11-2007, 16:23
8v92 temperature
Ron,
Part numbers...thermostats #23503825 (old part #5102651), seals #5132155 (
no old part number), gaskets #5117786 (old part #6117438).
> "Curt Sprenger"
> > Ron,
> I think
> > > know of?
> > > --- In
> > > "Curt Sprenger"
> > > wrote:
> > > > Ron,
> > > the fan?
> After
> > > > > --- In
> > > > > "Curt Sprenger"
> thermostats and
> > > > > radiator
> > > the steep
> > > on the
> below 190
> > > > > on the
> > > > > > > Scott Forman
> > > > > > > 86 PT38
> > > > > > > Memphis
> > > > > > Curt Sprenger
> > > > > > Anaheim Hills, CA
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
> > Curt Sprenger
> > Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
