LXi Front Anti-Sway Bar
01-22-2008, 16:39
Folks,
As many of you know, I've been trying to get my LXi to ride better for quite some time. I've added Koni FSD's to the rear, set the ride height to spec, played with the tag axle air-bag pressure, and finely calibrated my tire pressures. All of these efforts paid off but none offered the big bang I was looking for. I've long been considering disconnecting the front sway bar to see what effect it has on the ride quality. As many of you know, the LXi was the first Wanderlodge to be factory equipped with a front sway bar. The sway bar is 2.125" in diameter and provides 2500 lbs/in of spring rate at the wheel. Well, around 1000 miles ago I disconnected the bar and the results are astonishing. Folks out there who have experience with aftermarket sway bars know that they are quite effective in limiting lean in turns and at sprucing up the steering response in general. What I found after disconnecting mine is that the bird does lean more in a turn, but the suspension quickly settles providing good turn-in and corner stability. During crosswinds, I can feel the bird roll with each gust, but the steering control isn't terribly effected. What is changed dramatically is the ride. For the first time, my LXi's front suspension actually absorbs bumps! In addition, gone is the porpoising that I thought was endemic to the entire Wanderlodge line. It turns out that my front air-bags offer 2500 lb/in of spring rate at the wheel; the sway bar doubles this to 5000 lb/in. Also, the front shocks are tuned to handle the dampening of the air-bags; the sway bar is largely undamped. If I increase the Koni dampening to include the sway bar, then on straight ahead bumps, the ride becomes extremely harsh. The undamped sway bar causes the front end to sometimes launch resulting in huge weight transfer to the rear axle, right at the time that the rear axle is hitting the bump, causing the rear axle to launch vertically, etc. All of that is gone. The bird doesn't porpoise; it's front axle has independent wheel movement; and it absorbs bumps instead of launching the vehicle into a rocking to- and-fro frenzy. What a difference. As I stated earlier, there are handling compromises, but to me the improvement in ride easily outways the increase in driver dilligence in heavy crosswinds. What I'd like to do is to try a lighter weight bar. Something on the order of 500 to 1000 lbs/in of spring rate; or better yet, something like HWH's Active Air. But for now, I'm enjoying the ride. David Brady '02 LXi, FL |
01-22-2008, 18:11
--- In WanderlodgeForum@yahoogroups.com, "david brady"
wrote: > > Folks, > > As many of you know, I've been trying to get my LXi to ride better > for quite some time. I've added Koni FSD's to the rear, set the ride > height to spec, played with the tag axle air-bag pressure, and finely > calibrated my tire pressures. All of these efforts paid off but none > offered the big bang I was looking for. I've long been considering > disconnecting the front sway bar to see what effect it has on the > ride quality. As many of you know, the LXi was the first Wanderlodge > to be factory equipped with a front sway bar. The sway bar is 2.125" > in diameter and provides 2500 lbs/in of spring rate at the wheel. > Well, around 1000 miles ago I disconnected the bar and the results > are astonishing. Folks out there who have experience with aftermarket > sway bars know that they are quite effective in limiting lean in > turns and at sprucing up the steering response in general. What I > found after disconnecting mine is that the bird does lean more in a > turn, but the suspension quickly settles providing good turn-in and > corner stability. During crosswinds, I can feel the bird roll with > each gust, but the steering control isn't terribly effected. What is > changed dramatically is the ride. For the first time, my LXi's front > suspension actually absorbs bumps! In addition, gone is the > porpoising that I thought was endemic to the entire Wanderlodge line. > It turns out that my front air-bags offer 2500 lb/in of spring rate > at the wheel; the sway bar doubles this to 5000 lb/in. Also, the > front shocks are tuned to handle the dampening of the air-bags; the > sway bar is largely undamped. If I increase the Koni dampening to > include the sway bar, then on straight ahead bumps, the ride becomes > extremely harsh. The undamped sway bar causes the front end to > sometimes launch resulting in huge weight transfer to the rear axle, > right at the time that the rear axle is hitting the bump, causing the > rear axle to launch vertically, etc. All of that is gone. The bird > doesn't porpoise; it's front axle has independent wheel movement; and > it absorbs bumps instead of launching the vehicle into a rocking to- > and-fro frenzy. What a difference. As I stated earlier, there are > handling compromises, but to me the improvement in ride easily > outways the increase in driver dilligence in heavy crosswinds. What > I'd like to do is to try a lighter weight bar. Something on the order > of 500 to 1000 lbs/in of spring rate; or better yet, something like > HWH's Active Air. But for now, I'm enjoying the ride. > > David Brady > '02 LXi, FL Well that is interesting. I wonder how many of the commercial bluebird buses have this sway bar installed? Seems like the Wanderlodge engineers mist something when they installed that particular sway bar set up. Have you tried to contact the people at the Bluebird company to see if they have a lighter set up? Well anyway very interesting report and should it give a good heads up to fellow owners of the Lxi's. Thanks Jon Bremerton > |
01-23-2008, 03:19
Jon,
I did speak to BB service personel explaining my experience. The service folks had no issue with removing the bar regarding vehicle handling dynamics. I want to emphasize that I removed the bar, not BB. There's no question that the handling is "looser", but not excessively so. I'd guess that it's much like any of the "bar-less" Wide Bodies. The problem with the 2.125" bar is that in a corner, it holds up the entire bus as opposed to working in conjunction with rear roll stiffness. The rear of the bus has quite a bit of roll stiffness built in. The stock front bar makes the LXi corner with virtually no lean. I don't want a front bar to hold up the entire bus - way too stiff; it almost eliminates independent front wheel motion. David Brady '02 LXi, FL --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Well that is interesting. I wonder how many of the commercial > bluebird buses have this sway bar installed? Seems like the > Wanderlodge engineers mist something when they installed that > particular sway bar set up. Have you tried to contact the people at > the Bluebird company to see if they have a lighter set up? Well > anyway very interesting report and should it give a good heads up to > fellow owners of the Lxi's. Thanks > > Jon > Bremerton > > > |
01-23-2008, 05:05
David, How about a electrically activated disconnect like on the new
Jeep Rubicon's, in low wind and straight roads, disconnect, in high wind and roads with a lot of tight corners, push a button and connect. I am sure that the same type of system could be made for larger bars than the Jeep has. Marty Gregg 95 BMC 37 Kennewick WA. |
01-23-2008, 05:18
Hi Marty,
That thought has occurred to me. I'm also a big fan of rubicon lift kits. The problem is that the bar is so darn stiff the auto connect/disconnect would have to be engineered very well. The stock vertical links on the LXi look much like shackles on a leaf spring suspension. The shear bolts are 5/8" and mounted in double shear. At these spring rates a quick connect vertical link is beyond my abilities, plus space is very limited down there. I like the idea though. I'm thinking active air. The new '09 uses HWH Active Air without front or rear sway bars. David Brady '02 LXi, FL --- In WanderlodgeForum@yahoogroups.com, "martingregg598" > > David, How about a electrically activated disconnect like on the new > Jeep Rubicon's, in low wind and straight roads, disconnect, in high > wind and roads with a lot of tight corners, push a button and connect. > I am sure that the same type of system could be made for larger bars > than the Jeep has. > Marty Gregg > 95 BMC 37 > Kennewick WA. > |
01-23-2008, 05:41
With your Florida home base, I realize you're rather far from the
west coast. I can suggest contacting Henderson's Line-Up in Grants Pass Oregon. (They may be able to refer you to some one closer to you.) See their website: <http://www.hendersonslineup.com> They sell (and manufacture) a large number of suspension improvement options for RVs -- and they've worked on several Wanderlodges, including mine. Looking at their web site, they sell Roadmaster anti-sway bars -- so they might have a smaller one for you to try. If you take your coach to them, they start out with a Road Performance Assessment -- a trip of a few miles over a variety of driving conditions -- where their technician analyzes the suspension characteristics. They'll then prepare a list of recommendations to improve your coach's handling. I used them when my coach was pulling to the right (constantly) and had a out of balance tire vibration in the front end. It was quickly found that the Blue Ox True Center steering damper with trim adjustment was bent and jammed -- I also had a worn tie rod end (drag link) and an out-of-round tire. In addition to a new tire (purchased from Schawb tire across the street), new tie rod components were installed and the steering damper was replaced with the Henderson's manufactured Safe-T-Plus steering damper with trim adjustment -- they also gave the adjustable Koni shocks a slightly more resistant adjustment (one turn). The handling improvement was substantial and other (expensive) additions that they could have suggested were deemed "probably marginal" and not recommended. Indeed, they could easily have 'sold' me on several unneeded products, but proved to be quite honest in their suggestions. In addition to the sway bars they offer, you might find a steering damper may provide the additional precision to the steering you lose without the current sway bar. They also offer Super Steer motion control units -- these are added to the air lines feeding the air bags to control their reaction rate to reduce sway, roll, and bounce. See their web site for information about the various products they offer and here's the URL for the motion control units. <http://hendersonslineup.com/uncategorize...n-control- unit/> Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jan 22, 2008, at 9:39 PM, david brady wrote: > Folks, > > As many of you know, I've been trying to get my LXi to ride better > for quite some time. <snip> What > I'd like to do is to try a lighter weight bar. Something on the order > of 500 to 1000 lbs/in of spring rate; or better yet, something like > HWH's Active Air. But for now, I'm enjoying the ride. > > David Brady > '02 LXi, FL |
01-23-2008, 06:19
Thanks Pete,
I'll check Henderson's website. I spend a lot of time on the west coast so a visit is a possibility. I'd like to explore the possibility of a softer sway bar. I also plan to stiffen the front shocks slightly and maybe lower the front ride height a smidge to regain some of my lost handling. Quite franky, I like the way it handles w/o the bar. Feels more bus like. (Don't plan to do laps at Leguna Seca any time soon)! It will be interesting to see how HWH's active air performs on the new '09 bus. That may also be a possible upgrade. Right now, I'm thrilled with the "new" bus ride I have. I've driven Prevost' and my LXi rides pretty close at this point. David Brady '02 LXi, FL (just visiting) --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > With your Florida home base, I realize you're rather far from the > west coast. > > I can suggest contacting Henderson's Line-Up in Grants Pass Oregon. > (They may be able to refer you to some one closer to you.) See their > website: > <http://www.hendersonslineup.com> > > |
01-23-2008, 06:45
David,
Sounds fascinating. That's one of the biggest disappointments I have with my beautiful coach- the porpoising. I'm going to study your notes more carefully and may have mine removed before my western trip in about a month. Brad Barton 00LXiDFW bbartonwx@... Connect and share in new ways with Windows Live. Get it now! |
01-23-2008, 06:54
Brad,
I removed the two vertical links and swung the bar up and secured it out of the way. After a thousand miles I'm sure that mine won't be going back on, so I do plan to completely remove the bar. Removing the links and swinging the bar out of the way is quick and easy, then you can go for a test drive on a bumpy road to see what you think. David Brady '02 LXi, Fl --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > David, > Sounds fascinating. That's one of the biggest disappointments I have with my beautiful coach- the porpoising. I'm going to study your notes more carefully and may have mine removed before my western trip in about a month. Brad Barton 00LXiDFWbbartonwx@... > _________________________________________________________________ > Connect and share in new ways with Windows Live. > http://www.windowslive.com/share.html? ocid=TXT_TAGHM_Wave2_sharelife_012008 > |
01-23-2008, 07:02
David,
I might just have that done. I don't have the facility for it myself. I've been on some bridges and overpasses that have such a vertical undulating frequency that I have to slow down to get better control. I even worry about blowing an airbag or a tire. And I had the shocks tightened up with I first got it. Driving a Newell for five years (no tag) I would have to struggle on a really bad crosswind..and I enjoy the lateral stability of the Blue Bird with the tag. But what you've found is very interesting. I'm also still struggling with the tag solenoid releasing the following tag on rough roads at slow speed. I think I'll have it bypassed completely out. Brad Barton 00LXiDFW bbartonwx@...
