LXi Front Anti-Sway Bar
01-23-2008, 09:04
Can't you just remove the link from one side, and tie that link out of the way?
True, there will still be a bit of unsprung weight, but I really don't think that it would matter. ken wannabe in SoCal On Jan 23, 2008 10:54 AM, david brady > > > > > Brad, > > I removed the two vertical links and swung the bar up and secured it > out of the way. After a thousand miles I'm sure that mine won't be > going back on, so I do plan to completely remove the bar. Removing the > links and swinging the bar out of the way is quick and easy, then you > can go for a test drive on a bumpy road to see what you think. > > David Brady > '02 LXi, Fl > > --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> > > wrote: > > > > > > David, > > Sounds fascinating. That's one of the biggest disappointments I have > with my beautiful coach- the porpoising. I'm going to study your notes > more carefully and may have mine removed before my western trip in > about a month. Brad Barton 00LXiDFWbbartonwx@... > > __________________________________________________________ > > > Connect and share in new ways with Windows Live. > > http://www.windowslive.com/share.html? > ocid=TXT_TAGHM_Wave2_sharelife_012008 > > > > > > -- Ken Sann |
01-23-2008, 16:41
Brad,
I know exactly what you mean by "slowing down to get better control". Sure, I may have given up razor sharp handling, but in return I now look forward to bumps beast to settle. All-in-all I think I made an improvement in handling. David Brady '02 LXi, Fl --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > David, > I might just have that done. I don't have the facility for it myself. I've been on some bridges and overpasses that have such a vertical undulating frequency that I have to slow down to get better control. I even worry about blowing an airbag or a tire. And I had the shocks tightened up with I first got it. Driving a Newell for five years (no tag) I would have to struggle on a really bad crosswind..and I enjoy the lateral stability of the Blue Bird with the tag. But what you've found is very interesting. I'm also still struggling with the tag solenoid releasing the following tag on rough roads at slow speed. I think I'll have it bypassed completely out. Brad Barton 00LXiDFWbbartonwx@... > > > To: WanderlodgeForum@...: dmb993@...: Wed, 23 Jan 2008 18:54:58 +0000Subject: [WanderlodgeForum] Re: LXi Front Anti-Sway Bar > > > > > Brad,I removed the two vertical links and swung the bar up and secured it out of the way. After a thousand miles I'm sure that mine won't be going back on, so I do plan to completely remove the bar. Removing the links and swinging the bar out of the way is quick and easy, then you can go for a test drive on a bumpy road to see what you think.David Brady'02 LXi, Fl--- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@> wrote:>> > David,> Sounds fascinating. That's one of the biggest disappointments I have with my beautiful coach- the porpoising. I'm going to study your notes more carefully and may have mine removed before my western trip in about a month. Brad Barton 00LXiDFWbbartonwx@> __________________________________________________________> Connect and share in new ways with Windows Live.> http://www.windowslive.com/share.html? ocid=TXT_TAGHM_Wave2_sharelife_012008> > > > > > > > _________________________________________________________________ > Connect and share in new ways with Windows Live. > http://www.windowslive.com/share.html? ocid=TXT_TAGHM_Wave2_sharelife_012008 > |
01-23-2008, 16:43
Ken,
For a short road test, I think removing one link is sufficient. If you want to try it for a thousand miles, then I think removing both and securing the bar is safer. David Brady '02 LXi, Fl --- In WanderlodgeForum@yahoogroups.com, "Ken Sann" wrote: > > Can't you just remove the link from one side, and tie that link out of the way? > True, there will still be a bit of unsprung weight, but I really don't > think that it would matter. > > > > ken > wannabe in SoCal > > On Jan 23, 2008 10:54 AM, david brady > > > > > > > > > > Brad, > > > > I removed the two vertical links and swung the bar up and secured it > > out of the way. After a thousand miles I'm sure that mine won't be > > going back on, so I do plan to completely remove the bar. Removing the > > links and swinging the bar out of the way is quick and easy, then you > > can go for a test drive on a bumpy road to see what you think. > > > > David Brady > > '02 LXi, Fl > > > > --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@> > > > > wrote: > > > > > > > > > David, > > > Sounds fascinating. That's one of the biggest disappointments I have > > with my beautiful coach- the porpoising. I'm going to study your notes > > more carefully and may have mine removed before my western trip in > > about a month. Brad Barton 00LXiDFWbbartonwx@ > > > __________________________________________________________ > > > > > Connect and share in new ways with Windows Live. > > > http://www.windowslive.com/share.html? > > ocid=TXT_TAGHM_Wave2_sharelife_012008 > > > > > > > > > > > > > > > -- > Ken Sann > |
01-25-2008, 06:45
David,
Just talked w/ Jesse Gibson. For what it's worth, he said he'd never heard of removing the anti-sway bar from the front end of an LXi and was not in favor of it. Hesuggested my shocks may not have been adjusted properly even when they were tightened up. I went through some of the pressures and weights you mentioned, but didn't feelright about bending his ear too much. I may have CCW check and adjust my shocks when in SoCal next month. And I'll shop their opinion about the anti-sway bar when I'm there. Meanwhile, Earle was able to find the right deadbolt to fit my entry lock..so it's on the way. Brad Barton 00LXiDFW bbartonwx@... Helping your favorite cause is as easy as instant messaging. You IM, we give. Learn more. |
01-25-2008, 14:12
If CCW can't fix it up, a visit to Henderson's Line-Up in Grants Pass
OR might be worthwhile. They'll be able to tell you how your suspension stacks up... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jan 25, 2008, at 11:45 AM, brad barton wrote: > David, > Just talked w/ Jesse Gibson. For what it's worth, he said he'd > never heard of removing the anti-sway bar from the front end of an > LXi and was not in favor of it. He suggested my shocks may not > have been adjusted properly even when they were tightened up. I > went through some of the pressures and weights you mentioned, but > didn't feel right about bending his ear too much. I may have CCW > check and adjust my shocks when in SoCal next month. And I'll shop > their opinion about the anti-sway bar when I'm there. > Meanwhile, Earle was able to find the right deadbolt to fit my > entry lock..so it's on the way. > > Brad Barton 00LXiDFW > bbartonwx@... > |
01-25-2008, 14:54
Thanks Pete,
I won't be able to make it that far North. We're going DFW to LA to Phoenix to Tucson and back in 10 days. May stop by Quartzite for a night. Brad Barton 00LXiDFW bbartonwx@...
Climb to the top of the charts! Play the word scramble challenge with star power. Play now! |
01-25-2008, 15:00
Brad,
I'm not surprised; corporate liability. They won't do it if they don't have to. Why open yourself up to a potential lawsuit. We as owners, however, are free to do as we please. The difference in handling w/o the bar requires one to recalibrate his driving approach. Once that is accomplished, the coach feels predictable, as usual. Allowing the front suspension to react to the road unencombered by a roll bar is eye opening. I think a softer bar is really what's needed. Something on the order of 500 to 1000 lb/in of spring rate at the wheel, or maybe an HWH Active Air setup (talk about opening yourself up to liability). Coming from a Newell where you had to struggle in gusty winds, I don't think you'd have any problem at all. With due respect to Jesse, I don't think yet-another- shock-adjustment will do much to change your coach. Remember, every Wanderlodge up to the LXi was shipped w/o a sway bar, even the late model 43' Wide Bodies equipped with Series 60 motors. These units are practically identical to LXi's in weight, wheelbase, overhang, and weight distribution. In the end, each of us needs to function within our own confort zones, and each of us needs to take responsibilty for our own actions. David Brady '02 LXi, NC --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > David, > Just talked w/ Jesse Gibson. For what it's worth, he said he'd never heard of removing the anti-sway bar from the front end of an LXi and was not in favor of it. He suggested my shocks may not have been adjusted properly even when they were tightened up. I went through some of the pressures and weights you mentioned, but didn't feel right about bending his ear too much. I may have CCW check and adjust my shocks when in SoCal next month. And I'll shop their opinion about the anti-sway bar when I'm there. > Meanwhile, Earle was able to find the right deadbolt to fit my entry lock..so it's on the way. Brad Barton 00LXiDFWbbartonwx@... > _________________________________________________________________ > Helping your favorite cause is as easy as instant messaging. You IM, we give. > http://im.live.com/Messenger/IM/Home/?so...tmail_join > |
01-25-2008, 15:47
David,
I'm sure there's a lot of truth in what you say. My son, a wouldbe gearhead who plays with suspension,agrees with the smaller, weaker roll-bar approach. I'll do a little more asking around various places, not being an engineer or anything.CCW and Blue Bird should hear what you have to say.You might help them rewrite the book. Brad Barton 00LXiDFW bbartonwx@...
02-08-2008, 07:59
Folks,
I just completed a 2000 mi trip sans front sway bar and am very pleased with the ride and handling. The bus does lean a bit more in a turn, but it quickly settles and feels totally predictable. I learned something new about LXi's during my trip. I had a chance to look over a non-slide 2000 LXi and found that the sway bar is 1.75" in dia. versus my (slide equipped) 2.125" dia. bar. My bar comes in at 5000 lb/in spring rate, while the 1.75" bar is 2350 lb/in. Quite a difference. It seems extreme to double the spring rate simply to accommodate an aluminum slide, which incidentally has most of its heavy weight components (booms, hydraulics, etc) down low close to the CG. The 1.75" bar does provide another option for those of us who don't want to completely eliminate the bar. I'd like to try an even lighter weight bar, on the order of 1000 lb/in. In the meantime, in an effort to keep the bus more upright, I'm looking into Ridewell's Extreme Air height control valves. These valves narrow the dead band to 3 degrees and flow 10 cfm of air. They do require 3/8" air lines however David Brady '02 LXi, NC |
02-08-2008, 16:03
David,
Great to hear your coach is handling well. We are having the brakes and undercarriage inspected and the shocks re-adjusted per spec which is the "company" way to reduce porpoising. We'll be on the road West in another week. I'll let you know how they did. Brad Barton 00LXiDFW bbartonwx@...
Shed those extra pounds with MSN and The Biggest Loser! Learn more. |
