Oil pressure gauge
02-24-2008, 12:14
Oil pressure gauge
While driving north the last couple days, my oil pressure gauge has
fluctuated from 30 pounds to the "normal" 60 while driving. I wonder if the sending unit is starting to go south- or the gauge? Ernie- 83PT40 Buffalo, Wy |
02-24-2008, 12:35
Oil pressure gauge
Or a loose wire with crud at the sensor.
Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > While driving north the last couple days, my oil pressure gauge has > fluctuated from 30 pounds to the "normal" 60 while driving. I wonder if > the sending unit is starting to go south- or the gauge? > Ernie- 83PT40 > Buffalo, Wy > |
02-24-2008, 12:38
Oil pressure gauge
Ernie, OOPS
I hit the send too quick, an intermittent gage needle movement will act like your symptom. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > While driving north the last couple days, my oil pressure gauge has > fluctuated from 30 pounds to the "normal" 60 while driving. I wonder if > the sending unit is starting to go south- or the gauge? > Ernie- 83PT40 > Buffalo, Wy > |
02-24-2008, 13:21
Oil pressure gauge
Ernie: At one time I had a direct reading guage on that rig. Look
just above the pan on the curb side. That will at least tell you if you have good oil pressure. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > While driving north the last couple days, my oil pressure gauge has > fluctuated from 30 pounds to the "normal" 60 while driving. I wonder if > the sending unit is starting to go south- or the gauge? > Ernie- 83PT40 > Buffalo, Wy > |
02-24-2008, 13:24
Oil pressure gauge
Ernie, I agree with what Bill is saying. Check for corrosion/loose wires at both ends. I have seen both the sending unit and the gauge cause this problem. With the age of your bus it could be either. I would lean towards the sending unit if the previous checks don't work for you. Good Luck, George Burke 1977FC31 Charlotte
On Sun, Feb 24, 2008 at 7:14 PM, Ernest Ekberg <"erniecarpet@aol.com"> wrote:
02-24-2008, 14:03
Oil pressure gauge
On the last leg of the trip,
Just a few more miles and a few more climbs. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > I'm wondering if that sending unit is located beside the direct reading > gauge that Ron just mentioned? > > Ernie Ekberg > 83PT40 > Buffalo, Wy, on my way to Livingston, Mt in the am---if it don't SNOW > > > > > **************Ideas to please picky eaters. Watch video on AOL Living. > (http://living.aol.com/video/how-to-pleas...er/rachel- campos-duffy/ > 2050827?NCID=aolcmp00300000002598) > |
02-24-2008, 15:16
Oil pressure gauge
Ernie, Check and make sure the oil level is as it should be. I know
you alrady did this but stranger things have happened. Look for loose or coroded connections. If the sending unit goes out it is usually dead, not intermitent. MIke McMahan --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > While driving north the last couple days, my oil pressure gauge has > fluctuated from 30 pounds to the "normal" 60 while driving. I wonder if > the sending unit is starting to go south- or the gauge? > Ernie- 83PT40 > Buffalo, Wy > |
02-24-2008, 15:44
Oil pressure gauge
I believe that is the case Ernie.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > I'm wondering if that sending unit is located beside the direct reading > gauge that Ron just mentioned? > > Ernie Ekberg > 83PT40 > Buffalo, Wy, on my way to Livingston, Mt in the am---if it don't SNOW > > > > > **************Ideas to please picky eaters. Watch video on AOL Living. > (http://living.aol.com/video/how-to-pleas...pos-duffy/ > 2050827?NCID=aolcmp00300000002598) > |
02-24-2008, 16:20
Oil pressure gauge
Good point Mike, bet it is the gauge and not the sender???? Or a
wire grounding out on the way????? But you should not rule out oilpressure reading being correct!!! Ernie has a Detroit6V92 The 3208Cats have a major oil pressure isssue that added a interval replacement of the oil screen pickup tube in the pan. I had a 1985 3208T lose the oil pickup and droped it in the pan. The entire pipe cracked off at the mounting because the screen cantilevers off the pipe and constant vibration proved a crack. Cat Parts Clerk told me it is a common issue and the pickup was in stock. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...> wrote: > > Ernie, Check and make sure the oil level is as it should be. I know > you alrady did this but stranger things have happened. Look for loose > or coroded connections. If the sending unit goes out it is usually > dead, not intermitent. MIke McMahan > > > --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > > > While driving north the last couple days, my oil pressure gauge has > > fluctuated from 30 pounds to the "normal" 60 while driving. I wonder > if > > the sending unit is starting to go south- or the gauge? > > Ernie- 83PT40 > > Buffalo, Wy > > > |
02-24-2008, 20:58
Oil pressure gauge
Mike, my engine's "comfort" range is operating about 4 quarts low. The oil level holds pretty steady, there. This will be a spring time project upon my arrival in Livingston. Thanks
Ernie Ekberg 83PT40 Buffalo, Wy Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
