Why is my gas gauge pessimistic?
02-29-2008, 21:07
Hugh- do you have any issues with your generator when it runs out of fuel? Do you have to prime it, again?
83PT40
Livingston, Montana
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
02-29-2008, 22:45
In a message dated 3/1/2008 9:31:16 A.M. Central Standard Time, dustbowl@... writes:
when the fuel is running
out on my shoes,
AHHH- the Bluebird baptismal ritual~
usually its all over my pants, too
83PT40
Livingston, Montana
03-01-2008, 01:13
At what level is the gen pickup?
Scott
--- In WanderlodgeForum@yahoogroups.com, Hugh Turner
> Hi Everyone
> This seems to be a fairly common problem with the mid 80s PTs.
My PO told me that when the gauge reads E it still has at least
50/60 gallons left. I have never got a low fuel light. I base mine
fuel time off the generator since it has a shorter pickup. When the
generator shuts off and will not start back it time to get fuel.
When I was in the Air Force working on airplanes ,we had to
physically dip the tanks to check the quantity.
> Hugh & Lexie Turner
> 1984 Wanderlodge PT 40 "OUR DREAM"
> FMCA F393612 Bluebird Chapter
> FCRV #75760 Pollywogs chapter
> Good Sam Life Member 057729600
> Thomaston, Ga 30286
> hturner12@...
03-01-2008, 03:31
Scott
Our FC gauge only reads between full and 3/4 when the fuel is running
out on my shoes, I guess it gives us a buffer when it gets low.
Jeff & Michelle August
1980FC35RB
Plymouth Wi.
> My gas gauge reads full when it is full, but proceeds to fall much
> faster than the actual fuel level. The gauge will be at E and
the 'low
> fuel' light on with 60-70 gals remaining.
> Anyone else experiencing this? No matter how "sure" I am of fuel
level
> using my mileage log, it is still disconcerting...
> Scott Forman
> 86 PT38
> Memphis
03-01-2008, 15:54
The generator did it once as I was bring it home. Once it hic uped I
shut it down to avoid the prime issue, but after I filled up it
started up with no problem. I have several pieces of pvc/cpc pipe
around here, I think I am going to make some type of dip stick to
verify the quantity. Just got to find the 1k to fill it up.
Hugh
fuel?
> Ernie Ekberg
> 83PT40
> Livingston, Montana
> **************Ideas to please picky eaters. Watch video on AOL
Living.
(http://living.aol.com/video/how-to-pleas...pos-duffy/
> 2050827?NCID=aolcmp00300000002598)
03-02-2008, 05:54
Do you know how muchwas in the tan when it hiccupped?
Scott
--- In WanderlodgeForum@yahoogroups.com, "Hugh Turner"
> Hugh
of
> fuel?
> > Ernie Ekberg
> > 83PT40
> > Livingston, Montana
> Living.
> (http://living.aol.com/video/how-to-pleas...er/rachel-
campos-duffy/
03-04-2008, 16:32
Scott
The gage was reading empty and the fuel bill was close $ 700.00 that was last June or July when I brought it home. I was told that when reading zero I still had 50 gallons left and the gauge was off by 50 gallons. Since is appears to be a problem with all birds of our vintage, I still thinking of some type of dip stick to verify the quantity. I will post pictures here and on the new owners site.
Hugh
Hugh & Lexie Turner
1984 Wanderlodge PT 40 “OUR DREAM”
FMCA
Thomaston, Ga 30286
hturner12@...
03-10-2008, 07:47
Gus, you must have been living right to have a fuel starvation and not having to go thru the ordeal of priming.
83PT40
Livingston, Montana
03-10-2008, 11:29
When I was bringing my 89PT40 home, my
generator actually shut off while stopping for a burger.  The fuel gauge was just
below ¼.  I added 100 gls and the generator started right up without priming.
Gus 89PT40
[mailto:WanderlodgeForum@yahoogroups.com] On
Behalf Of
Scott Forman
Sent: Sunday, March 02, 2008 11:54
AM
To:
Subject: [WanderlodgeForum] Re:
Scott
--- In "WanderlodgeForum%40yahoogroups.com",
"Hugh Turner"
> Hugh
of
> fuel?
> > Ernie Ekberg
> > 83PT40
> > Livingston, Montana
> Living.
> (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-
campos-duffy/
