Roof air
03-23-2008, 11:19
Roof air
In a message dated 3/23/2008 7:26:14 P.M. Central Standard Time, dbcooper100@... writes:
Would it be practical to remove this air
conditioner and install a Fantastic Fan.
If you live in Canada- yes, if you live in the south, no.
83PT40
Livingston, Montana--summer- 2 airs required
if I was home in texas in summer- 3 required
Create a Home Theater Like the Pros. Watch the video on AOL Home.
03-23-2008, 14:25
Roof air
I have a 1984 FC35SB it has 3 roof air conditioners, the center one is
inoperative, my question is: Would it be practical to remove this air
03-23-2008, 14:51
Roof air
We have just 2 roof A/Cs in out FC31, and find them adaquite. Yes,
you could certianly replace the center A/C with a Fantastic Fan. But
the cost of the Fantastic fan is about 25% of a new A/C. Our FC31
has 2 Fantastic Fans, one near the front A/C, and one over the
kitchen. Sometimes we use them instead of the A/Cs when pratical.
It would help if you specufied where you are living..In very hot areas
you would need all 3 A/Cs.. The now make a 15,000btu unit that will
replace a 13,500 unit and use the same amount of energy. (so they say)
BTW/you aren't THE D.B.Cooper living incognito, are you???
(sorry, I couldnt resist)...
Jack Smith
1973FC31
SoCal
--- In WanderlodgeForum@yahoogroups.com, "Dale B. Cooper"
> inoperative, my
03-23-2008, 16:07
Roof air
So that where he is! parachute out of a plane on to a Bluebird bus and hides out in plain sight!
Jim Riordan
pratical.
Jack Smith
1973FC31
SoCal
--- In "WanderlodgeForum%40yahoogroups.com", "Dale B. Cooper"
> inoperative, my
Never miss a thing. Make Yahoo your homepage.
03-23-2008, 16:20
Roof air
The center roof air on my 83 FC is a 15,000 btu unit. If you replace it with a fantastic vent you will probably leave an impression of the interior shroud on the ceiling and you may have to replace the plastic strips if they are cut to allow the shroud to fit.
Bruce - Webmaster
Wanderlodge Owners Online
(919)872-7635
Cell: (919)740-8941
03-24-2008, 06:14
Roof air
The standard opening is 14" square, so if the AC uses that size opening, you should be able to install a Fantastic Fan. However, the Fantastic Fan will require 12vdc power, and you may only have 120vac where the AC is located. (That will require some hassle to pull a 12 vdc line through the ceiling and wall.)
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
03-24-2008, 06:32
Roof air
Nothing is ever simple is it? I vote for replacing the air
conditioner with another. Not all that much difference in cost when
you get down to it especially if you have to match the ceiling (and
you certainly will) I would guess it would be at least 50% of the
cost of the air conditioner. Nothing wrong with the fantastic fans.
I replaced the old fans in my FC with them and they are really nice
but you can never have too much air in an RV in my opinion. I
replaced one of the air conditioners in the "Big Napper" and that is
pretty easy. Pretty much like replacing a window unit in a house
(once you have the thing up on the roof of the Bus) I had a fellow
lift it up with a tractor and front end loader. I had the old one
loose and we set the new one up still in the box and took the old one
out and off at the same time. The new ones are lighter then the old
ones. Just like everything else seems stuff is cheapened up. Makes
it easy to move a new one around however.
John Heckman
central Pa
1973 FC
120vac
12
> Pete Masterson
> El Sobrante CA
> aeonix1@...
one is
air
