Experience w/ B20 Bio-diesel in 8V92
05-11-2008, 06:31
Anyone in the group have experience with B20 Bio-diesel in a 8V92?
Like to have some input, such as filter clogging, mileage and power
changes, current cost, etc.
05-11-2008, 08:50
Rule of thumb, have fuel filters on board and be efficient at changing them. Bio likes to stir things up. It's a good idea to have all teflon lined flex fuel lines too. Bio likes to wax up around 50 degrees too, not for winter use.
MH
Sent: Sunday, May 11, 2008 1:31 PM
Subject: [WanderlodgeForum] Experience w/ B20 Bio-diesel in 8V92
05-11-2008, 09:43
B20 will give the similiar performance as petro diesel. I run B100
year round and don't have waxing problems. Of course, when it gets
down to 30 degrees or less, I go to about B90. With that said, I do
live in the deep South and we only have a day or two of cold
weather. If I lived in the north, I would drop my percentage more to
insure I had no problem. Easiest way to see, is to keep a pint jar
of your B20 in a unheated bay and that way you can tell at a glance
what is going on with your fuel. B20 mixture will start to wax or
gel at a slightly higher temp then straight petro. The biggest word
of advice, is try to maintain percentage so that you are not
shrinking and expanding your seals. Also 1% biodiesel will increase
the lubrication of your motor by 30% so no more additives are needed.
Al Johnson
'96 BMC B100
Mandeville, Louisiana
> MH
> From: ronmarabito2002
power
05-11-2008, 12:11
Thanks Mike. The website that I visited on Bio seem to indicate that
fuel lines for B20 were not a problem, but was over that mix.
> MH
05-11-2008, 12:18
What is your experience with the fuel lines? Any reason to change
with a B20 mix?
I know that you produce your own. What's the going price at retail
outlets?
> Al Johnson
> '96 BMC B100
> > MH
> power
05-11-2008, 12:29
Fuel lines will start to weep slowly till they have to be replaced.
I was told my fuel lines were not fuel lines but instead water
lines. Did not have to replace main engine line ( cummins to fuel
tank ). Had to replace line from generator and aquahot to fuel
tank. I am running B100 so the lines will fail faster till they are
replaced with todays fuel line. I would expect the B20 blend to make
your lines fail as well but take a longer period of time. Your the
cutover to viton fuel lines started around 1993. So I would tell you
to expect the replacement possibility but it will not fail
overnight. You will get plenty of notice before failure of the fuel
line. As far as retail price, Biodiesel will compete with Petro
Diesel but don't expect it to be much lower than. In most cases, it
is a premium to Petro Diesel.
Al Johnson
'96 BMC B100
> with a B20 mix?
> outlets?
B100
gets
do
more to
jar
glance
or
word
increase
needed.
> > Al Johnson
> > '96 BMC B100
> > > MH
8V92
8V92?
> > power
05-11-2008, 13:39
Thanks Al.
> Al Johnson
> '96 BMC B100
> > with a B20 mix?
> > outlets?
> B100
> gets
> do
> more to
> jar
> glance
> or
> word
> increase
> needed.
> > > Al Johnson
> > > '96 BMC B100
> > > > MH
> 8V92
> 8V92?
> > > power
