Sound deadening
05-11-2008, 19:53
Sound deadening
My project this weekend was the installation of the insulation (Stephen
Bartles product). Any of you FC owners if you have not you should. I believe that there is practically no sound out of the dog house area. (In addition to the foam I have a heavy cover over the outside of the dog house). The only area that seems to be transmitting sound is now the floor area drivers side. Anyone have a way to handle that? I certainly can live with what I have now but if there is more that can be done why not. Not looking to make a Lexus out this thing but I wouldn't mind getting just a bit closer. John Heckman central Pa 1973 FC |
05-11-2008, 20:50
Sound deadening
John, when you insulated the doghouse, did you remove the base of the doghouse and insulate that?
If you didn't then that is why you have sound and will have heat transfer.
Ernie Ekberg 83PT40 Livingston, Montana we have insulated many doghouses and genny compartments Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. |
05-12-2008, 00:02
Sound deadening
Hello John,
I am in the process of replacing the flooring after having removed the doghouse for valve lashing, re-insulation. On the doghouse I used 2", 2# sq./ft. quilted fiberglass and lead sandwich with mylar face. This stuff is very good but very heavy too. I was able to obtain it locally from Soundown so shipping charges were eliminated. I used Permatex High Temp RTV Silicone Gasket Maker to reinstall the doghouse. I purchased it at a heavy truck shop parts dept. About $15 a tube. I used about 1/2 tube What am I using for a sub floor in the driver's area? I am using the same sub floor throughout the front of the coach. From the the driver's side of the accelerator and brake pedals back to the salon side of the mid-door entry way where it meets ceramic floor (its all level). All the furniture and seat mounts and seat belts have been removed. I did not remove the built in couch. The vertical carpeting is in good shape so that is not being touched. This will save a lot of work and money. The sub floor material is from Soundown it is 1/2" thick 2#/sq. ft. It One side is dense foam and the other is dense mass loaded vinyl. This should be installed vinyl side up. The Soundown rep stated some people make the mistake of putting vinyl side down and this defeats the sound deadening/vibration damping properties. The following link will take you to that particular product line. http://www.soundown.com/carpet%20under.htm The finish floor is Dupont Laminate Henna Hickory, http://tinyurl.com/4gf39p . I have installed this material in the past and like it a lot. The finish floor needs 1/4" clearance around the perimeter. Both floors will rest in place without fasteners or glue and butt nicely into the vertical carpet. If I ever need to get under the floor or, God forbid, remove the doghouse again, it will be relatively easy. Bill Bill and Lisa BILLISA Adventures LLC 1983 FC 35 SB "Coach" --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > My project this weekend was the installation of the insulation (Stephen > Bartles product). Any of you FC owners if you have not you should. I > believe that there is practically no sound out of the dog house area. > (In addition to the foam I have a heavy cover over the outside of the > dog house). The only area that seems to be transmitting sound is now > the floor area drivers side. Anyone have a way to handle that? I > certainly can live with what I have now but if there is more that can > be done why not. Not looking to make a Lexus out this thing but I > wouldn't mind getting just a bit closer. > > John Heckman > central Pa > 1973 FC > |
05-12-2008, 00:02
Sound deadening
I pulled up my carpet and put a layer of insulation under it. Not
very scientific, but effective at deadening sound through the floor. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > My project this weekend was the installation of the insulation (Stephen > Bartles product). Any of you FC owners if you have not you should. I > believe that there is practically no sound out of the dog house area. > (In addition to the foam I have a heavy cover over the outside of the > dog house). The only area that seems to be transmitting sound is now > the floor area drivers side. Anyone have a way to handle that? I > certainly can live with what I have now but if there is more that can > be done why not. Not looking to make a Lexus out this thing but I > wouldn't mind getting just a bit closer. > > John Heckman > central Pa > 1973 FC > |
05-12-2008, 00:28
Sound deadening
Scott, What material did you use under the carpet? John
> > I pulled up my carpet and put a layer of insulation under it. Not > very scientific, but effective at deadening sound through the floor. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > My project this weekend was the installation of the insulation > (Stephen > > Bartles product). Any of you FC owners if you have not you > should. I > > believe that there is practically no sound out of the dog house > area. > > (In addition to the foam I have a heavy cover over the outside of > the > > dog house). The only area that seems to be transmitting sound is > now > > the floor area drivers side. Anyone have a way to handle that? I > > certainly can live with what I have now but if there is more that > can > > be done why not. Not looking to make a Lexus out this thing but I > > wouldn't mind getting just a bit closer. > > > > John Heckman > > central Pa > > 1973 FC > > > |
05-12-2008, 02:09
Sound deadening
Ernie, I did not remove the dog house. I would have had to pull up
the carpet to do so. The other part of this is that I have no room under the floor where the floor and the dog house meet to put insulation. This is likely due to the fact that this is not the original engine for this BB. The edge of the dog house is all but touching the engine so any further sound deadening will have to be from the inside of the coach. The carpet was done by the previous owner right before I purchased the bus last year. I hated to get into ripping that up at this time. I am thinking about making up a section of removable carpet to lay over the carpet more or less like a floor mat as a temporary fix at this time. At some point I might get into removing the dog house and at that time I would likely be up to replacing the carpet (again). At 61 years of age and having worked really hard on this thing for almost a year I am not in the mood to take on any more major projects for a while. I know that not all that I have done is as perfect as others (with more experience and knowledge) would have been able to accomplish but then again this ole bus is a first for me. So I have cut some corners and made some compromises to get it the best I can within reason. If you consider what it is, the age and inexperience of the old boy that owns it plus the time period that I have owned it I think I've done pretty well. My goal is to get it "pretty good" and then drop back as time and money permits and then nail down any mistakes or imperfections. (If I feel like it) That's the beauty of owning an old one. No guilt in imperfections. In the back of my mind Ernie I would like to think at some time maybe I could get out to your neck of the woods and let you do it right. Can't predict the future but its a thought. I know you guys understand what I am saying. I am basically a perfectionist in this but with advancing years I am now able to live with compromises which is what this "Big Napper" is. Steve suggested that the way to do this job was to pull the dog house out but I just didn't have it in me at this time. Maybe some of you guys understand. Especially you fellows with some years behind ya. Maybe all this comes down to saying I need a break from working on this bus. John Heckman central Pa 1973 FC > > John, when you insulated the doghouse, did you remove the base of the > doghouse and insulate that? > If you didn't then that is why you have sound and will have heat transfer. > > Ernie Ekberg > 83PT40 > Livingston, Montana > > we have insulated many doghouses and genny compartments > > > > **************Wondering what's for Dinner Tonight? Get new twists on family > favorites at AOL Food. > (http://food.aol.com/dinner-tonight?NCID=...0000000001) > |
05-12-2008, 04:40
Sound deadening
Hi John, I can appreciate being in my 6th decade, also. It really takes 2 individuals to remove the lid to the dog house and the base. One person could do it, but with the size and weight of that thing, would kill ya the rest of the day.
If you get out this way we will help you out. Shane is due out in Aug and I'm gonna "fix" his coach up, also.
Ernie Ekberg 83PT40 Livingston, Montana Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. |
05-12-2008, 05:07
Sound deadening
Same thing you have used. Makes for some thick "padding" under the
carpet, but its effective Scott --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Scott, What material did you use under the carpet? John > > > > I pulled up my carpet and put a layer of insulation under it. Not > > very scientific, but effective at deadening sound through the floor. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > My project this weekend was the installation of the insulation > > (Stephen > > > Bartles product). Any of you FC owners if you have not you > > should. I > > > believe that there is practically no sound out of the dog house > > area. > > > (In addition to the foam I have a heavy cover over the outside of > > the > > > dog house). The only area that seems to be transmitting sound is > > now > > > the floor area drivers side. Anyone have a way to handle that? I > > > certainly can live with what I have now but if there is more that > > can > > > be done why not. Not looking to make a Lexus out this thing but I > > > wouldn't mind getting just a bit closer. > > > > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > |
08-31-2008, 15:28
Sound deadening
John
I see that you used a specific material to insulate. I was not able to locate this. Would happen to have a website for this? Chuck Somers 81fcsb35 > Scott, What material did you use under the carpet? John >> >> I pulled up my carpet and put a layer of insulation under it. Not >> very scientific, but effective at deadening sound through the floor. >> >> Scott Forman >> 86 PT38 >> Memphis >> >> --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" >> wrote: >> > >> > My project this weekend was the installation of the insulation >> (Stephen >> > Bartles product). Any of you FC owners if you have not you >> should. I >> > believe that there is practically no sound out of the dog house >> area. >> > (In addition to the foam I have a heavy cover over the outside of >> the >> > dog house). The only area that seems to be transmitting sound is >> now >> > the floor area drivers side. Anyone have a way to handle that? I >> > certainly can live with what I have now but if there is more that >> can >> > be done why not. Not looking to make a Lexus out this thing but I >> > wouldn't mind getting just a bit closer. >> > >> > John Heckman >> > central Pa >> > 1973 FC >> > >> > > > |
08-31-2008, 17:16
Sound deadening
we suppplied the sound deader for the project \
look at dupreeproducts.com pick out insulation from the tabs allthe specs. are there stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, cfsomers@... wrote: > > John > > I see that you used a specific material to insulate. I was not able to > locate this. Would happen to have a website for this? > > Chuck Somers > 81fcsb35 > > > > Scott, What material did you use under the carpet? John > >> > >> I pulled up my carpet and put a layer of insulation under it. Not > >> very scientific, but effective at deadening sound through the floor. > >> > >> Scott Forman > >> 86 PT38 > >> Memphis > >> > >> --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > >> wrote: > >> > > >> > My project this weekend was the installation of the insulation > >> (Stephen > >> > Bartles product). Any of you FC owners if you have not you > >> should. I > >> > believe that there is practically no sound out of the dog house > >> area. > >> > (In addition to the foam I have a heavy cover over the outside of > >> the > >> > dog house). The only area that seems to be transmitting sound is > >> now > >> > the floor area drivers side. Anyone have a way to handle that? I > >> > certainly can live with what I have now but if there is more that > >> can > >> > be done why not. Not looking to make a Lexus out this thing but I > >> > wouldn't mind getting just a bit closer. > >> > > >> > John Heckman > >> > central Pa > >> > 1973 FC > >> > > >> > > > > > > > |
