Has anyone checked into this device??
06-01-2008, 15:34
http://www.runyourcarwithwater.com/?hop=watertt
06-01-2008, 15:47
Yeah Jon: I dont think this is anything new, except the hype.
Crosley made an attempt at a Sportscar in the 50s called the "HotShot"
that used a water injection system. They ran a 10 or 10.5
compression, and used the water to control detonation, or something
like that. I think they also said to add alchol to the mixture..
Oldsmobile had something similar on their small supercharged F85,
during the same era, I think..
Wasn't something similar on the P-38 Lightning's turbochargers during
WW-2 ?
Jack Smith
73FC35
SoCal
06-01-2008, 16:13
Jack,
A long time ago I tried these remedies on a 1979 Ford 460 engine. Even built a fuel pre-heater to atomize gasoline; along with water injection...the 460 got better HP/MPG, and no "ping"; pulled the trailer beyond belief. Not sure what this was doing to the engine. I abandoned the project because I was out of time. Perhaps I should dig this project out from the moth balls...might make a few bucks.
WW-2 ?
Jack Smith
73FC35
SoCal
Curt Sprenger
Anaheim Hills, CA
06-02-2008, 12:48
I read an article recently about someone who developed an engine
that alternated between fuel and water injection. On the first
cycles diesel was injected creating lots of heat and pushing the
piston down, on the next cycles water was injected and converted to
steam from the heat of compression and the residual heat from the
first combustion stroke. This not only took advantage of the
residual heat, it also cooled the engine so little other cooling was
required.
I believe it is still in the development stages, but it was a
pretty good design.
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Jack,
Even built
injection...the 460
belief. Not sure
I was out
balls...might
> make a few bucks.
the "HotShot"
something
during
> > WW-2 ?
> > Jack Smith
> > 73FC35
> > SoCal
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> Curt Sprenger
> Anaheim Hills, CA
06-02-2008, 12:54
Here is the article.
http://thekneeslider.com/archives/2006/0...ix-stroke-
engine/
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
to
was
> required.
> pretty good design.
> > Jack,
engine.
> Even built
> injection...the 460
> belief. Not sure
because
> I was out
> balls...might
> > make a few bucks.
> the "HotShot"
> something
mixture..
F85,
> during
> > > WW-2 ?
> > > Jack Smith
> > > 73FC35
> > > SoCal
> > > --- In WanderlodgeForum@yahoogroups.com > 40yahoogroups.com>,
> > Curt Sprenger
> > Anaheim Hills, CA
06-04-2008, 19:19
There are some B-52s & Kc 135s setting out in the AZ dessert that used water. The 135 used 1200gallons in about 30 seconds. It was used to pack more air into the inlet. Here is magic number to remember 14.7 to 1 that is the ideal air to fuel ratio so if this thing sprayed the air with water with air will be heaver therefore using less fuel to get bac to the 14.7:1
Hugh & Lexie Turner
1984 Wanderlodge PT 40 “OUR DREAM”
FMCA F393612 Bluebird Chapter
FCRV #75760 Pollywogs chapter
Good Sam Life Member 057729600
Thomaston, Ga 30286
hturner12@...
