Where to find 8V92 oil pressure sending unit?
10-20-2008, 08:10
Not "Where to buy", but rather "Where on the engine is this thing?!"
I feel silly, but can't find it. Thank you, -Ryan '86 PT-40 8V92 |
10-20-2008, 09:11
Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
10-20-2008, 09:36
The oil pressor sender on the 94pt is on the frame rail below the starter. I have a rubber oil lineconnecting to the 8vblock with an elbow on the 8vblock.. since the DDec computer reads oil pressure, the out put of the sender must go to the computer then computer controls the dash gauge, or op sender sends to both in parellel??? then again it could be that the dash gauge is reading a different sender?? if you ran the bus for any length of time with no oil pressure on the gauge, and didnt register a code on ddec, that could be a hint .
here is apage on the ddecII opsender repairfrom a site I use to help with some of the old crap I use on jobsites. they have documents used by the military for the repair of field equipment. DetroitDiesel is a big military supplier. I like the plain language of the repair procedures. Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > On mine it is not on the engine. It is on the frame rail up high on the curb side just behind the exhaust exit point. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > --- On Mon, 10/20/08, Ryan Wright ryanpwright@... wrote: > From: Ryan Wright ryanpwright@... > Subject: [WanderlodgeForum] Where to find 8V92 oil pressure sending unit? > To: "wanderlodgeforum" WanderlodgeForum@yahoogroups.com > Date: Monday, October 20, 2008, 4:10 PM > > > > > > > > > > > > Not "Where to buy", but rather "Where on the engine is this thing?!" > > I feel silly, but can't find it. > > > > Thank you, > > > > -Ryan > > '86 PT-40 8V92 > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-20-2008, 10:27
This is the location on my 86 8v92 as well.
Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > On mine it is not on the engine. It is on the frame rail up high on the curb side just behind the exhaust exit point. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > --- On Mon, 10/20/08, Ryan Wright > From: Ryan Wright > Subject: [WanderlodgeForum] Where to find 8V92 oil pressure sending unit? > To: "wanderlodgeforum" > Date: Monday, October 20, 2008, 4:10 PM > > > > > > > > > > > > Not "Where to buy", but rather "Where on the engine is this thing?!" > > I feel silly, but can't find it. > > > > Thank you, > > > > -Ryan > > '86 PT-40 8V92 > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-20-2008, 12:07
No wonder I couldn't find it. Thanks for the responses, I should be
able to find it there. I assume it's connected with a hard line? Anyone have a picture handy? -Ryan '86 PT-40 8V92 On Mon, Oct 20, 2008 at 3:27 PM, Scott Forman <scottforman75@...> wrote: > This is the location on my 86 8v92 as well. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > >> >> On mine it is not on the engine. It is on the frame rail up high on > the curb side just behind the exhaust exit point. >> Leroy Eckert >> 1990 WB-40 Smoke N Mirrors >> Dahlonega, GA >> |
10-21-2008, 11:42
OK, I think I found it. Is this it? : http://www.ryanwright.com/tmp/sensor.jpg
Found that sucker on the frame rail hiding next to the muffler. If this IS it, I have questions: 1. It (the big one) looks exactly like the sensor on my Yanmar genset, which I replaced earlier this year AND happen to have an extra of! Anyone know if they're cross-compatible before I swap them and fry something? 2. What's that little one with the orange wire for? Are there two oil pressure sensors on this engine? If so, why? 3. Looks like there are a couple of extra ports on that manifold... can I simply hook up my mechanical gauge I just bought to install in the engine compartment to one of them? Thanks! -Ryan '86 PT-40 8V92 On Mon, Oct 20, 2008 at 5:07 PM, Ryan Wright > No wonder I couldn't find it. Thanks for the responses, I should be > able to find it there. I assume it's connected with a hard line? > Anyone have a picture handy? > > -Ryan > '86 PT-40 8V92 > > On Mon, Oct 20, 2008 at 3:27 PM, Scott Forman <scottforman75@...> wrote: >> This is the location on my 86 8v92 as well. >> >> Scott Forman >> 86 PT38 >> Memphis >> >> --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert >> >>> >>> On mine it is not on the engine. It is on the frame rail up high on >> the curb side just behind the exhaust exit point. >>> Leroy Eckert >>> 1990 WB-40 Smoke N Mirrors >>> Dahlonega, GA >>> > |
10-21-2008, 12:40
10-21-2008, 15:33
one could be a sensor and one a switch. the sensor (potentiometer
sensor) would have a standing resistance that changes as you add pressure and used for a gauge. the switch would be open or closed and are commonly used for idiot lights and murphy fail safe systems??????? Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > I believe the large one is the sender for the gauge. In the files is a Teleflex cross reference which should have the gauge value and the pn. I put most of that together, Curt added info and it is believed to be correct. The other sensor is most likely a low oil pressure sender to give you a stop engine light in the event oil pressure goes below 8psi. This is what I am into now for my DDEC II system. Since you do not have DDEC your BB manual should give you some ideal how your warning system works, if in fact you have one. If you do not have a warning system, disregard because I don't have a clue. I do not want to steer you wrong, but I really think that is what it is. And no your genset gauge has a different temperature index and the sender will give you a false reading. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Tue, 10/21/08, Ryan Wright > From: Ryan Wright > Subject: Re: [WanderlodgeForum] Re: Where to find 8V92 oil pressure sending unit? > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, October 21, 2008, 7:42 PM > > > > > > > > > > > > OK, I think I found it. Is this it? : http://www.ryanwrig ht.com/tmp/ sensor.jpg > > > > Found that sucker on the frame rail hiding next to the muffler. If > > this IS it, I have questions: > > > > 1. It (the big one) looks exactly like the sensor on my Yanmar genset, > > which I replaced earlier this year AND happen to have an extra of! > > Anyone know if they're cross-compatible before I swap them and fry > > something? > > > > 2. What's that little one with the orange wire for? Are there two oil > > pressure sensors on this engine? If so, why? > > > > 3. Looks like there are a couple of extra ports on that manifold... > > can I simply hook up my mechanical gauge I just bought to install in > > the engine compartment to one of them? > > > > Thanks! > > > > -Ryan > > '86 PT-40 8V92 > > > > On Mon, Oct 20, 2008 at 5:07 PM, Ryan Wright > > > No wonder I couldn't find it. Thanks for the responses, I should be > > > able to find it there. I assume it's connected with a hard line? > > > Anyone have a picture handy? > > > > > > -Ryan > > > '86 PT-40 8V92 > > > > > > On Mon, Oct 20, 2008 at 3:27 PM, Scott Forman <scottforman75@ gmail.com> wrote: > > >> This is the location on my 86 8v92 as well. > > >> > > >> Scott Forman > > >> 86 PT38 > > >> Memphis > > >> > > >> --- In WanderlodgeForum@ yahoogroups. com, Leroy Eckert > > >> > > >>> > > >>> On mine it is not on the engine. It is on the frame rail up high on > > >> the curb side just behind the exhaust exit point. > > >>> Leroy Eckert > > >>> 1990 WB-40 Smoke N Mirrors > > >>> Dahlonega, GA > > >>> > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-23-2008, 01:09
Ryan, Mine is on the starboard frame rail (Curb side) also. Kysor 1042-08200-03 I got them at freghtliner of south florida 561-840-1066 Jim Riordan 88 wbwl xxv Ryan Wright
10-24-2008, 10:03
Hello Ryan,
"2. What's that little one with the orange wire for? Are there two oil pressure sensors on this engine? If so, why?" That's a Kysor 3 psi pressure switch, there are 2 on mine, one on each side of the oil pressure sending unit. One side passes ground over to the two solenoids mounted a foot further down on the rail, and cuts off the ground after 3 psi has been exceeded. (Perhaps so you can't turn the starter over after the engine has started running.) One of those two solenoids supplies the positive power to the starter solenoid, while the other supplies the ground to the starter solenoid, Bluebird redundancy(??) I don't recall tracing out the second 3 psi switch, perhaps, if yours is the same, you will figure out where that switch passes it's ground? Hope this helps. Michael Kramer 1986 PT-40 8V92 San Diego, CA --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > OK, I think I found it. Is this it? : http://www.ryanwright.com/tmp/sensor.jpg > > Found that sucker on the frame rail hiding next to the muffler. If > this IS it, I have questions: > > 1. It (the big one) looks exactly like the sensor on my Yanmar genset, > which I replaced earlier this year AND happen to have an extra of! > Anyone know if they're cross-compatible before I swap them and fry > something? > > 2. What's that little one with the orange wire for? Are there two oil > pressure sensors on this engine? If so, why? > > 3. Looks like there are a couple of extra ports on that manifold... > can I simply hook up my mechanical gauge I just bought to install in > the engine compartment to one of them? > > Thanks! > > -Ryan > '86 PT-40 8V92 > > > On Mon, Oct 20, 2008 at 5:07 PM, Ryan Wright > > No wonder I couldn't find it. Thanks for the responses, I should be > > able to find it there. I assume it's connected with a hard line? > > Anyone have a picture handy? > > > > -Ryan > > '86 PT-40 8V92 > > > > On Mon, Oct 20, 2008 at 3:27 PM, Scott Forman <scottforman75@...> wrote: > >> This is the location on my 86 8v92 as well. > >> > >> Scott Forman > >> 86 PT38 > >> Memphis > >> > >> --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > >> > >>> > >>> On mine it is not on the engine. It is on the frame rail up high on > >> the curb side just behind the exhaust exit point. > >>> Leroy Eckert > >>> 1990 WB-40 Smoke N Mirrors > >>> Dahlonega, GA > >>> > > > |
