Suspension dump light won't go out
11-08-2008, 05:50
OK, the title sums it up: the suspension dump light on the dash does
not go out. Always seemed a little slow going off after the tag axle aired up, but now it just stays on. All suspension air bags *are* fully aired up. Checked the Clippard valves in the front load center on advice from Ralph - no leaks found. Crawled around under the rear listening for air leaks and checking the air bags. No leaks heard, but of course that for sure doesn't mean there aren't any, based on older ears! Any ideas on what to check next? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX |
11-08-2008, 05:53
Mike,
Did you cycle the system several times? Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > OK, the title sums it up: the suspension dump light on the dash does > not go out. Always seemed a little slow going off after the tag axle > aired up, but now it just stays on. > > All suspension air bags *are* fully aired up. Checked the Clippard > valves in the front load center on advice from Ralph - no leaks found. > Crawled around under the rear listening for air leaks and checking > the air bags. No leaks heard, but of course that for sure doesn't > mean there aren't any, based on older ears! > > Any ideas on what to check next? > > Thanks, > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
11-08-2008, 06:05
Kurt,
Yes, I have cycled it several times. Also, after finding all bags up, we went out for the weekend and drove around looking for bumps after remembering a couple old posts on that. After about 50 miles it finally went out. On the way back from the weekend, it never went out over the 100 mile trip. It does not go out at all any more. I was thinking there is a sensor/air valve somewhere that is stuck, sticking, gunked up? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Mike, > > Did you cycle the system several times? > > Kurt > Horvath > 95 PT 42 > 10AC > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > OK, the title sums it up: the suspension dump light on the dash does > > not go out. Always seemed a little slow going off after the tag > axle > > aired up, but now it just stays on. > > > > All suspension air bags *are* fully aired up. Checked the Clippard > > valves in the front load center on advice from Ralph - no leaks > found. > > Crawled around under the rear listening for air leaks and checking > > the air bags. No leaks heard, but of course that for sure doesn't > > mean there aren't any, based on older ears! > > > > Any ideas on what to check next? > > > > Thanks, > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
11-08-2008, 07:06
I think your problem is a pressure switch failure. Why would you think an air leak would cause your condition??
2008/11/8 mbulriss <"mbulriss@yahoo.com">
-- Rob, Sue & Merlin Robinson 94 WLWB |
11-08-2008, 07:37
Mike, my old coach will do the same thing. I wonder if in that switch that controls the light, maybe some electrolysis may be occurring?
Ernie Ekberg 83PT40 Weatherford, Texas |
11-08-2008, 07:52
Thanks Rob,
> I think your problem is a pressure switch failure. Can you point me to where is that located? > Why would you think an air leak would cause your condition?? Mainly because the rear suspension lost pressure after about 30-45 minutes while I was washing bugs off the front end. Open to any more ideas...... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > I think your problem is a pressure switch failure. Why would you think an > air leak would cause your condition?? > > 2008/11/8 mbulriss <mbulriss@...> > > > Kurt, > > > > Yes, I have cycled it several times. > > > > Also, after finding all bags up, we went out for the weekend and drove > > around looking for bumps after remembering a couple old posts on that. > > After about 50 miles it finally went out. On the way back from the > > weekend, it never went out over the 100 mile trip. It does not go out > > at all any more. I was thinking there is a sensor/air valve somewhere > > that is stuck, sticking, gunked up? > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com > > "Kurt Horvath" > > > > > > Mike, > > > > > > Did you cycle the system several times? > > > > > > Kurt > > > Horvath > > > 95 PT 42 > > > 10AC > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "mbulriss" <mbulriss@> > > > wrote: > > > > > > > > OK, the title sums it up: the suspension dump light on the dash does > > > > not go out. Always seemed a little slow going off after the tag > > > axle > > > > aired up, but now it just stays on. > > > > > > > > All suspension air bags *are* fully aired up. Checked the Clippard > > > > valves in the front load center on advice from Ralph - no leaks > > > found. > > > > Crawled around under the rear listening for air leaks and checking > > > > the air bags. No leaks heard, but of course that for sure doesn't > > > > mean there aren't any, based on older ears! > > > > > > > > Any ideas on what to check next? > > > > > > > > Thanks, > > > > Mike Bulriss > > > > 1991 WB40 "Texas Minivan" > > > > San Antonio, TX > > > > > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > |
11-08-2008, 08:03
light is powered off a timed 60 second relay. K38. ig powered.
tripped by a 30#pressure switch K38 no buzzer. ( if the same as a 94pt)since ig powered it should go out with key off. there must be a diode between the tag and suspension dash switch or tripped relays that I need to find because I cant drop tag only and when I drop suspension the tag runs up to 100# plus so I always drop tag and main . the fuse that powers the relay for the suspension also does the backup lights. I hate having toad functions mixed anyplace in the formula. Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > OK, the title sums it up: the suspension dump light on the dash does > not go out. Always seemed a little slow going off after the tag axle > aired up, but now it just stays on. > > All suspension air bags *are* fully aired up. Checked the Clippard > valves in the front load center on advice from Ralph - no leaks found. > Crawled around under the rear listening for air leaks and checking > the air bags. No leaks heard, but of course that for sure doesn't > mean there aren't any, based on older ears! > > Any ideas on what to check next? > > Thanks, > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
11-08-2008, 08:13
two switches front and rear. I'm in KY digging a hole. but had
access to some pdf. must be aft the dump valves, follow the hissing. may be one of those fixes that require a pit or jacks. wouldnt want to tug on a pressure swithch holding up wiggle out room. Greg--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Thanks Rob, > > > I think your problem is a pressure switch failure. > Can you point me to where is that located? > > > Why would you think an air leak would cause your condition?? > Mainly because the rear suspension lost pressure after about 30-45 > minutes while I was washing bugs off the front end. > > Open to any more ideas...... > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > I think your problem is a pressure switch failure. Why would you > think an > > air leak would cause your condition?? > > > > 2008/11/8 mbulriss <mbulriss@> > > > > > Kurt, > > > > > > Yes, I have cycled it several times. > > > > > > Also, after finding all bags up, we went out for the weekend and drove > > > around looking for bumps after remembering a couple old posts on that. > > > After about 50 miles it finally went out. On the way back from the > > > weekend, it never went out over the 100 mile trip. It does not go out > > > at all any more. I was thinking there is a sensor/air valve somewhere > > > that is stuck, sticking, gunked up? > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > "Kurt Horvath" > > > > > > > > Mike, > > > > > > > > Did you cycle the system several times? > > > > > > > > Kurt > > > > Horvath > > > > 95 PT 42 > > > > 10AC > > > > > > > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > "mbulriss" <mbulriss@> > > > > wrote: > > > > > > > > > > OK, the title sums it up: the suspension dump light on the > dash does > > > > > not go out. Always seemed a little slow going off after the tag > > > > axle > > > > > aired up, but now it just stays on. > > > > > > > > > > All suspension air bags *are* fully aired up. Checked the Clippard > > > > > valves in the front load center on advice from Ralph - no leaks > > > > found. > > > > > Crawled around under the rear listening for air leaks and checking > > > > > the air bags. No leaks heard, but of course that for sure doesn't > > > > > mean there aren't any, based on older ears! > > > > > > > > > > Any ideas on what to check next? > > > > > > > > > > Thanks, > > > > > Mike Bulriss > > > > > 1991 WB40 "Texas Minivan" > > > > > San Antonio, TX > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > |
11-08-2008, 09:29
Ahhh, that explains why the light always seemed slow in going out after the tag was filled. > since ig powered it should go out with key off. It does. Time to check my prints and look around K38 if the same as 91, but I kind of doubt it. Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > light is powered off a timed 60 second relay. K38. ig powered. > tripped by a 30#pressure switch K38 no buzzer. ( if the same as a > 94pt)since ig powered it should go out with key off. there must be > a diode between the tag and suspension dash switch or tripped relays > that I need to find because I cant drop tag only and when I drop > suspension the tag runs up to 100# plus so I always drop tag and > main . the fuse that powers the relay for the suspension also does > the backup lights. I hate having toad functions mixed anyplace in > the formula. > Greg > 94ptCa > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > OK, the title sums it up: the suspension dump light on the dash > does > > not go out. Always seemed a little slow going off after the tag > axle > > aired up, but now it just stays on. > > > > All suspension air bags *are* fully aired up. Checked the Clippard > > valves in the front load center on advice from Ralph - no leaks > found. > > Crawled around under the rear listening for air leaks and checking > > the air bags. No leaks heard, but of course that for sure doesn't > > mean there aren't any, based on older ears! > > > > Any ideas on what to check next? > > > > Thanks, > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
11-08-2008, 13:27
Mike, Just had a simmilar problem. There are three pressure switches on my coach, that activate that light. I found after trouble shhoting that the tag axle pressure switch was bad. We did the trouble shooting by disconnecting the leads to the switch. high up middle of coach near tag. it was a pain but we got it figured out. BB had the parts jim riordan 88WBWL XXV stuart, fl. mbulriss <mbulriss@...> wrote:
