PT Cruise Control Replacement
11-12-2008, 09:11
Scott,
Mine was behaving the same way. They are INCREDIBLY easy to troubleshoot. Do you have the schematic for the cruise circuit and valves? The first problem with mine was the 12V supply- a wire between the relay and module was corroded. The ground was bad too. The second problem was the RV-1 Pressure Regulator. It was clogged with debris from the air system. I also disassembled the two air solenoids and cleaned them with plastic-safe solvent and lubed the o-rings with silicone. It works great now. Simple 12V systems. I can email the troubleshooting guide from Bendix if you want it. It is rarely the module that fails- but Rick Archie found a guy in DFW that rebuilds them!. Usually one of the components fails or is having a problem. With the relatively cheap price of fuel- it might be worth your time to visit Ralph over in Okie. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > It does nothing at all. > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Why don't you tell us what is going on. Does it turn on? Does it > run > > at all? Does it not engage? We need more information to help you. > > It might be salvageable. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > > <scottforman75@> wrote: > > > > > > My cruise does not work, and I cannot figure out why. I also > > > understand that some parts for this old system are no longer > > > available. > > > > > > With that in mind, has anyone installed a new cruise system on an > 80's > > > PT with 8v92? I really want to have cruise. I am open to > suggestions. > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > |
11-12-2008, 11:03
Please send anything you have
Thanks --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Scott, > > Mine was behaving the same way. They are INCREDIBLY easy to > troubleshoot. Do you have the schematic for the cruise circuit and > valves? The first problem with mine was the 12V supply- a wire between > the relay and module was corroded. The ground was bad too. The second > problem was the RV-1 Pressure Regulator. It was clogged with debris > from the air system. I also disassembled the two air solenoids and > cleaned them with plastic-safe solvent and lubed the o-rings with > silicone. It works great now. Simple 12V systems. I can email the > troubleshooting guide from Bendix if you want it. > > It is rarely the module that fails- but Rick Archie found a guy in > DFW that rebuilds them!. Usually one of the components fails or is > having a problem. With the relatively cheap price of fuel- it might be > worth your time to visit Ralph over in Okie. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <scottforman75@> wrote: > > > > It does nothing at all. > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > Why don't you tell us what is going on. Does it turn on? Does it > > run > > > at all? Does it not engage? We need more information to help you. > > > It might be salvageable. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > > > <scottforman75@> wrote: > > > > > > > > My cruise does not work, and I cannot figure out why. I also > > > > understand that some parts for this old system are no longer > > > > available. > > > > > > > > With that in mind, has anyone installed a new cruise system on an > > 80's > > > > PT with 8v92? I really want to have cruise. I am open to > > suggestions. > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > |
