Toad / Tow Brakes
11-17-2008, 15:50
Toad / Tow Brakes
We will begin full timing within the next 6 months. Our motorhome is
a 1994 Bluebird BMC diesel pusher with a Spartan air brake chassis (mountain master type class) , tow car is a 2005 Subaru Impreza WRX wagon 5 speed. I have done some net research, and have not made a final decison. I do not want to have to add/remove any components inside the the tow car to tow/drive. I want feedback inside the coach of what the toad brakes are doing. I will likely install myself, and while mechanically inclined, and I have most tools, easier install is always nice - if it doesn't give up too many features. Thus far I am at: SMI Air Force One SMI Stay In Play Duo US Gear Unified Tow Brake UTB-1000 I could use any advice/rational to help me decide, Thanks, Dan 94 BB BMC 37' Albuquerque NM |
11-17-2008, 18:05
Toad / Tow Brakes
Dan,
I have an SMI unit installed in our '87 PT38 and Bronco toad. The SMI gives feedback to let you know the toad brakes are applied, and the dial allows setting the amount of toad braking. This was installed a couple years ago so SMI may have updated units now. If you need more info. don't hesitate to let me know. On Mon, Nov 17, 2008 at 7:50 PM, drw907 <"drw907@yahoo.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
11-18-2008, 02:50
Toad / Tow Brakes
11-18-2008, 04:23
Toad / Tow Brakes
Dan, I have both a jeep wrangler and chevy suburban, as toads. When I towed the jeep wrangler I did not have an aux braking system, the coach seemed to handle this fine. a breakaway situation would have been a problem however. When I decided to tow the suburban I did research and ended up using the M&G system.The hardest part was probally tapping into the brake system of the bus. Installation on the suburban took some time but once we read the instructions things went faster. LOL Jim Riordan 88 WBWL XXV Stuart, Fl 772 -260 -1328 drw907
11-18-2008, 06:18
Toad / Tow Brakes
We have the Air Force One towing a GMC Acadia and have had no problems including towing in the Rockies.
Jerry Smith
2005 450 LXI
On Mon, Nov 17, 2008 at 10:50 PM, drw907 <"drw907@yahoo.com"> wrote:
11-18-2008, 06:24
Toad / Tow Brakes
Note that many states have requirements that a towed vehicle (car or
trailer) have a braking system if it is over a certain weight (which varies by state). In this case, even if your home state does not have that requirement, if you go into a neighboring state that does... you can get a very expensive citation. I note, too, that I've towed my Toyota Camry with the supplemental brake system turned off (oops!) and I didn't notice any difference in my coach's handling. That's why I have the sensitivity of the SMI system I have set at the lowest position, so that the toad brakes only come in during a very heavy braking situation. It also keeps the brakes from over heating and wearing excessively. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart, TX. On Nov 18, 2008, at 10:23 AM, jim riordan wrote: > Dan, > > I have both a jeep wrangler and chevy suburban, as toads. When I > towed the jeep wrangler I did not have an aux braking system, the > coach seemed to handle this fine. a breakaway situation would have > been a problem however. When I decided to tow the suburban I did > research and ended up using the M&G system.The hardest part was > probally tapping into the brake system of the bus. Installation on > the suburban took some time but once we read the instructions > things went faster. LOL > > http://www.m-gengineering.com > <snip> |
11-18-2008, 10:33
Toad / Tow Brakes
Our U S Gear brake has been in place since 2005. It performs great
and provides good feedback, and the toad is always ready to drive. I was able to integrate the wiring into the 7-pin connector so only one electric cable is needed for hookup. The U S Gear does require some installation time, but the result is worth the effort. A cable run is required from dashboard to rear bumper of the coach. In my case, a small tail light loom had to be installed from bumper to bumper in the toad. I also added a junction box under the toad's hood for a cleaner install. For toad tail lights I installed additional 1157 sockets and bulbs in spare holes in the existing lenses so the bus and toad are entirely independent except for ground and +12V battery connections. When bus brakes are applied, the additional toad brake lights come on. When the U S Gear brake activates, the stock toad brake lights also come on. Turn signals and parking lights are supplied by the additional 1157 bulbs. After dark or in the rain I usually turn the toad parking lights on as well. Bob Griesel '84 FC31 WLII WA, '04 Honda CRV toad --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > I have had the u s gear on two coaches and find it excellent. I know nothing of the others. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Mon, 11/17/08, drw907 > > From: drw907 > Subject: [WanderlodgeForum] Toad / Tow Brakes > To: WanderlodgeForum@yahoogroups.com > Date: Monday, November 17, 2008, 9:50 PM > > We will begin full timing within the next 6 months. Our motorhome is > a 1994 Bluebird BMC diesel pusher with a Spartan air brake chassis > (mountain master type class) , tow car is a 2005 Subaru Impreza WRX > wagon 5 speed. > > I have done some net research, and have not made a final decison. > > I do not want to have to add/remove any components inside the the tow > car to tow/drive. I want feedback inside the coach of what the toad > brakes are doing. > > I will likely install myself, and while mechanically inclined, and I > have most tools, easier install is always nice - if it doesn't give > up too many features. > > Thus far I am at: > SMI Air Force One > SMI Stay In Play Duo > US Gear Unified Tow Brake UTB-1000 > > I could use any advice/rational to help me decide, > Thanks, > Dan > 94 BB BMC 37' > Albuquerque NM > > > ------------------------------------ > > Yahoo! Groups Links > |
11-19-2008, 10:31
Toad / Tow Brakes
I agree with Jim on the M&G Braking. They have a site just Google and they will give you a list of who they can hook up to. I pull a Tahoe and it works fine. For your info If you use this system you should have two female air plug hookups one on the car onthe Bird and use a double ended male plug for air supply attachment It takes me about 3/4 minutes to hook up and go, brakes and all, but to my knowledge there is no feedback to the coach on the car brakes. another good thing is if you were to change toads, M&G will trade your old pump control (it goes between you master booster and master cylinder) for $400.00 and you are set to go. Since I have another toad I am looking for a M&G for a 06 Trailblazer anybody have a lead? Jim if you are reading this IF you were to be pulled over or heaven forbid you got in a accident with you Jeep attached, you are in violation. Not to mention your insurance would be out the window if no brakes on Jeep or any toad that is 1,200 pounds or more. this is the law. Scooter 2000LX Ocqueoc, MI
11-19-2008, 14:58
Toad / Tow Brakes
Al, There are differing rules (laws)in different states regarding brakes for towed vehicles. some state don't even require aux brakes.No doubt it is clearly safer and smarter to have a braking system with a breakaway feature. My suburban requires no pump becauce my master cylinder is a vacuum.
Al Scudder
11-20-2008, 00:19
Toad / Tow Brakes
You can go to a web site that tells you by state what the requirements are. I think only two states require no braking regardless of weight, 26 states if it is over 3000 pounds you are required.I think the information is on the towmaster tow site
re brake 1984 pt-40 and 1983 Fc-35
RE -------------- Original message from jim riordan |
