Stalling 80BB = Racor Questions!!!! ?????
06-01-2005, 20:52
John,
You can order Racor parts through a Parker Store. The store located in Roanoke does not stock parts for the FG900/1000 but has access to whatever I need. Usually takes a couple of weeks although I'm sure you can get quicker delivery if you are willing to pay the price. Bill & Rita in Roanoke, VA (lots of rain) 1987 FC-35 [Non-text portions of this message have been removed] |
06-01-2005, 23:55
Gang,
I pulled the Racor last night after the following events. I again removed the "in" line to it and opened up the valve at the bottom. I put the rubber tip air chuck into the "IN" side and gave it a quick shot of air and the air only seemed to want to come back at me. I then removed the "OUT" line and secondary filter and stuck a can under the secondary fuel filter adapter. I blew into the out line and heard it push the fuel through the line and into the can. I then also pushed air into the "OUT" side of the Racor and it LAUNCHED fuel out the drain valve until it was empty. After the fuel ran out, sludge started to drain. Having the air do "something" when pushed through the "out" side but not the "in" side told me something was screwy. So I tore it all apart and found the inside of the Racor to be pretty full of black sludge. The rubber washer underneath that ball on that screw on part seemed pretty weak. After giving everything a big cleaning and partial reassembly - I shot air back into the "IN" side and could only feel flow through some of the air veins at the bottom of that plastic piece. Unscrewing it showed that the ball had partially collapsed the rubber washer down into the inside - closing off the other half. I set it up again - blew air in again - and got NOTHING the second time. Unscrewing it showed that the ball had seated the washer evenly, but actually gotten pushed down so far into the washer that the ID of the washer got kind of stuck around the ball. Also, it looks like something in the bowl had caused it to become hot. One of the wire leads that plugs through the side of the Racor has distorted the plastic so bad that it couldn't be removed from the side wall and the wire that belonged to it just kind of pulled out with very little effort. Upon dissassembly, there is also that plastic "bowl" shaped device that looks to create a swirl in the flow. It also is severly distorted from what looks to be too much heat. Call me crazy, but I would prefer my fuel not to get so hot that it melts plastic inside of it and around it. This leads me to a few questions: Can I just get the specific Racor parts that I need or do I have to buy a whole new unit? Is it important that these heating elements and 5 wire setup be plugged back in or can I live without them? What all do they do that is so critical and why is there FIVE wires? Would that weakened washer alone cause the fuel to stop flowing or did it just appear weak because I subjected it to a much higher pressure with air than it would ever see from fuel? Hopefully, this will get me enough info in retun to continue my being overwhelmed. Thanks again in advance gang, John in Flint |
06-02-2005, 00:16
You can buy rebuild parts for the Racor. I replaced the bowl on
mine about 4-5 years ago. Unfortunatly I don't recall where I bought it although I do remember that I had found a dealer that carries/services Racor and ordered through them. I think I may have found them through the Racor web site. Hope this helps, John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@n...> wrote: > > > This leads me to a few questions: > |
06-02-2005, 00:32
West marine has the parts.
Tom1982 FC35 Vernon Center,NY At 12:16 PM 6/2/2005 +0000, you wrote: >You can buy rebuild parts for the Racor. I replaced the bowl on >mine about 4-5 years ago. Unfortunatly I don't recall where I >bought it although I do remember that I had found a dealer that >carries/services Racor and ordered through them. I think I may have >found them through the Racor web site. > >Hope this helps, > >John Stiles >1980 33FC >"My Navion" > > > >--- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" ><mrbeebody@n...> wrote: > > > > > > This leads me to a few questions: > > > > > > > > > >Yahoo! Groups Links > > > > |
06-02-2005, 02:38
I have been following this thread and will comment on what little I know.
On the old site I posted some information on replacement of the old see-thru bowl with four pins (two for the water sensor probe and two for the heater), with the two pin bowl currently available. If you can find it or if someone can point you to it you may find it relevant. The heater is essential at low temperature (20 or less?), you should eventually replace it. Sounds as if the integral thermostat did not shut off and cooked the internal components. --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@n...> wrote: > Gang, > > I pulled the Racor last night after the following events. I again > removed the "in" line to it and opened up the valve at the bottom. I > put the rubber tip air chuck into the "IN" side and gave it a quick > shot of air and the air only seemed to want to come back at me. I > then removed the "OUT" line and secondary filter and stuck a can under > the secondary fuel filter adapter. I blew into the out line and heard > it push the fuel through the line and into the can. I then also > pushed air into the "OUT" side of the Racor and it LAUNCHED fuel out > the drain valve until it was empty. After the fuel ran out, sludge > started to drain. > > Having the air do "something" when pushed through the "out" side but > not the "in" side told me something was screwy. > > So I tore it all apart and found the inside of the Racor to be pretty > full of black sludge. The rubber washer underneath that ball on that > screw on part seemed pretty weak. After giving everything a big > cleaning and partial reassembly - I shot air back into the "IN" side > and could only feel flow through some of the air veins at the bottom > of that plastic piece. Unscrewing it showed that the ball had > partially collapsed the rubber washer down into the inside - closing > off the other half. I set it up again - blew air in again - and got > NOTHING the second time. Unscrewing it showed that the ball had > seated the washer evenly, but actually gotten pushed down so far into > the washer that the ID of the washer got kind of stuck around the > ball. > > Also, it looks like something in the bowl had caused it to become > hot. One of the wire leads that plugs through the side of the Racor > has distorted the plastic so bad that it couldn't be removed from the > side wall and the wire that belonged to it just kind of pulled out > with very little effort. Upon dissassembly, there is also that > plastic "bowl" shaped device that looks to create a swirl in the > flow. It also is severly distorted from what looks to be too much > heat. Call me crazy, but I would prefer my fuel not to get so hot > that it melts plastic inside of it and around it. > > This leads me to a few questions: > > Can I just get the specific Racor parts that I need or do I have to > buy a whole new unit? > > Is it important that these heating elements and 5 wire setup be > plugged back in or can I live without them? > > What all do they do that is so critical and why is there FIVE wires? > > Would that weakened washer alone cause the fuel to stop flowing or did > it just appear weak because I subjected it to a much higher pressure > with air than it would ever see from fuel? > > Hopefully, this will get me enough info in retun to continue my being > overwhelmed. > > Thanks again in advance gang, > > John in Flint |
