Has anyone tried replacing dual drive tires with super singles?
02-13-2009, 02:02
Sam,
I've been running Michelin 31580R22.5's in ALL positions for a year- 22K miles so far- they were a great replacement for the 12R22.5's and fit the same rim. I started with the steers in Jan. 2008 and liked the ride so much that as $$ permitted, I got them for the drives in June 2008 and tags in December 2008. They are a load range L tire. Make sure the duals are at 110 PSI and they do not touch each other. They also do not rub the fenders. You will be amazed at the ride difference. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "surplushound" > > --- In WanderlodgeForum@yahoogroups.com, "Ross" > > > > There are no super singles over 10,000 each as the market would only > > be for overweight vehicles. Too small for production. > > Fed law allows the maximum single axle weight to be 20,000 lbs. > > Some builders have more than that as their GAWR ,and as a safety > > factor ,that is great. Legally ,however , you run the risk of fines > or > > penalties if the load is over 20,000 lbs. > > > > The 365 tire has a maximum load of over 10,000 but would not be > > suitable. > > Ross 2006 LXi > > > > I have had several people try to talk me into 11R 22.5's instead of the > 12R 22.5's I now have. I looked on Michelin's site and couldn't find > the 12R 22.5's . Have they been replaced by the 315's. Thanks > > Sam Powers > 1985 PT40 > Lexington,Ohio > |
02-13-2009, 06:00
I wouldn't rule out using quality tires from another brand. Toyo and Sumitomo seem to have a good reputation. Personally, I'm leery of the Chinese tires...
12R22.5s are not as common as the 11R22.5 -- but most larger truck tire stores and chains seem to be able to get them (but you're less likely to get a "super" sale price -- however, those "super" sale prices may be on tires that are actually stale and have been laying around for 5 or more years... )
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Feb 12, 2009, at 10:03 PM, Don Bradner wrote:
02-13-2009, 11:30
I thought of doing that myself just for the look but I was advised that wheel replacment was needed and they are EXPENSIVE!
Scooter 2000LX Ocqueoc, Mi To: WanderlodgeForum@yahoogroups.com From: surplushound@... Date: Fri, 13 Feb 2009 01:31:18 +0000 Subject: [WanderlodgeForum] Has anyone tried replacing dual drive tires with super singles?
I have excellent tread but the dreaded sidewall cracks from sun and
age. Looking for the best retire options for my 1985 PT40. Just wondering if anyone has tried super singles on the drive axle? Thanks Sam Powers 1985 PT40 Lexington,Ohio |
02-13-2009, 13:18
I looked into super singles for my drives before I retired in
Washington state. Found that they could hold 13k each, but the rims, being special, cost 600 bucks. Tires were also 600 bucks. Weight saved was 400 lbs. Wasn't worth it so didn't. Bob Lawrence 84 PT36 Workcamping in Los Fresnos, Texas > I have excellent tread but the dreaded sidewall cracks from sun and > age. Looking for the best retire options for my 1985 PT40. Just > wondering if anyone has tried super singles on the drive axle? Thanks > > > Sam Powers > 1985 PT40 > Lexington,Ohio > |
02-13-2009, 13:24
02-13-2009, 13:54
Bob,
My 315's are $600 a piece. If I could find a super single that could handle the weight, I'd be happy to buy a wheel for $600.00. Let's see: If I stay with four 315's: Four new tires is $600 times four: $2400 Or I could spend extra initially for the new super single wheels: Two wheels at $600 for a total of $1200, plus two tires at $600 each for a total of $1200 and a grand total of $2400. Future tire replacement saves $1200 with the super singles! I'm sold, where did you find the 13000lb load rated super singles? David Brady '02 LXi, NC -----Original Message----- |
02-14-2009, 13:48
I looked into these at Les Schwab Tires in Lakewood, Washington.
The other problem the mgr stated that if I blew one of these out in the toolies town, that the local tire shop definitely wouldn't have them. Bob Lawrence 84 PT36 Los Fresnos, Texas |
02-14-2009, 16:00
Bob,
I wonder where all the H.E.B. tractors and trailers that are on the highways in Texas get their serviceif they have a problem. They seem to have changed out all their equipment to the super singles And with 300 plus large grocery stores to service I am sure they took this into consideration. I also read that the EPA is encouraging this change over for fuel efficiency Probably wouldn't affect a motor home much, but here must be some good reason to invest in this change over.
Chet Geist
1981 FC33, Austin, Texas
02-15-2009, 03:11
Hi,
Safety should considered before a little fuel and a small percentage $ saving. On the commercial rigs that use these, the economics play a bigger role. Safety is less of an issue as these rigs are not overweight and enforced maximums of 20,000 lbs per axle. Also a professional driver is checking tire pressure daily, unlike most or all RV owners. If a super single had rapid failure in the drive position, the results would more likely be serious compared to a pro driver in a rig that would not be damaged by disintegrating tire. The dual gives a large safety margin. Also the max load is 22,000 per axle at maximum pressure. With side to side variance in RV's ,the pressure would nead to be max. No safety margin. Definitely a poor choice IMO. See super single http://www.michelintruck.com/michelintru...elector.do Ross 2006 450LXi |
02-15-2009, 05:20
Ross,
After you watch the videos on a truck and fully loaded trailer and on a bus with actual blowouts on the Michelin website I am impressed. Apparently the safety issue is a non issue. Cost to convert and fuel savings are the real issue for an RV owner.
Chet Geist
1981 FC33, Austin, Texas.
