Proper way to tow a Wanderlodge
03-04-2009, 07:05
Post: #31
This worries me too. You may want to be prepared by carrying
machined/drilled aluminum plates and gaskets to seal off the hub
area. I wonder if these "caps" are available from some vendor?
Stephen, here's a new product line idea.
David Brady
'02 LXi, NC
GARY MINKER wrote:
Never remove the axle tube rods and tow these units. You
risk getting sand in the tubes and pumpkin. You can not cover or seal
them effectively. If you must move the coach, you must drop the drive
shaft of you tow for any distance more than 15 to 20 miles. Any amount
of sand in the differential will be fatal right quick to the gears,
shims and bearings and it will never come out. Short distance towing
is ok with a front lift truck but long distance must be done on a
lowboy or roll away bed.
Gary
--- On Tue, 3/3/09, timvasqz com>
Subject: [WanderlodgeForum] Re: Proper way to tow a Wanderlodge
Date: Tuesday, March 3, 2009, 11:43 AM
Remove axle shaft???? is this in lue of removing a drive
line? May be
this is done so the tow driver doesnt have to crawl under the bus?
The rear is not allison so I cant see where they predict damage at
the rear to demand you render motorchoach rear not moving during a
tow????? Plus what lubes the hubs when you remove the axle shaft. you
will need to displace the lost volumn of the metal of the shaft to
get oil up to the hub?
For me I would pull the bus to a parking lot with a chain off a tow
truck (you need a tow truck for compressed air)then call a mobil
truck repair tech to determine that repair required the bus be shop
stored. When things go to a shop most of the hours it is there is
just parking effort. Mobil tech are working on your bus every hour
they are there.
Greg ofTim&Greg
94ptCA
In WanderlodgeForum@
yahoogroups. com
, "Kurt Horvath" "kguns@..."
> When all else fails
> ALLISON
> Operator's Manual
If the vehicle is a motor coach, remove the axle
> shafts from the drive wheels. When the axle shafts are removed, be
> sure to cover the wheel openings to prevent loss of lubricant and
> entry
> of dust and dirt. An auxiliary air supply will usually be required
> to actuate the vehicle brake system.
> Kurt Horvath
> 95 PT 42
> 10AC
Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.7 - Release Date: 3/3/2009 12:00 AM
03-04-2009, 07:06
Post: #32
You should never back off the spring brakes, if the thing gets away what will stop it?
Not a good idea.
Gary
--- On Mon, 3/2/09, Wayne Kotila wrote:
Subject: Re: [WanderlodgeForum] Re: Proper way to tow a Wanderlodge
Date: Monday, March 2, 2009, 2:44 PM
I forgot to mention and remembered when someone else commented about airing up the system to release the drive axle brakes, you can just release the back brakes by popping the little plastic covers of the round air brake pods. One one each side of axle, and thru the hole the plastic cover was in you can back off the brakes, this way you don't need to air up the system.
Wayne
Sent: Monday, March 2, 2009 1:23:07 PM
Wayne,
Thanks! Appreciate the info.
Jerry
85 PT40
Port Hueneme, CA
--- In WanderlodgeForum@ yahoogroups. com, Wayne Kotila
> You don't need to remove the generator crossbar if the tow truck
has the long extension forks to put on the lift, I had my PT40 towed
this way and the guy had different length extension forks to exend
from the lift arms up to the front axle, thisallowed him to stay
clear of the generator crossbar..
> Wayne PT40
> ____________ _________ _________ __
> From: jburgessx2
> Sent: Sunday, March 1, 2009 9:07:48 PM
> Scott,
> Thanks. Seems like the opinions vary a great deal. I thought it
> would be important to know this just in case. And, knowing I need
to
> remove the crossbar is important as well. I assume removing the
> crossbar isn't going to allow the tow gear from crushing the
> generator.
> Jerry
> 85 PT40
> Port Hueneme, CA
> --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman"
> <scottforman75@ ....> wrote:
> > Jerry,
> > Had my PT towed about 18 months ago. It requires removing the
> > driveshaft and, of course, an air line to the brakes to keep the
parking brakes released.
> > Another tip...the crossbar that crosses under the generator
> > compartment needs to be removed or it will be bent by the boom
for
> > the wheel lift. When I got my coach, this crossmember was bowed
> up,
> > and I always wondered why. I figured it out when I had the tow
> > saw the lift boom slide right into that "nook". It creates no
> problem
> > to have it bent, but removing it is probably the right way to go.
> > Scott Forman
> > 86 PT38
> > Memphis
> > --- In WanderlodgeForum@ yahoogroups. com, "jburgessx2"
> > wrote:
> > > Just to satisy my curiosity, I would like to know the proper
way
> to
> > tow
> > > my 85 PT40. I don't plan on having it towed but it would be
nice
> > to
> > > know if the situation arises - it never hurts to plan ahead.
> And,
> > > sometimes the tow truck folks don't know or think they know and
> > they
> > > are wrong.
> > > Thanks.
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
03-04-2009, 13:27
Post: #33
Just chock the back wheels first and once your hooked up to the tow truck then pull the wheel chocks. You also have to remember to re chock the wheels when you get where your goingbefore youunhook from the tow truck.
Wayne
Sent: Wednesday, March 4, 2009 1:06:35 PM
Not a good idea.
Gary
Wayne
Wayne,
Jerry
85 PT40
Port Hueneme, CA
> Wayne PT40
> From: jburgessx2
> Scott,
to
> generator.
> Jerry
> 85 PT40
> Port Hueneme, CA
> > Jerry,
for
> up,
> problem
> > Scott Forman
> > 86 PT38
> > Memphis
way
> to
> > tow
nice
> > to
> And,
> > they
> > > are wrong.
Thanks.
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
03-09-2009, 10:30
Post: #34
I think what Gary was referring to was what if the bird comes unhooked from the
tow truck? Without a safety in place (as in backed off brakes) nothing will
stop it until it hits something. I'm also not sure it would be legal to tow it
in this capacity in any state.
get where your going before you unhook from the tow truck.
> Wayne
> From: GARY MINKER
stop it?
> Not a good idea.
> Gary
> From: Wayne Kotila
> Wayne
> From: jburgessx2
> Wayne,
> Jerry
> 85 PT40
> Port Hueneme, CA
> from the lift arms up to the front axle, this allowed him to stay
> > Wayne PT40
> > From: jburgessx2
> > Scott,
> to
> > generator.
> > Jerry
> > 85 PT40
> > Port Hueneme, CA
> > > Jerry,
> for
> > up,
> and
> > problem
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> way
> > to
> > > tow
> nice
> > > to
> > And,
> > > they
> > > > are wrong.
> > > > Thanks.
> > > > Jerry
> > > > 85 PT40
> > > > Port Hueneme, CA
03-15-2009, 12:35
Post: #35
We bought a 1982 FC-33 and when we looked at the unit the Generator gauges in
the dash worked, we bought the couch (a week ago and got it home) started the
generator and the gagues are not working what have i gotten turned off?
John
