LED Taillights
12-02-2005, 14:27
LED Taillights
I am new here and am the proud owner of an 82 FCRB35. I am interested
in info on installing LED taillights, specifically where I can purchase
the equipment and what modifications are required.
Thanks
12-03-2005, 03:24
LED Taillights
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...>
interested
purchase
> Thanks
scott
info: on LED taillight can be found at DORAN LED BUS LIGHTS.
tim detour mi
83 35 fc.
12-03-2005, 04:04
LED Taillights
for LED replacement of standard bulbs >>> you might want to check
http://www.superbrightleds.com
R. Webb
91 WL
Cedar Rapids, IA
12-03-2005, 12:52
LED Taillights
<sforman@r...>
> interested
> purchase
> > Thanks
> scott
> tim detour mi
> 83 35 fc.
Thanks, Tim...which lights fit the FC?
12-03-2005, 12:59
LED Taillights
I used standard round bus LED lights, several MFGRs make them, bought
mine at Holland Bus Company but likely any truck supplier or school-bus
dealer will have them for around $35/each.
The stripes are put on after the taillamps so the slight amount of
newly-exposed body on the upper two will not be striped. You'll
probably want to either touch-up or install a round trim-piece to cover
the footprint from the original lights.
When you do the install, run a tail-lamp wire up from the lower one so
that you get four tail-lamps instead of two. The upper light originally
is only brake-turn, no tail.
- Jeff Miller
in Holland, MI
interested
purchase
> Thanks
12-03-2005, 15:04
LED Taillights
Central States Bus Sales has Doran 7 in led in Red and Amber for
$34.81 each. They also have the marker lights for $8.10 each.
http://www.centralstatesbus.com/fliers.html
The usual I'm nots.
Marv
2004 M380
Ocean Shores, WA
bought
bus
cover
so
originally
> - Jeff Miller
> in Holland, MI
<sforman@r...>
> interested
> purchase
> > Thanks
12-03-2005, 16:49
LED Taillights
Can they just be wired straight in with no modifications? Do the
mounting holes in the body line up?
bought
bus
cover
so
originally
> - Jeff Miller
> in Holland, MI
<sforman@r...>
> interested
> purchase
> > Thanks
12-04-2005, 03:43
LED Taillights
Mounting holes I'm not remembering, but I don't think so as the
original Cat-Eye lights have the screws out on the corners and the
new ones are round, ... thus the witness lines where the stripe
doesn't cover the cream paint on the upper light. I think that the
gasket for the new light just barely covers the old screw-holes.
As far as wiring:
I believe that the tail-lamps can be changed with no wiring
modifications (although I suggest wiring the upper one to the tail-
lamp with the lower one). If you change the side-repeaters and the
front turn-signals also (all turn signals would then be LED) then the
flasher will not blink, I install a dummy load in the overhead at the
large relays, 10ohm-20watt is what I remember using, from Radio
Shack, the big ceramic-style resistors.
Maxxima makes a nice LED clearance light that is as close as I've
found to a direct replacement: It is the same screw-holes and a 1-
wire unit like original, but it is smaller overall so again the light
doesn't cover the old footprint in the stripe (stripes added after
lights, although your '82 has the tape-stripes (through mid-'83)).
Also the Maxxima lights will require that you caulk or silicone-seal
the wire hole when installing so that water doesn't creep in through
the bracket.
Good luck,
- Jeff Miller
in Holland, MI
03-19-2009, 15:50
LED Taillights
Oops, I forgot to tell you all where to find the LED taillight pictures. They
are in the photo section under Jerry'd 85 PT40. Sorry!
Jerry
85 PT40
