Water Filter
02-07-2008, 17:58
Water Filter
The water filter on my 1985fc developed a leak. I removed it and
bypassed it. Do I track down the original part or does anyone have a
replacement. Thanks...
Mario 1985 fc 35 in sunny Leucadia CA.
02-08-2008, 14:28
Water Filter
Buy a small domestic system Lowes Home Depot have them Easier to buy
the filters and replacement parts
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "mariopatti1"
04-08-2009, 01:42
Water Filter
To ALL birders.
What kind of a potable water filter you all use. The reason I am asking this is
because my coach came with a Bactereostatic filter mounted under my bed. This
thing came from Louisiana and caost 10 years ago $400.00. It works fine but
seems rather pricey.
I use a regular 5 - micron sediment filter at the camp water outlet and the
water then goes through the bacteiostatic to the tank. Use a small (0.5 micron)
filter in kitchen for drinking, coffee, ice etc.
Is there something new or different on the market today???
Thanks
Juergen In PA
1991 WLSP 36
04-08-2009, 01:56
Water Filter
--- In WanderlodgeForum@yahoogroups.com, "Juergen" wrote:
> To ALL birders.
is because my coach came with a Bactereostatic filter mounted under my bed. This
> Thanks
> Juergen In PA
> 1991 WLSP 36
I just use one of those cheap attachment types that go on sink faucet or just
drink bottled water. I guess if I were to be out full timming I would want
something to filter the main water coming out of the system but I don't so
bottle water seems the best to us.
Jon\Rebel Bird
Bremerton washington
http://i2.photobucket.com/albums/y4/1942...ustom\
%20Motor%20Home/Donavanbirthdayparty016.jpg
04-08-2009, 05:13
Water Filter
Juergen -
We have an Everpure filter under the galley that supplies a small water tap on
the galley sink. (No point in running wash water through this filter.)
This is the filter cartridge:
http://www.campingworld.com/shopping/ite...ridge/4142
The cartridge mounts in a filter head similar to this:
http://www.freshwatersystems.com/p-703-q...cket.\
aspx
Also, all the water entering the coach flows through a 10 micron filter that
mounts on the side of the coach anytime a hose is connected.
Bob Griesel '84FC1 WLII WA
> To ALL birders.
> Thanks
> Juergen In PA
> 1991 WLSP 36
04-09-2009, 09:01
Water Filter
--- On Wed, 4/8/09, freewill2008 wrote:
Subject: [WanderlodgeForum] Re: water filter
Date: Wednesday, April 8, 2009, 1:13 PM
Juergen -
We have an Everpure filter under the galley that supplies a small water tap on the galley sink. (No point in running wash water through this filter.)
http://www.campingw orld.com/ shopping/ item/everpure- replacement- cartridge/ 4142
http://www.freshwat ersystems. com/p-703- ql3-head- assy-wshut- off-mounting- bracket.aspx
Also, all the water entering the coach flows through a 10 micron filter that mounts on the side of the coach anytime a hose is connected.
Thanks Bob
I think I am doing a little overkill here. I have good general idea now about what I really need.
Juergen in PA
1991 WLSP 36
12-29-2010, 12:24
Water Filter
Hi folks,
My '86 PT-40 has a heavy, large diameter PVC water filter under the
bed. Looks original. Anyway, it developed a hairline crack, so I
pulled it out and bypassed it while I figure out what to do.
Questions:
1. What's the purpose of this thing? Looks like it filters incoming
water, but for what?
2. Should I replace it? If so, is there a recommended replacement model?
Thanks folks.
-Ryan
'86 PT-40 8V92
12-29-2010, 13:34
Water Filter
Hi Ryan;
The original filter was a silver impregnated material that was very efficient in
delivering good water from across a world wide span of water treatments or lack
of.
These unit were and are expensive but available. Now then, with that said a
filter system of some sort is definitely needed and should be re installed. You
can go with a replaceable cartridge type or?
I suggest the files section be researched or do a search for water filter in the
messages and you should get hits on the subject.
Safe travels, Ralph &
Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
-----Original Message-----
Sender: WanderlodgeForum@yahoogroups.com
Date: Wed, 29 Dec 2010 16:24:44
To: wanderlodgeforum
Reply-To: WanderlodgeForum@yahoogroups.com
Subject: [WanderlodgeForum] Water filter
Hi folks,
Questions:
Thanks folks.
-Ryan
'86 PT-40 8V92
Yahoo! Groups Links
12-29-2010, 13:42
Water Filter
Ryan, I pulled mine and stuck it in the dumpster. Ernie- left coast
83 PT40
Weatherford, Tx 76086
817-475-3991
To: "wanderlodgeforum"
Date: Wednesday, December 29, 2010, 6:24 PM
Hi folks,
Questions:
Thanks folks.
-Ryan
'86 PT-40 8V92
12-29-2010, 14:01
Water Filter
Mine is disconnected long ago. Note to cap off the air supply, as I had a situation where an air leak from that line prevented the coach from airing up.
RWW
83 PT40
817-475-3991
To: "wanderlodgeforum" <"WanderlodgeForum@yahoogroups.com">
Hi folks,
Questions:
Thanks folks.
-Ryan
'86 PT-40 8V92
