Ignition switch
05-12-2009, 06:27
Ignition switch
If you have the old lock cylinder, you may be able to "drop it in" to the new lock -- or take it to a locksmith as a source of parts or for the locksmith to swap the cylinders if you're unable to. Most locks will require replacing and/or rearranging small pins and springs -- best left to an expert with the right tools. Besides, the locksmith may need to substitute other pins from stock for those in the lock... especially if the old cylinder isn't available or is damaged. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On May 12, 2009, at 11:16 AM, p_a_lazar wrote:
07-22-2009, 02:39
Ignition switch
