Trans Cooling fans
11-21-2009, 06:08
Trans Cooling fans
On my 96 42' Wanderlodge there is a cooler mounted on the drivers side of the
coach forward of the radiator. There are two electric cooling fans mounted to
it. They appear to be controlled by a thermostat. Neither fan runs. Can
someone tell me where the fuse is located for this circuit. Thanks, Mike
McMahan 96 42' Wanderlodge
11-21-2009, 06:39
Trans Cooling fans
Mike
The fuses are in the box where your rear start panel is
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
11-21-2009, 13:56
Trans Cooling fans
Thanks Fred. I'll look tomorrow. Mike
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Mike
> Fred & Jeanne Hulse
> Morristown Arizona
11-21-2009, 17:20
Trans Cooling fans
Mike: in that same box that Fred mentioned with the fuse for the hydraulic system cooling fans, there is a relay for the fans. I think the temp. switch that controls them is mounted to the bottom of the big blue hydraulic resevoir. One of my fans was bad and I just replaced it today.
Wayne
96WBPT42
Sent: Sat, November 21, 2009 12:08:40 PM
Subject: [WanderlodgeForum] Trans Cooling fans
On my 96 42' Wanderlodge there is a cooler mounted on the drivers side of the coach forward of the radiator. There are two electric cooling fans mounted to it. They appear to be controlled by a thermostat. Neither fan runs. Can someone tell me where the fuse is located for this circuit. Thanks, Mike McMahan 96 42' Wanderlodge
