Noisy relay
11-30-2009, 05:58
Noisy relay
Under my rear clothes closet there four metal boxes with four relays in each,
one of these are setting up a high pitch harmonic sound that's very annoying,
I've cleaned the contacts and stuffed insulation around the boxes, it helped
some but not enough. Has anyone had this problem? if so what's the fix, are
these relays available? Lee Brown 94WB 40
12-01-2009, 10:10
Noisy relay
It is a mechanically amplified and transmitted sound through the thing they are mounted on. If it really eats your lunch, mount the boxes on Lord or some other rubber mounts from Grainger.
Gary
85 pt-40
http://www.grainger.com/Grainger/wwg/sea...=0&sst=All
--- On Mon, 11/30/09, dreamcatcher7300 <bat73@...> wrote:
Subject: [WanderlodgeForum] Noisy relay
Date: Monday, November 30, 2009, 12:58 PM
Under my rear clothes closet there four metal boxes with four relays in each, one of these are setting up a high pitch harmonic sound that's very annoying, I've cleaned the contacts and stuffed insulation around the boxes, it helped some but not enough. Has anyone had this problem? if so what's the fix, are these relays available? Lee Brown 94WB 40
12-01-2009, 10:50
Noisy relay
Gary - Do you know any trick to get Grainger to sell to an individual? Our
local Grainger just turns you away if you don't represent a company. PITA.
Thanks.
Bob Griesel '84 FC31 WLII WA
> Gary
> 85 pt-40
http://www.grainger.com/Grainger/wwg/sea...&op=s\
earch&Ntt=rubber+mounts&N=0&sst=All
> From: dreamcatcher7300 <bat73@...>
> Â
12-01-2009, 23:56
Noisy relay
Pick out what you want and I will get them for you
--- On Tue, 12/1/09, freewill2008 wrote:
Subject: [WanderlodgeForum] Re: Noisy relay
Date: Tuesday, December 1, 2009, 5:50 PM
Gary - Do you know any trick to get Grainger to sell to an individual? Our local Grainger just turns you away if you don't represent a company. PITA.
Thanks.
> Gary
> 85 pt-40
> http://www.grainger .com/Grainger/ wwg/search. shtml?searchQuer y=rubber+ mounts&op= search&Ntt= rubber+mounts& N=0&sst=All
> To: WanderlodgeForum@ yahoogroups. com
> Â
12-02-2009, 10:50
Noisy relay
Bob:
Some Granger's can be difficult. Here is a solution. Go online and sign up for
a cod account. Make up some company name like Bob's Rv Repairs Inc. You can then
order online for local pickup. I have friend that did just that. We have a real
company account and just walk in!
Bruce
1988 FC35
12-02-2009, 11:11
Noisy relay
Thanks Bruce. Great idea. Bob
> Bob:
for a cod account. Make up some company name like Bob's Rv Repairs Inc. You can
then order online for local pickup. I have friend that did just that. We have a
real company account and just walk in!
> Bruce
> 1988 FC35
12-02-2009, 11:31
Noisy relay
I never had a problem when I said cash when they asked for a company name~
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
Date: Wednesday, December 2, 2009, 4:50 PM
Bob:
Some Granger's can be difficult. Here is a solution. Go online and sign up for a cod account. Make up some company name like Bob's Rv Repairs Inc. You can then order online for local pickup. I have friend that did just that. We have a real company account and just walk in!
Bruce
1988 FC35
