How do you remove a Sharp microwave/convection oven?
03-02-2010, 16:29
Can't remember. I replaced my Sharp about 3 years ago and it was actually done
by a friend of mine while we were at Quartzsite. If I can find his email address, I'll query him about it. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Eric" > > Can you pull the touch pad? If I could have removed the touch pad I likely could have got at the fuse. > > I just figured out how to pull the whole mw. How do you pull just the touch pad??? > > Eric Perplies > 96 PT-42 > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > I believe mine was behind the touch pad. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > > > > The fuse is deep in the bowels of the microwave/convection, adjacent to the circuit board on my Sharp R-1830. > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > > > > > Eric: You should have been able to check the fuse without removing the microwave. > > > > > > > > R.E. (Ron) Marabito, Dallas, Tx 92WB40 > > > > > > > > > > |
03-04-2010, 13:26
Eric: I talked with my friend about access to the fuse. He couldn't remember
and said he thought we had to remove the front of the unit, but he wasn't sure. It's been quite a while since he worked on one. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Can't remember. I replaced my Sharp about 3 years ago and it was actually done by a friend of mine while we were at Quartzsite. If I can find his email address, I'll query him about it. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > > Can you pull the touch pad? If I could have removed the touch pad I likely could have got at the fuse. > > > > I just figured out how to pull the whole mw. How do you pull just the touch pad??? > > > > Eric Perplies > > 96 PT-42 > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > > > I believe mine was behind the touch pad. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > > > > > > The fuse is deep in the bowels of the microwave/convection, adjacent to the circuit board on my Sharp R-1830. > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > > > > > > > Eric: You should have been able to check the fuse without removing the microwave. > > > > > > > > > > R.E. (Ron) Marabito, Dallas, Tx 92WB40 > > > > > > > > > > > > > > > |
03-04-2010, 16:16
I can find one screw on the top of the touchpad assembly, behind the upper
cover. That does not appear to release the touchpad. Actually after corresponding with someone else from this forum I should have left the two upper safety screws out of the microwave. The microwave would then be a LOT easier to remove. Getting at the fuse isn't bad once the microwave is out. It's getting the microwave out of the cabinet is the hard part (once you know the combination.) Thanks for the information Ron. Eric Perplies 96 PT-42 --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Eric: I talked with my friend about access to the fuse. He couldn't remember and said he thought we had to remove the front of the unit, but he wasn't sure. It's been quite a while since he worked on one. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > Can't remember. I replaced my Sharp about 3 years ago and it was actually done by a friend of mine while we were at Quartzsite. If I can find his email address, I'll query him about it. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > > > > Can you pull the touch pad? If I could have removed the touch pad I likely could have got at the fuse. > > > > > > I just figured out how to pull the whole mw. How do you pull just the touch pad??? > > > > > > Eric Perplies > > > 96 PT-42 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > > > > > I believe mine was behind the touch pad. > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > > > > > > > > The fuse is deep in the bowels of the microwave/convection, adjacent to the circuit board on my Sharp R-1830. > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > > > > > Eric: You should have been able to check the fuse without removing the microwave. > > > > > > > > > > > > R.E. (Ron) Marabito, Dallas, Tx 92WB40 > > > > > > > > > > > > > > > > > > > > > |
