Solenoid
07-05-2010, 14:20
Solenoid
Hi All.
The other day I was in the battery compartment & I felt one of the solenoids &
it was so hot you couldn't touch it. I never felt it being that hot before. Is
that normal? I shut the 12Volt system off in side & it cooled off.
Don Spithaler
89 SP 36'
Butler, PA
07-05-2010, 14:27
Solenoid
Don, touch the solenoid for your propane syatem~ talk about a "phantom draw"
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Mon, 7/5/10, DonS wrote:
Subject: [WanderlodgeForum] Solenoid
Date: Monday, July 5, 2010, 9:20 PM
Hi All.
The other day I was in the battery compartment & I felt one of the solenoids & it was so hot you couldn't touch it. I never felt it being that hot before. Is that normal? I shut the 12Volt system off in side & it cooled off.
Don Spithaler
89 SP 36'
Butler, PA
07-05-2010, 22:45
Solenoid
I've Already found that one out  Ernie but the one in my battery compartment is hotter.
   Don Spithaler
   89 SP 36'
   Butler , PA
83PT40
Wanderlodge
Hi All.
Don Spithaler
89 SP 36'
Butler, PA
07-06-2010, 00:03
Solenoid
Depending on your year those 100 amp solenoids supply the 12 volt power to the rig when the master is on. Unfortunately it is their job to get hot. The fact that it supplies 12 volts to the rig is an afterthought. Those big solenoids draw between 1 and 2 amps all by them selves.
gary 85pt40
--- On Tue, 7/6/10, Donald Spithaler wrote:
Subject: Re: [WanderlodgeForum] Solenoid
Date: Tuesday, July 6, 2010, 6:45 AM
Don Spithaler
89 SP 36'
Butler , PA
83PT40
Wanderlodge
Hi All.
Don Spithaler
89 SP 36'
Butler, PA
07-06-2010, 00:36
Solenoid
I also have a step one that stays hot, also.
83PT40
Wanderlodge
Date: Tuesday, July 6, 2010, 7:03 AM
gary 85pt40
Don Spithaler
89 SP 36'
Butler , PA
83PT40
Wanderlodge
Hi All.
Don Spithaler
89 SP 36'
Butler, PA
07-06-2010, 00:41
Solenoid
Make sure it is not the generator tie relay. If that one is stuck on, it will trash your gen battery
gary 85pt40
Date: Tuesday, July 6, 2010, 8:36 AM
83PT40
Wanderlodge
gary 85pt40
Don Spithaler
89 SP 36'
Butler , PA
83PT40
Wanderlodge
Hi All.
Don Spithaler
89 SP 36'
Butler, PA
07-06-2010, 00:46
Solenoid
Its for the step
83PT40
Wanderlodge
Date: Tuesday, July 6, 2010, 7:41 AM
gary 85pt40
83PT40
Wanderlodge
gary 85pt40
Don Spithaler
89 SP 36'
Butler , PA
83PT40
Wanderlodge
Hi All.
Don Spithaler
89 SP 36'
Butler, PA
07-06-2010, 00:53
Solenoid
Thanks Gary
Don Spithaler
89 SP 36'
Butler, PA
gary 85pt40
   Don Spithaler
   89 SP 36'
   Butler , PA
83PT40
Wanderlodge
Hi All.
Don Spithaler
89 SP 36'
Butler, PA
