Air Springs Replaced - popping sound revisited
06-19-2005, 05:07
I happened to think about another possibility Kurt. Are you hearing
this after using the front leveling jacks? On the '83-up the jacks will
usually not swing up until the airbags begin to inflate/lift the coach,
often they will swing up fast enough to hit the stop hard and make a
fairly loud "pop" sound when they do.
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach"
> When I drop the suspension and later reinflate, I hear a loud popping
> noise coming from the front airbags----- this leads me to believe
> they are getting pinched somehow during deflation? Is this anything
> to be concerned?
> Thanks for your advise
> Kurt
> '83FC35SB in NH
06-20-2005, 00:04
Jeff, I certainly appreciate your thoughts.
It happens when I set the jacks to retract, before having some air in
the bags. Then I heared a popping in one or two of the bags as the
coach started to lift. This happend only a few times, after that, I
changed the start up procedure. Now when the coach rests on the jacks
I make sure the dump switch is off, I start the engine and let the
air build up and after a few minutes I raise the jacks slowly,
releasing the weight on to the filling bags. This way no mor popping.
I keep the coach inside a garage and will check the issue on our next
outing, which unfortunately will not be until early August.
As allways thank you
Kurt
'38FC35SB in NH
will
coach,
a
> - Jeff Miller
popping
anything
> > to be concerned?
> > Kurt
> > '83FC35SB in NH
06-20-2005, 03:14
Kurt,
I realize that procedure change, sometimes each year but for our '95,
the instructions say to dump the air pressure completely before
lowering the jacks and conversely, to be completely aired up before
retracting the jacks. Trying to find strange sounds can be a problem,
especially since they can be intermittent.
George Lowry
Spearfish, SD
> Kurt
> '38FC35SB in NH
> will
> coach,
> a
>> - Jeff Miller
> popping
> anything
>>>to be concerned?
>>>Kurt
>>>'83FC35SB in NH
> Yahoo! Groups Links
06-20-2005, 06:14
George I hear you, but on my '83FC35 the coach is to low with the
bags dumped, for the jacks to swing down properly.
Thanks
Kurt
--- In WanderlodgeForum@yahoogroups.com, George Lowry
> Kurt,
our '95,
problem,
> George Lowry
> Spearfish, SD
air in
I
jacks
popping.
next
> > Kurt
> > '38FC35SB in NH
hearing
jacks
> > will
> > coach,
make
> > a
> >> - Jeff Miller
> > popping
believe
> > anything
> >>>to be concerned?
> >>>Kurt
> >>>'83FC35SB in NH
> > Yahoo! Groups Links
06-20-2005, 06:24
Kurt,
I may be way off base with this, but I get popping sounds from the jack
retracting springs. This frequently happens when they come up slowly.
Chet Geist
1981 FC33, Austin, Texas
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Kurt Achenbach
Sent: Monday, June 20, 2005 1:15 PM
Subject: [WanderlodgeForum] Re: Air Springs Replaced - popping sound
revisited
Thanks
Kurt
> Kurt,
our '95,
problem,
> George Lowry
> Spearfish, SD
air in
I
jacks
popping.
next
> > Kurt
> > '38FC35SB in NH
hearing
jacks
> > will
> > coach,
make
> > a
> >> - Jeff Miller
> > popping
believe
> > anything
> >>>to be concerned?
> >>>Kurt
> >>>'83FC35SB in NH
> > Yahoo! Groups Links
Yahoo! Groups Links
06-20-2005, 07:06
That explains it - mine are straight acting jacks. Well, I tried.
George Lowry
Spearfish, SD
> Thanks
> Kurt
>>Kurt,
> our '95,
> problem,
>>George Lowry
>>Spearfish, SD
> air in
> the
> I
> jacks
> the
> popping.
> next
>>>Kurt
>>>'38FC35SB in NH
> hearing
> jacks
>>>will
>>>coach,
> make
>>>a
>>>>- Jeff Miller
>>>popping
> believe
>>>anything
>>>>>to be concerned?
>>>>>Kurt
>>>>>'83FC35SB in NH
>>>Yahoo! Groups Links
> Yahoo! Groups Links
06-20-2005, 08:47
Chet I don't know if this will apply to your coach but my 94 was making
noises until Randy Dupree told me that the foot plate was only held on my
the two springs and that it rotated on the end of the hydraulic shaft. The
shaft has the ball end and the plate has the socket. My socket/ball had
rusted up a bit and everytime I used my jacks the socket/ball combination
made rusted metal grinding together noise including pops, bangs etc.. I
sprayed each socket with lubricant (PB Blaster) and I haven't had these
noises since. Hope this helps.
Rob Robinson
94 WLWB
Original Message:
Date: Mon, 20 Jun 2005 13:24:07 -0500
Subject: RE: [WanderlodgeForum] Re: Air Springs Replaced - popping sound
revisited
Kurt,
Chet Geist
revisited
  Thanks
  Kurt
  > Kurt,
  > I realize that procedure change, sometimes each year but for
  our '95,
  > the instructions say to dump the air pressure completely before
  > lowering the jacks and conversely, to be completely aired up before
  > retracting the jacks. Trying to find strange sounds can be a
  problem,
  > especially since they can be intermittent.
  > George Lowry
  > '95 WBDA 4203 & GM 4106 (for sale)
  > Spearfish, SD
  > Kurt Achenbach wrote:
  > > Jeff, I certainly appreciate your thoughts.
  > > It happens when I set the jacks to retract, before having some
  air in
  > > the bags. Then I heared a popping in one or two of the bags as
  > > coach started to lift. This happend only a few times, after that,
  I
  > > changed the start up procedure. Now when the coach rests on the
  jacks
  > > I make sure the dump switch is off, I start the engine and let
  > > air build up and after a few minutes I raise the jacks slowly,
  > > releasing the weight on to the filling bags. This way no mor
  popping.
  > > I keep the coach inside a garage and will check the issue on our
  next
  > > outing, which unfortunately will not be until early August.
  > > As allways thank you
  > > Kurt
  > > '38FC35SB in NH
  > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller"
  > > wrote:
  > >>I happened to think about another possibility Kurt. Are you
  hearing
  > >>this after using the front leveling jacks? On the '83-up the
  jacks
  > > will
  > >>usually not swing up until the airbags begin to inflate/lift the
  > > coach,
  > >>often they will swing up fast enough to hit the stop hard and
  make
  > > a
  > >>fairly loud "pop" sound when they do.
  > >> - Jeff Miller
  > >>[url]www.millercoachworks.com
[/url]
  > >>[url]www.wanderlodge.net
[/url]
  > >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach"
  > >>wrote:
  > >>>When I drop the suspension and later reinflate, I hear a loud
  > > popping
  > >>>noise coming from the front airbags----- this leads me to
  believe
  > >>>they are getting pinched somehow during deflation? Is this
  > > anything
  > >>>to be concerned?
  > >>>Thanks for your advise
  > >>>Kurt
  > >>>'83FC35SB in NH
  > > Yahoo! Groups Links
  Yahoo! Groups Links
    href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.yahoo.c
Service.
<!-- |**|begin egp html banner|**| -->
Yahoo! Groups Links
<!-- |**|end egp html banner|**| -->
mail2web - Check your email from the web at
http://mail2web.com/ .
06-20-2005, 14:18
Thanks Rob, I'll keep that in mind when I get to reworking my jacks. They
are a little further down the list. On my jacks the small cylinder that
extends the jacks pushes against a small bearing and they get all gunked up
from road grim. Need to keep them cleaned and working for a smooth
operating jack.
Chet Geist
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of rrob@...
Sent: Monday, June 20, 2005 3:47 PM
revisited
Rob Robinson
94 WLWB
Original Message:
revisited
Kurt,
jack
Chet Geist
revisited
Thanks
Kurt
> Kurt,
our '95,
before
problem,
> George Lowry
> Spearfish, SD
air in
that,
I
jacks
popping.
next
> > Kurt
> > '38FC35SB in NH
hearing
jacks
> > will
> > coach,
make
> > a
> >> - Jeff Miller
[/url]
[/url]
> > popping
believe
> > anything
> >>>to be concerned?
> >>>Kurt
> >>>'83FC35SB in NH
> > Yahoo! Groups Links
Yahoo! Groups Links
.c
Service.
Yahoo! Groups Links
Yahoo! Groups Links
06-21-2005, 04:34
Thanks Chet,
I am familiar with the sound the jacks make. The noise I am talking
about was like when a newly mounted tire popps in place on the rim.
Kurt
--- In WanderlodgeForum@yahoogroups.com, "Chet Geist"
> Kurt,
jack
slowly.
> Chet Geist
sound
> revisited
> Thanks
> Kurt
> > Kurt,
> our '95,
before
> problem,
> > George Lowry
> > Spearfish, SD
> air in
> the
that,
> I
> jacks
> the
> popping.
our
> next
> > > Kurt
> > > '38FC35SB in NH
> hearing
> jacks
> > > will
> > > coach,
> make
> > > a
> > >> - Jeff Miller
> > > popping
> believe
> > > anything
> > >>>to be concerned?
> > >>>Kurt
> > >>>'83FC35SB in NH
> > > Yahoo! Groups Links
> Yahoo! Groups Links
Service.
