Carrying Spares (was How High ?)
06-20-2005, 10:23
Hey Randolf, did John stand too close? Inquiring minds ya know. Is there a
story to relate (much better if at John's expense)
Original Message:
Date: Mon, 20 Jun 2005 18:14:02 -0400
Subject: Re: [WanderlodgeForum] Carrying Spares (was How High ?)
ether/starting fluid is what i use,stand back! huh john? randydupree93wb
  Sent: Monday, June 20, 2005 9:28 AM
  Lighter fluid or hair spray
  At 08:49 PM 6/19/2005, you wrote:
  >        that sounds like a good idea, having the spare without the
rim,,,
  > but,
  >how do they "blow" the tire onto the rim ,, to seat it so they can
pressurize
  >it??? that was a problem to seat the new tire on the rim,the last time i
got
  >tires. it does save having to look for the tire yes,, but, it will be
an old
  >tire like the one you blew,,, i guess it would be good enough to get
back
  >home
  >with,,,, day jax fla 83 pt-40,,
  >[Non-text portions of this message have been removed]
  >Yahoo! Groups Links
  >    * To visit your group on the web, go to:
  > < href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.yahoo.c
om/group/WanderlodgeForum/> href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.yahoo.c
  >    * To unsubscribe from this group, send an email to:
Wan
derlodgeForum-unsubscribe@yahoogroups.com
  >    * Your use of Yahoo! Groups is subject to the
  > < href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/ a>>Yahoo! Terms of Service.
  Yahoo! Groups Links
    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
<!-- |**|begin egp html banner|**| -->
Yahoo! Groups Links
<!-- |**|end egp html banner|**| -->
mail2web - Check your email from the web at
http://mail2web.com/ .
06-20-2005, 10:36
well,i had a flat on my truck,outside rear,and i had a used tire,and i was in a
hurry to sell 10,000 lbs of lead so i needed the truck fast.so,i let the air out
of the tire,jacked it up with the forklift,setting the flat tire down on a 4x4
so it would pop loose from the rim,then i picked the truck up with the big green
jack (forklift),pulled the old tire off,hammered the used tire on,sprayed it
full of starting fluid, (all the while john finn was standing around
watching)then threw a lit rag onto the tire!!WHOOP!!! the tire was seated,i put
70 lbs of air in it and away we went! john had never seen it done!! it does get
your attention when it goes WHOOP!! hahaa randydupree93wb
Sent: Monday, June 20, 2005 6:23 PM
Original Message:
rim,,,
> but,
pressurize
got
an old
back
>home
>Yahoo! Groups Links
Wan
Yahoo! Groups Links
Service.
Yahoo! Groups Links
Yahoo! Groups Links
06-20-2005, 10:43
Ah I understand. That's where his hair went........up in the butane, ether,
hairspray, lighter fluid etc etc hahaha
Original Message:
Date: Mon, 20 Jun 2005 18:36:08 -0400
in a hurry to sell 10,000 lbs of lead so i needed the truck fast.so,i let
the air out of the tire,jacked it up with the forklift,setting the flat
tire down on a 4x4 so it would pop loose from the rim,then i picked the
truck up with the big green jack (forklift),pulled the old tire
off,hammered the used tire on,sprayed it full of starting fluid, (all the
while john finn was standing around watching)then threw a lit rag onto the
tire!!WHOOP!!! the tire was seated,i put 70 lbs of air in it and away we
went! john had never seen it done!! it does get your attention when it
a
  Original Message:
randydupree93wb
  rim,,,
    > but,
  pressurize
i
  got
be
  an old
get
  back
    >home
  href=" href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.yahoo.c
om/group/WanderlodgeForum/"> href="http://groups.yahoo.c">http://groups.yahoo.c
Wan
  href=" href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/ a>"> href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/ a>
    Yahoo! Groups Links
  Service.
  Yahoo! Groups Links
  http://mail2web.com/">http://mail2web.com/ .
  Yahoo! Groups Links
Service.
Yahoo! Groups Links
06-20-2005, 10:47
yep! thats it!
Sent: Monday, June 20, 2005 6:43 PM
Original Message:
a
Original Message:
randydupree93wb
rim,,,
> but,
pressurize
i
got
be
an old
get
back
>home
>Yahoo! Groups Links
Wan
Yahoo! Groups Links
Service.
Yahoo! Groups Links
Yahoo! Groups Links
Service.
Yahoo! Groups Links
Yahoo! Groups Links
06-20-2005, 11:32
I believe this discussion could best be served on the wanderlodge_all forum.
Lets take it over there. The creator of that forum had the insight that is
needed on this forum. Many thanks, ernie ekberg
